Just a small sample of components that I have collected over the years.
Unlike most sellers at Ebay, I don't try to make money from shipping.
I will send by the lowest cost and not charge for packaging. I get free packaging from my
work place from our shipping department, so I recycle our received items packages.
I am here to help fellow electronics enthusiasts like myself.
I have several of each of these. You can find the Data Sheets for them here:
http://www.datasheetarchive.com/uA715HC high speed op amp
uA733HMQB Differential Video Amplifier op amp
MC14011BAL Motorola 2-Input NAND-Function Logic Gate
9601DMQB Retriggerable One Shot
DM7430N 8-Input NAND Gate
MC6802 Microprocessor with clock and optional RAM
MC10105L Triple 2-3-2-Input OR/NOR Gate
MC10125L Quad MECL to TTL Transistor
MC10131L Dual Type D Master-Slave Flip-Flop
MC14050 HEX Buffer
7430N 8-Input NAND-Function Logic Gate
10524 Quad Ttl-to-mecl Translator
54165DMQB 8-Bit Parallel-to-Serial Converter
9601DC Retriggerable Monostable Multivibrator
AM27S21DC 1,024-Bit (256 x 4) Bipolar PROM DATA SHEET:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-115/DSAP00731.html ICL7109CPL Maxim Integrated Products 12 Bit A/D Converter With 3-State Binary Outputs DATA SHEET:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-18/DSA-346047.htmlCA3028B/3 RCA General Purpose Differential Amplifier - high rel.
S68B21P American Microsystems Peripheral Interface Adapter (PIA) - Peripheral I/F Adapter
SN54155J Texas Instruments Dual 2 Line to 4 line Decoders/Demultiplexers
SNJ54S02J Texas Instruments QUADRUPLE 2-INPUT POSITIVE-NOR GATES
MC6840P Motorola Semiconductor Programmable timer module, 1 MHz
SN74LS86N Motorola / Freescale Semiconductor QUAD 2-INPUT EXCLUSIVE OR GATE
2N3823 Motorola N-CHANNEL JUNCTION FIELD EFFECT TRANSISTOR 4 pins
JAN2N1613 Microsemi Corporation NPN Transistor
2N2369A Texas Instruments SMALL SIGNAL NPN TRANSISTOR TO-18
2N2484 Fairchild Semiconductor NPN low level low noise amplifier.
93L425PC Fairchild General-Purpose Static RAM - Includes separate CE, WE cntrl
D2148H Intel General-Purpose Static RAM - Icc 150mA max
RM4156DC Raytheon Electronics Quad General Purpose Op Amp - Compensated
TRW52602 TRW RF power transistor 2GHz QTY. (2)
http://www.advancedsemiconductor.com/pdf/mln2033f.pdfMC14046B Motorola Phase Locked Loop
ICM7218AIJI Intersil Corporation 8-Digit LED Microprocessor-Compatible Multiplexed Display Decoder Driver.... QTY. (1)
DS8830N National Semiconductor Dual Differential Line Driver
LF347BN National Semiconductor Wide Bandwidth Quad JFET Input Operational Amplifier
LM324AN Motorola Operational Amplifier, General purpose, Quad channel, 32V, DIP, 14-Pin
CA3028A RCA Differential/Cascode Amplifiers from DC to 120MHz
LM311N ST Microelectronics Comparator, Single channel, Open drain/collector, 36V, DIP, 8-pin (QTY. 2)
I have a plethora of other components that I will post also.
I'm looking for a TDA7000 FM Receiver IC.
Trimmer caps 2-45 pf range
Hi frequency power transistors
electret condenser microphones
330pf ceramic caps
