ANAVI Gas Detector – An ESP8266-powered air quality monitor
https://www.electronics-lab.com/anavi-gas-detector-esp8266-powered-air-quality-monitor/
ANAVI Gas Detector is an ESP8266-powered, open source, Wi-Fi dev board for monitoring air quality and detecting dangerous gases. ANAVI Gas Detector is an ESP8266-powered, open source, Wi-Fi dev board for monitoring air quality and detecting dangerous gases. It supports popular analog MQ gas sensor modules such as MQ-135, MQ-2, MQ-3, etc. Furthermore, it comes […]
ERASynth Micro – An Open Source RF Signal Generator
https://www.electronics-lab.com/erasynth-micro-open-source-rf-signal-generator/
ERASynth Micro is a USB-Powered, Low Priced, Open Source RF Signal Generator, by ERA Instruments. ERASynth Micro is an open source signal generator with impressive features. Everyone can afford it, including makers, hackers, students, ham radio and SDR users. ERASynth Micro can be powered from a USB port and features an LCD interface for standalone […]
Using two tri-axis accelerometers for rotational measurements
https://www.electronics-lab.com/using-two-tri-axis-accelerometers-rotational-measurements/
App note from Kionix on utilizing 2 linear accelerometers to determine angular rotational rates. In many applications, customers would like to measure rotational motions (angular velocity, angular acceleration) in addition to linear motions. Most often, gyroscopes are added to their end product to obtain the rotational information. In some instances, customers already have a system […]
Using ESP32’s Flash Memory for data storage
https://www.electronics-lab.com/using-esp32s-flash-memory-data-storage/
The ESP32 has about 4MB of internal flash memory and since the data stored within the flash memory is retained even when power is recycled, it becomes super useful for applications where you need to keep certain amount of data even after power off. For today’s tutorial, we will learn how to read and write […]
https://www.electronics-lab.com/project/using-esp32s-flash-memory-for-data-storage/
Teledyne LeCroy T3DMM Series – Digital Multimeters
https://www.electronics-lab.com/teledyne-lecroy-t3dmm-series-digital-multimeters/
Teledyne Test Tools new T3DMM series are dual display digital desktop multimeters that provide a rich and powerful feature set. The design is easy-to-use from the front-panel and computer-based control via USB or LAN. Each model is equipped with a 4.3 inch TFT-LCD true color screen with 480 * 272 resolution for easy viewing. The […]
Arduino Introduces 4x new Nano boards
https://www.electronics-lab.com/arduino-introduces-4x-new-nano-boards/
Arduino has begun pre-orders for four new 45 x 18mm Nano form-factor boards. They include a $10 “Arduino Nano Every” model, a faster “WiFi/BT-enabled IoT” model, and two BLE boards. The Arduino Nano Every Substitutes the ATmega328P-based Arduino Uno-like Nano 3, equipped with ATMega4809, which is more powerful, and energy-efficient, and previously present in Arduino […]
ATTO – The World’s Smallest Arduino Compatible Board
https://www.electronics-lab.com/atto-worlds-smallest-arduino-compatible-board/
Atto is the world’s smallest Arduino compatible board! It is based on the ATmega32U4 microcontroller and comes with reset push-button as well as an RGB (rainbow) LED controlled by 3 PWM channels. The new Arduino board is 10.3 mm x 11.5 mm (0.40” x 0.45”) and it has an onboard reset button as well as […]
5900ppi full HD 0.37” LCoS micro-display measures 23.4×8.65mm
https://www.electronics-lab.com/5900ppi-full-hd-0-37-lcos-micro-display-measures-23-4x8-65mm/
AR and VR display manufacturer Raon-Tech has developed a 0.37-inch diagonal full HD (1920×1080) LCoS micro-display (Liquid Crystal on Silicon) aimed at single panel optical display systems such as HMD (Head Mounted Display), HUD (Head-Up Display), and pico projectors. [via www.eenewsled.com] Embedding an RGB LED driver, a low voltage differential signal receiver and power-down detection […]
RasPi Arcade Stick – the smart arcade control by TALENTEC
https://www.electronics-lab.com/raspi-arcade-stick-smart-arcade-control-talentec/
TALENTEC is a Spanish company whose goal is to improve the arcade game experience for players and facilitate this type of entertainment for everyone. To fulfil this premise, they have been working to develop a new concept for the arcade sticks, a smart arcade stick: the RasPi Arcade Stick. In order to check the reception […]
