Youyeetoo YY3588 RK3588 Development Board Launches with up to 32GB RAM, 6 TOPS NPU, and Dual Ethernet
Youyeetoo’s new RK3588 development board features an octa-core CPU, 6 TOPS NPU, up to 32GB LPDDR4X RAM, dual Ethernet, Wi-Fi 6, LTE, and multiple storage options for edge AIoT.
youyeetoo YY3588 Single Board Computer
youyeetoo YY3588 DEV KIT V2.0
Youyeetoo has introduced a new RK3588 development board designed for edge AIoT and industrial automation applications. Built around Rockchip’s RK3588 flagship SoC, the board features an octa-core CPU with four Cortex-A76 cores clocked at 2.4GHz and four Cortex-A55 cores at 1.8GHz. Connectivity options include dual-band Wi-Fi 6 + Bluetooth 5.2 via the RTL8852BE module, optional 4G LTE through a Mini PCIe slot, and dual Ethernet ports with 1GbE and 2.5GbE support.
The RK3588 development board offers 4GB to 32GB of LPDDR4/4X memory running at up to 3200Mbps, along with a tri-core NPU delivering 6 TOPS of AI performance. Storage options cover onboard eMMC 5.1 (32GB–256GB), SPI Flash, M.2 NVMe 2280 SSDs, SATA 3.0, and MicroSD cards. With its high-performance CPU, integrated NPU, and flexible storage and connectivity, the board is suitable for demanding edge computing and industrial projects.
Youyeetoo YY3588 SoM
youyeetoo YY3588 development board Specifications:
  • SoC: Rockchip RK3588 (8nm LP process), octa-core 64-bit ARM Cortex CPU, 4xCortex-A76 @2.4GHz and 4xCortex-A55 @1.8GHz frequency
  • GPU: ARM Mali-G610 MP4 “Odin” GPU
  • NPU: Tri-core NPU with up to 6 TOPS having Built-in AI accelerator, supports INT4/INT8/INT16 mixed operation
  • System Memory: up to 32GB LPDDR4 RAM with up to 3200Mbps frequency
  • Storage: up to 256GB onboard eMMC5.1 flash, MicroSD (TF) card socket, 16MB SPI Flash (optional)
  • Display Interface:
    • Pre-validated touchscreens: 7″ MIPI (1024×600) and 11.6″ eDP (1920×1080)
    • Hardware-accelerated 4K video encoding/decoding (H.265/VP9)
  • Video Input:
    • 1x HDMI-IN (4K@60fps) with HDCP 2.3 support | HDMI 2.0 input (4K@30p)
    • 2x MIPI CSI DPHY (1x 4Lanes or 2x 2Lanes, 30pin 0.5mm)
  • Video Output:
    • 1x HDMI2.1 (8K@60fps or 4K@120fps) | 2x MIPI DSI DPHY (4 Lanes output, 4K@60Hz, 30pin 0.5mm)
    • 1x DP1.4 (up to 8K@30fps via Type-C) | 1x EDP (FPC interface 30pin 0.5mm)
  • Audio:
    • 1x 3.5mm audio jack with Onboard Microphone; 2-pin header microphone socket
    • 1x SPK interface (4Ω, 2W)
    • 3.5mm audio jack (4-wire with MIC AFSL CTIA)
    • SPDIF (in 30PIN)
  • Network Connectivity:
    • 1x RJ45 Gigabit Ethernet port | 1x RJ45 2.5G Ethernet port
    • RTL8852BE Wi-Fi 6 (802.11ax) + Bluetooth 5.2 [dual-band Wi-Fi + Bluetooth via M.2 E-key slot]
    • 1x Mini PCIe slot for 4G LTE connectivity (with SIM slot)
  • USB:
    • 4x USB 3.0 Type-A
    • 1x USB2.0 Type-A (4 pin header, 4pin 2.0mm) | 1x USB Type-C (DP1.4, OTG)
  • Expansion:
    • 30-pin expansion:
      • 3x 5V, 1x 3.3V, 1x I2C, 1x PWM, 1x SPDIF,
      • 2x USB 2.0, 2x UART, 9x GPIO
      • 5x UART (including 1x dedicated DEBUG port, 4x standard)
      • 2x I2C, 1x CAN bus
      • 1x M.2 M-Key slot for NVMe SSD (4x PCIe 3.0)
  • NFC: Supports external antenna, mobile NFC pairing (Android/iOS) (ISO/IEC 14443 compliant)
  • Misc:
    • 4x buttons: Boot, Reset, Recovery, Power
    • 2x User LEDs (Programmable, red/green)
    • 1x IR input (2pin-header with 1.25mm pitch)
    • 1x FAN (2pin-header with 1.25mm pitch)
    • 1x RTC (2pin-header with 1.25mm pitch)
  • Power Supply: 12V DC jack (5.5 x 2.1mm, 12V/3A)
  • Operating temperature: -20°C to +70°C (Industrial-grade)
  • Dimensions (Mechanical Design):
    • 82.2 mm x 52 mm (SoM – BGA-embedded design)
    • 131.5 mm x 92 mm x 26.5 mm (Carrier Board)
youyeetoo YY3588 development board specifications
In terms of software, the YY3588 SoM supports multiple OS such as Android 14, Debian 12, Ubuntu 22.04, Buildroot, and OpenHarmony 5.1. Developer resources include a complete Yocto/Buildroot BSP with kernel 5.10 LTS, the RKNN-Toolkit2 for NPU tasks, and NFC API libraries for Android/debian integration. Users can go through the technical documentation section available on the youyeetoo wi-ki page.
YY3588 - RK3588 development board ports
YY3588 – RK3588 development board ports
Previously, we covered several Rockchip RK3588 development boards such as the Radxa ROCK 5 ITX+, Axelera AI Metis Compute Board, QuartzPro64 Developer Board, and more. Feel free to check them out if you’re interested in similar boards.
The YY3588 SoM and carrier board are available for purchase from the youyeetoo website starting from $141.71 (4GB RAM + 32GB eMMC), with configurations at $154.66 for 8GB + 64GB eMMC, $194.05 for 16GB + 128GB eMMC, and $264.48 for 32GB + 256GB eMMC. 16GB RAM+128GB eMMC is available at the Amazon online store for $187.79 and 8GB RAM+64GB eMMC standard kit variant for $143.10.
Images used courtesy of Youyeetoo.
