ZOTAC ZBOX PRO CM5-PICO Packs Dual 4K HDMI into a Fanless Industrial PC
Powered by Raspberry Pi CM5, this compact industrial PC offers up to 16GB RAM, M.2 expansion, and versatile I/O.
ZOTAC ZBOX PRO CM5-PICO Fanless Industrial PC
The ZOTAC ZBOX PRO CM5-PICO is a compact Fanless Industrial PC powered by the Raspberry Pi Compute Module 5 (CM5) platform. Designed for embedded systems, industrial automation, digital signage, and edge computing applications, this palm-sized computer combines processing performance, flexible connectivity, and silent operation in a durable aluminum enclosure. Its fanless cooling design supports continuous operation, while its compact dimensions of 114.8 × 76 × 31.3 mm make it suitable for space-constrained installations.
The system features a Broadcom BCM2712 processor with four Arm Cortex-A76 cores running at 2.4 GHz, alongside a VideoCore VII GPU operating at 800 MHz. It supports dual independent HDMI 2.1 displays at resolutions up to 4K at 60 Hz, with configurable memory options of up to 16GB LPDDR4X and onboard eMMC storage of up to 64GB. Additional features include Gigabit Ethernet with Precision Time Protocol (PTP), M.2 expansion, a 40-pin GPIO header, and industrial-grade protection for external I/O ports.
We previously covered the ZBOX PI336 pico, a powerful portable PC with an extremely small form factor, and the ZOTAC ZBOX pico PI225-GK, a mini PC about the size of a 2.5-inch SSD. Feel free to check out these articles if you’re interested in learning more about these compact computing solutions.
ZOTAC ZBOX PRO CM5-PICO front side
ZOTAC ZBOX PRO CM5-PICO Fanless PC Specifications:
- Processor and Graphics:
- Processor: Broadcom BCM2712 quad-core Arm Cortex-A76
- CPU frequency: Up to 2.4 GHz
- Graphics: Broadcom VideoCore VII GPU at 800 MHz
- Video decoding: H.265 HEVC hardware decoding
- Display outputs: 2 × HDMI 2.1
- Maximum display resolution: 4096 × 2160 at 60 Hz per output
- Memory and Storage:
- System memory: 2GB, 4GB, 8GB, or 16GB LPDDR4X
- Onboard storage: 16GB, 32GB, or 64GB eMMC
- CM5 Lite configuration: No onboard eMMC, with microSD card support
- Expansion: M.2 2280 Key-M slot for compatible SSDs or AI/NPU modules
- Networking and Wireless Connectivity:
- Ethernet: 1 × Gigabit Ethernet with PTP support
- Wireless LAN: Optional Wi-Fi 5 (IEEE 802.11ac/a/b/g/n)
- Bluetooth: Bluetooth 5.0
- Cellular connectivity: Optional LTE Cat 1 bis module through M.2 3024 Key-B
- Antenna connectivity: Two Wi-Fi antenna connectors
- I/O Ports and Expansion Interfaces:
- USB: 2 × USB 3.2 Type-A ports
- USB Type-C: 1 × port for firmware updates
- GPIO: 40-pin Raspberry Pi HAT-compatible header
- Camera and display interfaces: 2 × internal four-lane DSI/CSI-2 connectors
- Serial connectivity: Internal RS-232 header
- Debugging: UART debug header
- Cooling expansion: Internal fan header
- Industrial Features and Reliability:
- Cooling system: Passive cooling with no moving parts in the standard configuration
- Enclosure: Durable aluminum housing
- Protection: TVS and ESD protection on external I/O ports
- Watchdog: Built-in Broadcom SoC watchdog
- Real-time clock: RTC with CR2032 battery backup
- Power input: DC 5V to 20V
- Included power adapter: 12V, 2.5A
- Dimensions: 114.8 × 76 × 31.3 mm
- Operating temperature: -20°C to +55°C for the main unit
Antenna side
The ZOTAC ZBOX PRO CM5-PICO ships with Raspberry Pi OS based on Debian 13 as its factory-installed operating system. The platform also lists support for Ubuntu for Raspberry Pi, Twister OS, Emteria Android, LibreELEC, and Home Assistant OS. This software flexibility allows developers and system integrators to use the computer for applications such as industrial monitoring, multimedia playback, smart building control, embedded software development, and edge computing.
The system is based on the Raspberry Pi Compute Module 5 ecosystem, giving developers access to a broad range of software resources, development tools, and hardware integration options. Its 40-pin GPIO header and internal DSI/CSI-2 interfaces enable integration with compatible sensors, cameras, displays, and expansion boards. The M.2 interface also provides options for storage expansion or compatible AI acceleration modules. For product specifications, configuration details, and manufacturer information, users can consult the official ZOTAC documentation.
Ports
ZOTAC has not disclosed the official pricing of the ZBOX PRO CM5-PICO in the provided product information. The final price may vary depending on the selected Compute Module 5 configuration, including RAM capacity, onboard eMMC storage, and optional wireless or cellular connectivity. The product was showcased at ISE 2026 in February 2026, and its listed product lifecycle extends through January 2036, making it a potential option for long-term embedded deployments. For the latest availability, configuration options, and pricing updates, visit the official product page.
Images used courtesy of Zotac.
