Asahi Kasei Microdevices Introduces New Operational Amplifiers for Premium Audio Systems
The new single- and dual-channel components deliver ultra-low noise and distortion metrics to match modern digital-to-analog converter capabilities in high-resolution designs.
Modern high-resolution audio systems face distinct design challenges as digital-to-analog converter technology outpaces traditional analog support electronics. High-performance converters, including the advanced AK4499EX, demand matching low-noise and low-distortion elements in the downstream analog output stage to realize their full sonic potential. To address this systemic discrepancy, Asahi Kasei Microdevices has unveiled the AK491x series of premium audio operational amplifiers (op amps), expanding its comprehensive analog audio portfolio.
The AK4911 single-channel and AK4912 feature a 0.96 nV/√Hz noise density and ±100 mA output-drive capability. Image used courtesy of Asahi Kasei
The family comprises the AK4911 single-channel variant and the AK4912 dual-channel variant. Developed under the VELVET SOUND philosophy, these components aim to preserve the complete fidelity of the signals generated by a DAC (digital-to-analog converter). The hardware focuses heavily on architectural linearity and maintaining performance across heavy loads.
Overcoming Analog Output Stage Bottlenecks
Engineering analysis of the AK4911ET and AK4912ET highlights substantial advancements in minimizing distortion and overall background noise. Both devices exhibit an exceptionally low noise density of 0.96 nV/√Hz alongside an impressive THD+N figure of -150 dB at 1 kHz. The integrated circuits also provide a swift slew rate of 26 V/µs and a wide unity-gain bandwidth extending up to 38 MHz. These attributes ensure clean signal reproduction across the entire audible frequency spectrum without introducing unwanted phase shifts or roll-off.
In circuit topologies involving highly demanding loads, such as an eight-channel current-summing configuration for a DAC, standard component options often exhibit degraded performance. The AK491x series counteracts this vulnerability by delivering a ±100 mA output-drive capability. Furthermore, the operational amplifiers operate over a wide supply voltage range from ±3.5 V to ±25 V, accommodating diverse power rail configurations. Beyond pure laboratory metrics, development priorities focused on optimizing volume balance, transparency, spatial expansion, and perceived acoustic weight to deliver a highly accurate qualitative experience.
Target Hardware and System Implementation
These ultra-low-noise components are ideally suited for high-fidelity deployment across a broad spectrum of consumer and professional hardware. The technical enhancements directly benefit equipment such as network audio systems, USB DACs, CD or SACD players, and portable digital audio players. System designers can also leverage the strong output-drive capability of wireless speakers, soundbars, studio audio interfaces, and digital mixing consoles. Ultimately, this series bridges the gap between digital converter evolution and pure analog output capability, offering a highly precise path for future high-resolution systems. Samples are currently available, and mass production is slated to begin in early 2027.
