Dadamachines Doppler is a new FPGA Platform for Open Music Hardware
https://www.electronics-lab.com/dadamachines-doppler-new-fpga-platform-open-music-hardware/
The new doppler board promises to meld the power of FPGA brains with microcontrollers and the accessibility of environments like Arduino. And the founder is so confident that could lead to new stuff, he’s making a “label” to help share your ideas. doppler is a small, 39EUR development board packing both an ARM microcontroller and […]
Programmable light controller with ATmega8 and DS1307
https://www.electronics-lab.com/programmable-light-controller-atmega8-ds1307/
Dilshan Jayakody designed and build a programmable light controller that is able to turn ON and OFF a LED at predetermined time of each day. All the design files and source code related to this project are available at https://github.com/dilshan/programmable-light. The complete documentation of this project is also available at Github Wiki. To meet the […]
Samsung Develops Industry’s First 3rd-generation 10nm-Class DRAM
https://www.electronics-lab.com/samsung-develops-industrys-first-3rd-generation-10nm-class-dram/
New 8Gb DDR4 based on most advanced 1z-nm process enables DRAM solutions with ultra-high performance and power efficiency. Samsung Electronics, the world leader in advanced memory technology, today announced that it has developed a 3rd-generation 10-nanometer-class (1z-nm) eight-gigabit (Gb) Double Data Rate 4 (DDR4) DRAM for the first time in the industry. In just 16 […]
TDK claims smallest point-of-load DC-DC converter
https://www.electronics-lab.com/tdk-claims-smallest-point-load-dc-dc-converter/
µPOL DC-DC converters bring highest power density to space-constrained apps TDK Corporation announces the new series of µPOL™ DC-DC converters, the industry’s most compact and highest power density point-of-load solutions for applications such as big data, machine learning, artificial intelligence (AI), 5G cells, IoT and computing enterprise. Rather than using side by side discrete integrated […]
Grove HAT for Raspberry Pi Features A New RISC-V-Based AI Chip
https://www.electronics-lab.com/grove-hat-raspberry-pi-features-new-risc-v-based-ai-chip/
New Grove AI HAT for Edge Computing is released from SeedStudio Seeed Studio announced a Grove HAT for Raspberry Pi based on the Sipeed RISC-V MAix. This follows after Sipeed launched their 64-bit RISC-V MAix module, crowdfunding a series of boards on Indiegogo at the end of last year. The MAix module is based on […]
ESP-WROOM-5C is a Side-Mounted ESP8285 WiFi Module
https://www.electronics-lab.com/esp-wroom-5c-side-mounted-esp8285-wifi-module/
Seems we don’t have enough ESP8266 or ESP8285 WiFi modules in the market, and based on an FCC listing, we now know that Espressif Systems has been working on another ESP8285 WiFi module – ESP-WROOM-5C – designed to be side-mounted on a PCB. ESP-WROOM-5C specifications: SoC – Espressif Systems ESP8285 Wi-Fi802.11 b/g/n WiFi 4 @ […]
Avnet Silica Presents New Renesas Synergy low power S5D3 MCUs
https://www.electronics-lab.com/avnet-silica-presents-new-renesas-synergy-low-power-s5d3-mcus/
Design your next IoT solution using the Synergy S5D3 MCU The S5D3 adds a new tier to the S5 MCU group for applications that require a high-performance Cortex M4F core at a very attractive price point, that does not require on-chip graphic acceleration or Ethernet connectivity. The S5D3 is built on a highly efficient 40nm […]
Miniduino – Arduino USB board
https://www.electronics-lab.com/miniduino-arduino-usb-board/
Miniduino is a small (19x40x3,5 mm, pin-strip and USB connector excluded) Arduino board with minimal hardware, but with access to all I/O like the Nano board and equipped with a USB connector with direct insertion integrated into the PCB: practically an Arduino Pen Drive. The board is based on the Atmel ATmega32U4 microcontroller, which is […]
HiFive1 Rev B – An open source, RISC-V development platform with wireless connectivity
https://www.electronics-lab.com/hifive1-rev-b-open-source-risc-v-development-platform-wireless-connectivity/
HiFive1 Rev B – The Second Generation HiFive1 Dev Board and the Freedom Everywhere SoC, FE310 SiFive launched an upgraded Freedom Everywhere SoC and corresponding development kit, the HiFive1 Rev B, powered by SiFive’s E31 CPU, the FE310-G002. A small yet mighty 68 mm x 51 mm, the HiFive1 Rev B can connect to Arduino-compatible […]
60GHz RF antenna module uses optimised antenna beamforming
https://www.electronics-lab.com/60ghz-rf-antenna-module-uses-optimised-antenna-beamforming/
Murata has released a high gain antenna module that facilitates communication up to 4.62 Gbps. The new millimeter-wave RF antenna module will contribute to the creation of next generation wireless networks that utilise the 60 GHz frequency by supporting the IEEE802.11ad millimeter-wave wireless LAN standard. The need is growing for faster internet communications in line […]
