This Compact USB-C docking station adds 10Gbps USB ports, dual SD/TF card readers, Gigabit Ethernet, audio, and high-resolution display output.
EGIOZR Tech has launched a crowdfunding campaign for the EGIOZR 10-in-1 Pocket Dock, a compact USB-C hub that also includes a drop-proof silicone shell designed for travel and fieldwork.
The dock connects to a host via a USB-C port and expands it into ten interfaces, including a USB-C display port supporting up to 4K@144Hz or 2K@240Hz, Gigabit Ethernet, and multiple 10Gbps USB data ports. It also supports 100W USB PD pass-through charging, so users don’t have to sacrifice a charging port while using peripherals.
EGIOZR: 10-in-1 USB-C Pocket Dock with Detachable Shell
EGIOZR 10-in-1 Pocket Docking Station Specifications:
- Host Connection: USB-C
- Video Output: USB-C DP Alt Mode supporting up to 4K@144Hz or 2K@240Hz (Display + Data combined up to 5Gbps)
- Storage / Card Readers: SD 3.0 and microSD 3.0 (TF) slots (SDXC up to 2TB, SDR25 speeds up to 105MB/s)
- Networking: Gigabit Ethernet RJ45 port (10/100/1000M)
- USB:
- 2x USB-A 3.1 ports up to 10Gbps
- 1x USB-C data port up to 10Gbps
- Audio: 3.5mm Stereo Combo Jack
- Power Supply: USB-C PD 3.0 input, up to 100W
- Dimensions: 93 x 63 x 13.7mm
- Weight: 80 grams
The EGIOZR 10-in-1 Pocket Dock features a compact design with multiple USB ports, card readers, and Gigabit Ethernet.
The EGIOZR connects to a host device through USB-C and provides two USB-A ports and one USB-C port, all supporting up to 10Gbps data transfer. These ports can be used for SSDs, flash drives, keyboards, mice, and other peripherals.
The EGIOZR 10-in-1 docking station has launched on Kickstarter with a $637 funding goal. Rewards start at $79 for the “Limited to 100 KS Special” tier (a 50% discount off the $159 expected retail price), while the standard “Super Early Bird” tier is priced at $89.
The EGIOZR dock provides SD and TF card readers for transferring data from memory cards.
The campaign also offers several add-ons, including 1m USB4 V2 cables for $29.90, 128GB USB drives for $29, and power adapters ranging from 65W for $19 to 140W for $59. Shipping for one unit costs $15 to the United States, $11 to Europe and Australia, and $8 to Asia. Deliveries are scheduled to begin in December 2026.
Images used courtesy of Kickstarter
