Tektronix 1 Series Digital Phosphor Oscilloscopes Offer 200 MHz Bandwidth from $450
Featuring 12-bit resolution, up to four channels, a 7-inch touchscreen, and optional AI-assisted control, the new oscilloscopes target affordable bench testing and debugging.
Tektronix is most commonly recognized for its extravagant and expensive oscilloscopes, but now has unveiled the 1 Series DPO, a series of low-cost digital phosphor oscilloscopes commencing at just $450, with optional AI-assisted control via the new Tek Intelligence connector. These oscilloscopes are ideal for electronics test, embedded development, education and everyday circuit debugging. The Tektronix 1 Series DPO Digital Phosphor Oscilloscope is a small graphical touchscreen oscilloscope for embedded design, debugging, teaching labs and everyday bench work. The 1 Series DPOs feature up to four analog channels, 50 MHz to 200 MHz bandwidth, 12-bit vertical resolution as well as up to 1.25 GS/s sampling rate.
It has the same TekScope interface as the more expensive Tektronix oscilloscopes, adapted for a 7-inch capacitive touch screen with a streamlined front panel. New users are up and running quickly measuring, experienced engineers have a familiar workflow. They also include 10 Mpoints of memory per channel, support I2C, SPI and UART protocol decoding and have built-in waveform analysis tools. Higher-priced S models also have an additional 25 MHz arbitrary function generator (AFG) and Bode plot analysis.
Tektronix 1 Series DPO Oscilloscopes – Key Specifications:
  • Available Models: 16 configurations spanning four bandwidth levels, 2- or 4-channel options, and models with or without an integrated arbitrary function generator (AFG).
  • Display: 7-inch capacitive multi-touch display with 1024 × 600 resolution.
  • Analog Inputs: 2 or 4 analog channels.
  • Bandwidth Options: 50 MHz, 70 MHz, 100 MHz, and 200 MHz.
  • ADC Resolution: 12-bit vertical resolution.
  • Sampling Rate:
    • Up to 1.25 GS/s with half of the available channels enabled.
    • 625 MS/s when all channels are active.
  • Record Length: 10 Mpoints per channel.
  • Waveform Acquisition Rate: Up to approximately 125,000 waveforms per second.
  • Analog Input Characteristics:
    • Input impedance: 1 MΩ ±2%.
    • Typical input capacitance: 17 pF.
    • Input sensitivity: 1 mV/div to 10 V/div.
    • Input coupling: AC and DC.
  • Connectivity and Remote Control:
    • Ethernet: 10/100 Mbps with eScope remote-control functionality.
    • USB: One USB 2.0 host port and one USB 2.0 device port.
    • Security: Kensington security slot.
  • Triggering and Protocol Analysis:
    • Trigger types: Edge, pulse-width, runt, timeout, rise/fall-time, and serial bus triggering.
    • Serial protocol decoding: I2C, SPI, and UART (RS-232/422/485).
  • Waveform Analysis and Measurement:
    • 23 automatic waveform measurements.
    • FFT analysis and basic/advanced waveform mathematics.
    • XY waveform plotting and limit mask testing.
    • Waveform cursors and measurement statistics.
  • Integrated Test Instruments:
    • 5-digit digital voltmeter (DVM).
    • 6-digit frequency counter.
    • 14-bit, single-channel arbitrary function generator with 25 MHz bandwidth (S models only).
    • Bode plot and frequency response analysis (S models only).
  • Power and Physical Characteristics:
    • Power supply: 100–240V AC, 50/60 Hz.
    • Maximum power consumption: 45W.
    • Dimensions: 291 × 174 × 102 mm (W × H × D).
    • Weight: 2.16 kg.
    • Operating temperature: 0°C to 50°C.
  • Installation and Mounting:
    • Standard 100 × 100 mm VESA mounting compatibility
    • Optional 4U rackmount kit
Tektronix 1 Series Front panel and Rear Panel
The 1 Series DPO utilizes the identical TekScope intuitive user interface as found on flagship Tektronix oscilloscopes, but with a narrower 7-inch touch-screen display. You can navigate and zoom the waveforms right on the display, access measurements, and configure settings all through on-screen menus. There are also physical buttons and knobs for common controls. The company also announced early access to its new Tek Intelligence connector, which allows AI agents to get in touch with the oscilloscope using natural language instructions. The company said the connector can translate user requests into instrument commands for configuration, measurement and automation. This isn’t a built-in feature but is available through an early access program at the moment.
Tektronix 1 Series DPO oscilloscope with included power cord, passive probes, and other accessories
Tektronix 1 Series Digital Phosphor Oscilloscopes (DPO) with included power cord, passive probes, and other accessories
We have previously covered several oscilloscopes, including Rohde & Schwarz’s R&S RTB 2 and MXO 5C series, RIGOL’s DS80000, Keysight’s 1U XR3, and compact models such as ThunderScope and Haasoscope Pro. Feel free to check out our previous coverage if you are interested in learning more about these oscilloscopes.
Tektronix 1 Series DPO is obtainable in 16 different price and standard arrangements. The basic introductory 50 MHz-bandwidth, two-channel DPO1052 is $450, and the DPO1052S with a built-in function generator is $690. The most premium version of this model, the DPO1204S, is a four-channel, 200 MHz bandwidth unit with a built-in function generator and costs $1,650. Everyone can read more about it on the product page and in the press release.
Images used courtesy of Tektronix
