Multi Sensor Shield for Arduino Nano with Light, Magnetic Field & Temperature Sensor
https://www.electronics-lab.com/multi-sensor-shield-arduino-nano-light-magnetic-field-temperature-sensor/
This Arduino Nano Shield consists of a Light sensor, a Magnetic field sensor, and Temperature sensor. The shield can be used to develop various projects required light sensing, magnetic field sensing, and temperature sensing. All sensors provide analog voltage outputs, so each output is connected to analog inputs of Arduino Nano. Sensors OPT101 High Sensitive […]
https://www.electronics-lab.com/project/multi-sensor-shield-arduino-nano-light-magnetic-field-temperature-sensor/
USB 10-digit Seven Segment Display Module
https://www.electronics-lab.com/usb-10-digit-seven-segment-display-module/
by Dilshan R Jayakody:   This project is about an open-source, USB based, 10 digit seven segment display unit. This unit is specifically designed to work with POS systems and banking applications. Initially, this system is developed to work with PC based POS systems, and later it was modified to work with other applications. To […]
Ultra small quiescent current DC/DC converters for IoT and wearable devices
https://www.electronics-lab.com/ultra-small-quiescent-current-dc-dc-converters-iot-wearable-devices/
Ricoh Electronic Devices launched RP516 and RP517 series, buck (step-down) DC/DC converters featuring ultra-low output voltage (0.3 V to 1.2 V) and ultra-low quiescent current (typically 0.3 µA). The new converters are designed for IoT systems. As the IoT market expands, IoT devices with sensors, MCUs, communication ICs, etc. are required to correspond to low voltage to prolong […]
NixieTherm RGB – Nixie Tube Thermometer
https://www.electronics-lab.com/nixietherm-rgb-nixie-tube-thermometer/
NixieTherm RGB, an IN-13 tube indoor thermometer (DIY kit or assembled) with build-in true RGB controller; powered by 5V USB A Russian Bargraph-Nixie-tube shows similar like in the good old time a mercury thermometer the room-temperature with a variable glow hight lenght; however with NixieTherm RGB you have a wonderful red-orange glow. At the same […]
IBASE Releases Mini-ITX Motherboard Powered by 9th/8th Gen Intel Processors
https://www.electronics-lab.com/ibase-releases-mini-itx-motherboard-powered-9th-8th-gen-intel-processors/
iBASE Technology, a manufacturer of application specific industrial embedded computing platforms, has released the MI998 Mini-ITX motherboard supporting 9th/8th Gen Intel® Xeon® E / Core™ / Pentium® / Celeron® processors with a maximum of 4.7GHz frequency with Intel® Turbo Boost Technology. Equipped with the Intel C246/Q370/H310 chipset, this cutting-edge platform offers the required trusted performance […]
https://www.electronics-lab.com/project/usb-seven-segment-display-module/
This project is about an open-source, USB based, 10 digit seven segment display unit. This unit is specifically designed to work with POS systems and banking applications. Initially, this system is developed to work with PC based POS systems, and later it was modified to work with other applications. To simplify the communication interface this […]
SAMD21 MINI / Wemos D1 SAMD21 M0 Mini Development Board
https://www.electronics-lab.com/samd21-mini-wemos-d1-samd21-m0-mini-development-board/
Microchip / Atmel SAMD21 Arm Cortex-M0+ microcontroller has been around for several years and we have wrote for many boards using this microcontroller including the SAMD21 Lora Board and Minimal ATSAMD21 Board. Now, another SAMD21 development board has been shown up on Electrodragon website: the SAMD21 Mini Development Board which is sold for $14.50 on […]
ICE Tower CPU Cooling Fan for Raspberry Pi 4
https://www.electronics-lab.com/ice-tower-cpu-cooling-fan-raspberry-pi-4/
Meet this super ICE Tower CPU Cooling Fan for Raspberry Pi! Tower structure, 5mm copper tube, multi-layer heat sinks, 7 blades powerful fan, all the above combinations make this super radiator for Raspberry Pi. In the case of overclocking, it can reduce the temperature of the Raspberry Pi from 80℃ to 40℃. What amazing! Best […]
IC Locker – Online inventory for your IC components.
https://www.electronics-lab.com/ic-locker-online-inventory-ic-components/
IC Locker is an online Inventory management Software that seems to be online for a couple of years but we just found it. It also seems being on an early stage. To create your own parts database you have to create an account and you are ready to add your first components. All is free. […]
