Kiwi-DVK OpenWrt Development Kit Features Qualcomm IPQ9570 SoC, Wi-Fi 7 SoM, and 2.5GbE with 48V PoE
8devices has recently launched their latest embedded networking board with Qualcomm IPQ9570/QCN9274 SoC featuring Kiwi Wi-Fi 7 System-on-Module available in commercial or industrial temperature range, as well as a development kit based on the module. The Kiwi Development Kit (DVK) is a compact, cutting-edge platform designed for high-performance networking and flexible I/O expansion.
Kiwi-DVK embedded networking board
The Kiwi-DVK aims to allow to be integrated with the Kiwi SoM, a compact system on module introduced earlier this year. The Kiwi SoM has an integrated GPU, a Quad-core ARM Cortex-A73 processor, and several fast interfaces like Ethernet, USB 3.0, and PCIe. High-performance Wi-Fi 7 connectivity and high-throughput multi-user support are provided by the Qualcomm IPQ9570 SoC and QCN9274 radio chip, which power the Kiwi Wi-Fi 7 SoM. At the hardware level, the OpenWrt Kiwi-DVK has an SFP port for fiber-based networking, a 2.5 Gbps Ethernet port with passive 48V PoE support, and a 10 Gbps Ethernet interface. The Kiwi SoM’s entire interface capabilities have been rendered available by the Kiwi-DVK, giving developers access to its processing and communication capabilities in a modular test environment.
Kiwi Wi-Fi 7 SoM
Kiwi Wi-Fi 7 SoM Specifications:
  • SoC: Qualcomm IPQ9570 64-bit Quad-core ARM Cortex-A73 processor @ 2.2GHz, with 1 MB L2 Cache Memory
  • System Memory: 1GB DDR4 DRAM (Expandable up to 3GB)
  • Storage: 4GB SDIO3.0 eMMC Flash
  • Networking:
    • Wireless:
      • Qualcomm QCN9274 Wi-Fi 7 (802.11be) with tri-band support (2.4GHz, 5GHz, and 6GHz)
      • IEEE 802.11 b/g/n/ax/be 2×2 MU-MIMO 2.4GHz 20/40 MHz 4096 QAM
      • IEEE 802.11 a/n/ac/ax/be 2×2 MU-MIMO 5GHz 20/40/80/160/320 MHz 4096 QAM
    • Wired: 2x USXGMII, 10GBase-R, SGMII+ or SGMII and 1x USXGMII-M, PSGMII, QSGMII, SGMII+ or SGMII
    • Antenna: 4x LGA pads on module
  • Display: LCD controller
  • PCIe: 3x PCIe 3.0 (x2 single lane and x1 dual lane)
  • USB: 1x USB 3.0
  • Audio: 1x I2S/TDM SoundWire, PCM 24-bit sample size multi-channel digital audio interface
  • Low-speed interfaces:
    • 1x UART, 2x SPI, 1x I2C EEPROM
    • 34x GPIO with Audio Pulse Width Modulation interface support
  • Misc: Power Management IC and 4x RF Pins
  • Power Supply: 3.3V DC Supply Voltage
  • Dimensions: 65.9 x 42.5 mm
  • Humidity: 10-90% RH
  • Temperature Range
    • Storage:
      • Commercial: 0-110°C
      • Industrial: -40-110°C
    • Commercial Operating Temperature: 0-65°C
    • Industrial Operating Temperature: -40-85°C
Kiwi SoM Block Diagram
Kiwi-DVK Wi-Fi 7 and 2.5GbE with 48V PoE Development Kit
Kiwi Development Kit Specifications:
  • SoM: Kiwi industrial-grade Wi-Fi 7 module
  • Storage: eMMC module socket, MicroSD card slot
  • Networking:
    • Wired:
      • 2.5Gbps Ethernet RJ45 port with 48V passive PoE support
      • SFP port for fiber-based networking
      • 10 Gbps Ethernet interface
    • Wireless:
      • Wi-Fi 7 on Kiwi module
      • 4x u.FL antenna connector (2x for 5 to 6 GHz and 2x for 2.4 GHz bands)
  • USB: 1x USB 3.0 Type-A port | 1x USB C port dedicated for UART access and 1x USB C PD for power
  • Debugging: UART console
  • Expansion:
    • M.2 A+E PCIe slot 0 (share lanes with M.2 B+M slot 0)
    • M.2 B+M PCIe slot 0 (share lanes with M.2 A+E slot 0)
    • M.2 A+E PCIe slot 1
    • mPCIe slot (share lanes with M.2 B+M slot 1)
    • M.2 B+M PCIe slot 1 (share lanes with mPCIe slot)
    • 2.54mm pitch GPIO header
  • Misc: Bootstrap switch for PCIe routing selection, 3.3/5V switch for PCIe slots, Reset button
  • Power Supply:
    • DC-Jack input 12/24V via 2-pin terminal block
    • 24-48V PoE via 2.5GbE RJ45 port
  • Dimensions: 280 x 200 mm
On the software front, Kiwi-DVK incorporates Kiwi SoM, which supports OpenWrt Linux. The Kiwi DVK is currently available for $219 on the 8Devices online shop and for €193 through CODICO.
