Argon40 Launches Raspberry Pi HATs with PoE+ and NVMe Support
New Raspberry Pi HATs from Argon40 combine PoE+ power delivery, single-cable networking, and optional NVMe SSD expansion for Raspberry Pi 5.
Argon Industria PoE+ HATs with NVMe
Argon40 has announced two Industria PoE+ HATs for the Raspberry Pi 5 that deliver power and data over a single Ethernet cable according to the IEEE 802.3af/at PoE+ standard. Both boards can output up to 25W, and 5V/5A is required for full operation.
Standard Argon Industria PoE+ HAT is a perfect match for hobbyists and industries alike, showcasing its single-cable power and network connectivity with the IEEE 802.3af/at PoE+ standard, providing up to 25W of safe and stable power. The Argon Industria PoE+ NVMe HAT is the ultimate Raspberry Pi 5 power and expansion solution. This NVMe variant also includes built-in M.2 NVMe (2230/2242) support through the Pi 5 PCIe port, meaning fast SSD storage and other devices can be added.
Argon Industria PoE+ HATs with NVMe and without NVMe
Argon Industria PoE+ HATs with NVMe (left) and without NVMe (right)
Argon Industria PoE+ HAT with NVMe Specifications:
  • PoE Standard: IEEE 802.3af/at compliant PoE+ HAT for Raspberry Pi 5
  • Display Support: Compatible with Argon HMI display modules
  • Network Connectivity: Single Ethernet cable (data + power)
  • Network Compatibility: Works with PoE injectors and PoE network switches
  • Storage Expansion: Integrated M.2 NVMe SSD support for 2230 and 2242 form factors through PCIe
  • Expansion: SH 4-pin 3V I2C connector for Argon ONE V5 OLED Display
  • Power Delivery: Supplies stable 5V / 5A output with up to 25W power delivery
  • Cooling Design: Airflow Vents
  • Cooler Support: Compatible with the Argon THRML 30mm Active Cooler
  • Form Factor: Standard Raspberry Pi HAT layout
Argon Industria PoE+ HAT with NVMe with Raspberry Pi 5
Argon Industria PoE+ HAT with NVMe for Raspberry Pi 5
Argon Industria PoE+ HAT Specifications:
  • Power Output: 5V regulated power to Raspberry Pi 5
  • Form Factor: Raspberry Pi HAT standard
Argon Industria PoE+ HAT without NVMe for Raspberry Pi 5
Both versions are made to work with a PoE injector or a PoE switch that is compatible and can deliver both power and network connectivity via one Ethernet cable. This can reduce cabling in installations such as clusters, remote systems, signage and embedded deployments. The boards have airflow openings and are designed for use with the Argon THRML 30 mm active cooler.
The Pi Hut sells the Argon Industria PoE+ HAT for $26.17 and Argon 40 sells it for $20.00, or $31.08 if users want the Argon Industria PoE+ HAT with NVMe from the Pi Hut and $25.00 from the Argon 40. The conventional model includes mounting hardware, while the NVMe model includes PCIe cables, M.2 screws, and a mini screwdriver.
Images used courtesy of The PiHut.
