Grinn GenioSOM-360 SoM Powered by MediaTek Genio 360P
Compact 30×30mm SoM using MediaTek Genio 360P with 7.4 TOPS AI, octa-core CPU, rich I/O, and up to 8GB LPDDR4x for edge AI and embedded systems.
Mediatek Genio 360P system-on-module
Grinn GenioSOM-360 SoM based on MediaTek Genio 360P
The GenioBoard, a small single-board computer designed to speed up the development of embedded and AI-enabled systems, was introduced by Grinn. It combines a 7.4 TOPS AI accelerator with the company’s Grinn GenioSoM-360, the first system-on-module (SoM) based on MediaTek Genio 360P octa-core Cortex-A76/A55 SoC. It is designed for edge AI applications in space-constrained applications and comes in a small (30x30mm) LGA package.
The SoM has a PMIC, up to 8GB LPDDR4x RAM, up to 64GB eMMC flash, and 303 pads that expose all I/Os, including MIPI DSI, LVDS, eDP/DP display interfaces, MIPI CSI camera interfaces, Gigabit Ethernet, USB 3.2/2.0 interfaces, PCIe Gen2, CAN FD, and additional packages.
Grinn GenioSOM-360 Bottom Side
Grinn GenioSoM-360 Specifications:
  • Processor and SoC:
    • Powered by the MediaTek Genio 360P (MT8367) (note: reference image may show the hexa-core MT8366 variant)
    • Octa-core CPU configuration:
      • 2× Arm Cortex-A76 cores @ up to 1.9 GHz (industrial) / 2.0 GHz (commercial)
      • 6× Arm Cortex-A55 cores @ up to 1.7 GHz (industrial) / 2.0 GHz (commercial)
  • Graphics and Video:
    • GPU: Arm Mali-G57 MC2 @ up to 700 MHz
      • Supports OpenGL ES 3.2, Vulkan 1.1, and OpenCL 2.0
    • Video Processing Unit (VPU):
      • Decode: H.264 / H.265 / VP9 up to 4K @ 30fps
      • Encode: H.264 / H.265 up to 1080p @ 90fps
    • JPEG performance:
      • Decode: 250 MP/s
      • Encode: 400 MP/s
  • AI Capabilities:
    • Integrated 8th-generation MediaTek NPU
    • 1× MDLA 5.3 core with GenAI performance up to 7.4 TOPS
  • Memory and Storage:
    • Up to 8GB LPDDR4X-3733 (32-bit)
    • eMMC 5.1 storage from 16GB to 64GB
  • Interfaces and Connectivity:
    • Host Interface: 303-pad LGA
    • Display Interfaces:
      • 4-lane MIPI DSI / LVDS
      • 4-lane MIPI DSI
      • 4-lane eDP 1.2 or DP 1.4
  • Camera: Dual 4-lane MIPI CSI-2
  • Audio: I2S, TDM, PCM, PDM
  • Networking: Gigabit Ethernet via RGMII
  • USB: 1× USB 3.0, 2× USB 2.0
  • Expansion:
    • PCIe Gen2 x1
    • Low-Speed I/O
    • CAN-FD support
    • 4× UART, 6× SPI, 8× I2C
    • 4× analog inputs
  • Power and Mechanical:
    • Input voltage: 3.15V to 5.0V
    • On-module PMIC: MediaTek MT6365 PMIC
    • Form factor: 30 × 30 mm (303-pad LGA package)
  • Environmental:
    • Operating temperature: -20°C to 70°C
    • Storage temperature: -40°C to 85°C (TBC)
Mediatek Genio-360P SoM block diagram
Mediatek Genio-360P SoM Block Diagram
Robotics, Smart Home applications, Smart City infrastructure (such as smart security cameras), portable healthcare devices (such as diagnostic tools and patient monitoring), and industrial automation (such as smart controllers and high-resolution HMI panels) are all excellent uses for the Grinn GenioSOM-360.
There isn’t much information on the product page, and the press release or blog we obtained from the company didn’t include any availability or pricing details.
Images used courtesy of grinn-global.com
