Ryzen AI 9 HX470 Powers MINISFORUM’s AI X1 Pro-470 Mini PC
Shown at CES 2026, the AI X1 Pro-470 targets creators and gamers with Radeon 890M graphics, Wi-Fi 7, OCuLink eGPU support, and up to 128GB DDR5 memory.
X1 Pro-470 AMD Ryzen mini PC
The AI X1 Pro-470 is Minisforum’s latest mini PC, unveiled at CES 2026, and the first system powered by AMD Ryzen AI 9 HX 470 processor. Manufactured by TSMC using a 4 nm process, the processor features 12 cores and 24 threads, combining four high-performance Zen 5 cores with eight power-efficient Zen 5c cores, and reaching boost frequencies of up to 5.2 GHz. Graphics are handled by the integrated Radeon 890M GPU, with configurable VRAM allocation ranging from 2 GB to 48 GB, enabling smooth performance for moderate gaming, content creation, and AI workloads.
The system is designed for clear communication and productivity, featuring a dual-microphone array with AI-based noise reduction and integrated high-quality speakers. Connectivity options are extensive and include USB4, HDMI 2.1, DisplayPort 2.0, and an SD card slot, allowing support for multiple displays and a wide range of peripherals. Storage capacity can be expanded up to 12 TB, making the AI X1 Pro-470 suitable for managing large 4K video files, 3D projects, and AI datasets.
Memory support includes two DDR5 SO-DIMM slots with capacities of up to 128 GB and speeds of up to 5600 MHz, along with three internal M.2 2280 NVMe slots for high-speed storage. An OCuLink port enables connection to external GPUs such as NVIDIA RTX and Radeon RX series cards for higher frame rates and 4K or 8K gaming. Wireless connectivity includes Wi-Fi 7 and Bluetooth 5.4, while dual 2.5 Gigabit Ethernet ports provide wired networking. The metal chassis also includes a Kensington lock slot for physical security and a fingerprint sensor supporting Windows Hello.
AI X1 Pro-470 mini PC
Minisforum AI X1 Pro-470 specifications:
  • SoC: AMD Ryzen AI 9 HX470
    • 12-core DynamIQ processor with 24 Threads
      • 4x Zen 5 cores @ up to 5.2 GHz
      • 8x Zen 5c cores @ up to 3.3 GHz
    • Cache: 12MB L2 cache and 24MB shared L3 cache
    • GPU: 16-core AMD Radeon 890M integrated graphics with RDNA 3.5 GPU cores.
    • VPU:
      • Video Decoder: Up to 8Kp60 AV1, H.265, H.264, VP9, VP8, H.263, MPEG4, MPEG2
      • Video Encoder: Up to 8Kp30 H.265, H.264, VP9, VP8
    • AI accelerator: Up to 55 TOPS Neural Processing Unit (NPU) with support for INT4/INT8/INT16, FP16/BF16, and TF32; up to 86 TOPS with CPU+CPU+NPU
    • Manufacturing Process: TSMC 4nm FinFET
    • TDP: 28 Watts
  • Memory: Up to 128GB LPDDR5 (SO-DIMM х2) @ 5600 MHz
  • Storage:
    • 2x M.2 2280 NVMe SSD slot up to 4TB (PCIe 4.0 x4)
    • 1x M.2 2280 NVMe SSD slot up to 4TB (PCIe 4.0 x1)
    • Full-sized SD card slot
  • Video Output:
    • HDMI 2.1 port up to 8K@60Hz/4K@120Hz
    • DisplayPort 2.0 port up to 8K@60Hz/4K@120Hz
  • Audio:
    • 3.5mm audio output/input jack
    • Digital audio via HDMI (2x DMIC)
  • Networking:
    • 2x 2.5 Gigabit LAN (RJ45)
    • Wi-Fi 7 and Bluetooth 5.4
  • USB:
    • 2x USB 3.2 Gen2 Type-A ports @10Gbps
    • 2x USB 4 ports @40Gbps (Alt PD in 65-100W & PD Out 15W, In Rear and Alt PD Out 15W, In Front)
    • 1x USB 2.0 Type-A port
  • Expansion:
    • PCIe x16 slot with PCIe Gen4 x8 signalling
    • OCuLink for external GPUs
  • Misc:
    • Power button
    • Reset Hole
    • Kensington lock slot
    • Copilot button (dedicated)
    • Fingerprint sensor with Windows Hello support
  • Power Supply:
    • Internal DC Adapter 19V/7.1A 134.9W
    • AC Input 100-240V / 50-60Hz
  • Dimensions: 195mm x 195mm x 42.5mm to 47.5mm
  • Weight: 1.5 Kg
AI X1 Pro-470 mini PC slots
Windows 11 Pro comes preinstalled by default, while users can also install a Linux distribution based on their requirements. The system features a dual-microphone array for interaction with the installed assistant and includes VESA mount support for flexible installation options.
AI_X1 Pro-470 Built-in Power Supply
MINISFORUM has not yet announced pricing or availability, but customers who register on the company’s website will receive a $50 coupon toward the retail price. The MINISFORUM AI X1 Pro 470 mini PC, powered by the AMD Ryzen AI 9 HX 470 processor, will be available soon through the Minisforum store and on Amazon.
IOages used courtesy of MINISFORUM.
