PH12FEI – Thin Mini-ITX Board with Coffee Lake CPU
https://www.electronics-lab.com/ph12fei-thin-mini-itx-board-coffee-lake-cpu/
Thin Mini-ITX Mainboard for compact display systems With the Thin Mini-ITX Board PH12FEI, ICP Deutschland offers system integrators a motherboard to produce particularly flat displays or embedded systems. The PH12FEI is equipped with an IO Shield at half height and horizontal memory slots, which bring it to a height of only 20 mm. The LGA1151 […]
New large-format yellow tri-color e-paper displays open the door to more effective and engaging sign
https://www.electronics-lab.com/new-large-format-yellow-tri-color-e-paper-displays-open-door-effective-engaging-sign/
Pervasive Displays (PDi), a world leader in e-paper displays (EPDs), today launches its new range of large-format tri-color displays that render text and images in yellow, as well as black and white. With both 7.4 and 12.2-inch models available, the new EPDs open up fresh opportunities to enrich customer experiences by displaying information in three colors. E-paper displays are […]
The only 2.2″ TFT designed to fit 1U front panels
https://www.electronics-lab.com/2-2%e2%80%b3-tft-designed-fit-1u-front-panels/
The DT022CTFT is a 2.2 inch TFT LCD module with 240 x 320 RGB resolution. This LCD module is the only high resolution 2.2” TFT on the market that is designed specifically to fit 1U rack mount equipment. The a-Si TFT LCD uses a single chip driver (Ilitek ILI9341) that provides a full color display […]
NEW: 3.5” JNF835-8365U – SBC from Jetway
https://www.electronics-lab.com/new-3-5-jnf835-8365u-sbc-jetway/
The JETWAY JNF835 is 3.5” form factor board adopts the Intel® Whiskey Lake-U i5-8365UE Processor. The board supports two SO-DIMM DDR4 2400Mhz memory, up to 32GB. Featuring the integrated Intel® Gigabit Ethernet controller, the JNF835 offers two 10/100/1000Base-TX Ethernet devices for network transmission. One SATAIII (6Gb/s) interface and one M.2 M-key offer storage devices. One […]
A reference kit for the Intel Cyclone 10 LP FPGA
https://www.electronics-lab.com/reference-kit-intel-cyclone-10-lp-fpga/
Together with Trenz Electronic GmbH, Arrow Electronics has developed a full-featured reference kit based on the low-cost and low-power Intel Cyclone10 LP FPGA family. The Cyclone 10 LP reference kit reduces time to market and development costs by enabling users to start work immediately with a end product qualified platform. The kit includes a 55kLE […]
RaspberryPi 4B is not working with your USB-C charger?
https://www.electronics-lab.com/raspberrypi-4b-not-working-usb-c-charger/
Tyler Ward shared detailed article about not working USB-C chargers with Raspberry Pi 4B. via time4ee.com The problem is in design of USB-C of Raspberry Pi. HW designers used only one pull-down resistor for both CCx pins. This solution is not complain with USB-C standard and in case you are using e-marked cable (what is […]
SnapEDA releases new optoelectronic products in collaboration with OSRAM
https://www.electronics-lab.com/snapeda-releases-new-optoelectronic-products-collaboration-osram/
New collaboration with Osram Opto Semiconductors helps PCB designers and electronic engineers design faster with free symbols and footprints SnapEDA, the Internet’s first and leading electronics design library, recently announced its collaboration with Osram Opto Semiconductors, a leading lighting and technology company, which allows engineers worldwide to quickly and effortlessly integrate Osram’s components in their […]
X-FAB Expands its 180nm BCD-on-SOI Technology Platform with New High-Voltage Devices
https://www.electronics-lab.com/x-fab-expands-180nm-bcd-soi-technology-platform-new-high-voltage-devices/
X-FAB Silicon Foundries SE, the leading analog/mixed-signal and specialty foundry today announced the availability of new high-voltage primitive devices targeted at the growing market for automotive 48V board net and battery management system (BMS) ICs. Covering voltages of 70V to 125V, these complementary NMOS/PMOS devices are based on the company’s XT018 BCD-on-SOI (https://www.xfab.com/en/technology/soi/018-um-xt018/) platform with […]
Ventana GW5910 Single Board Computer
https://www.electronics-lab.com/ventana-gw5910-single-board-computer/
A small 70x100mm SBC designed for IoT Gateway applications with two Mini-PCIe sockets, GbE, WiFi, Bluetooth and Sub-1GHz wireless The GW5910 is a member of the Gateworks Ventana family of single board computers and is targeted for low cost, high performance Internet of Things (IoT) Gateway Appliances. The GW5910 features the NXP i.MX6 Dual Core […]
ioNode – The Dooba development board
https://www.electronics-lab.com/ionode-dooba-development-board/
A microcontroller development board for all your needs Whether you’re just playing around on a breadboard or actively designing an end-user product, the ioNode makes building digital circuits a breeze. With its very small footprint, it can be used to build applications of any size with ease. Featuring the powerful ATMEGA1284P AVR microcontroller, you’ll have […]
