2.4GHz Digital Voice and Data Transceiver achieve 12km range
https://www.electronics-lab.com/2-4ghz-digital-voice-data-transceiver-achieve-12km-range/
The SCT2400 operates in the 2.4GHz ISM band and offers a comprehensive solution supporting near global usage without the need for complex licensing. Capable of replacing unlicensed PMR/LMR solutions (FRS/MURS/GMRS/PMR446), the SCT2400 offers a rich set of features supporting not only secure digital voice operation but also wireless data capabilities. The SCT2400 also offers superior […]
Arduino SIM unveiled
https://www.electronics-lab.com/arduino-sim-unveiled/
Arduino has launched Arduino SIM, which is a SIM-only service exclusively for IoT (internet of things) devices based on the Arduino platform. It provides developers and manufacturers cellular access to the Arduino IoT Cloud platform from over 100 countries with a single data plan and competitive pricing. [via www.mwee.com] Arduino SIM aims to provide the […]
Inductive Proximity Sensor using TCA505
https://www.electronics-lab.com/inductive-proximity-sensor-using-tca505/
The circuit published here is an Inductive Proximity Sensor, which is used for non-contact detection of metallic objects. The circuit can be used for the detection of metal objects or as positioning sensor. The TCA505 is used to design inductive proximity switche which can detect metal object from 5-10mm range. The resonant circuit of the […]
https://www.electronics-lab.com/project/inductive-proximity-sensor-using-tca505/
The circuit published here is an Inductive Proximity Sensor, which is used for non-contact detection of metallic objects. The circuit can be used for the detection of metal objects or as a positioning sensor. The TCA505 is used to design an inductive proximity switch that can detect a metal object from 5-10mm range. The resonant […]
EPIC-KBS9-PUC: Proven Performance for your Embedded Application
https://www.electronics-lab.com/epic-kbs9-puc-proven-performance-embedded-application/
AAEON, an industry leader in embedded computing systems, announces the EPIC-KBS9-PUC barebones embedded system. Built upon our success and knowledge, the EPIC-KBS9-PUC offers the power of 6th and 7th Generation Intel Core Processors, four Gigabit Ethernet ports, and a range of expandability and customization to support your application. The EPIC-KBS9-PUC is a barebones system based […]
Experimental Next-Generation Chip-Scale Atomic Clock
https://www.electronics-lab.com/experimental-next-generation-chip-scale-atomic-clock/
Physicists at the National Institute of Standards and Technology (NIST) and partners have demonstrated an experimental, next-generation atomic clock—ticking at high “optical” frequencies—that is much smaller than usual, made of just three small chips plus supporting electronics and optics. Described in Optica, the chip-scale clock is based on the vibrations, or “ticks,” of rubidium atoms […]
Espressif Announces the Release of ESP32-S2 Secure Wi-Fi MCU
https://www.electronics-lab.com/espressif-announces-%e2%80%a8release-esp32-s2-secure-wi-fi-mcu/
Espressif announces the release of the ESP32-S2 Secure Wi-Fi MCU, which is a highly integrated, low-power, 2.4 GHz Wi-Fi Microcontroller SoC supporting Wi-Fi HT40 and 43 GPIOs. Based on Xtensa® single-core 32-bit LX7 processor, ESP32-S2 can be clocked at up to 240 MHz. ESP32-S2 is a highly integrated, low-power, 2.4 GHz Wi-Fi Microcontroller SoC supporting […]
DC slotless motor runs at up to 40,000 rpm
https://www.electronics-lab.com/dc-slotless-motor-runs-at-up-to-40000-rpm/
Portescap has expanded its Ultra EC range of brushless DC slotless motors with the introduction of a ultra-high speed 2 pole motor, the 35ECS. The 35mm diameter slotless motor draws up to 330W max imum in continuous operation and sustains speeds up to 40,000 rpm. The new design comes in two lengths: the 35ECS60 at […]
Small form factor board has computing power for medical and IoT
https://www.electronics-lab.com/small-form-factor-board-computing-power-medical-iot/
Populated with the Intel Core i5 7300U and i3 7100U processors, the WUX-7x00U is a small form factor (SFF) embedded board by Portwell. The processors, formerly codenamed Kaby Lake, integrate the low power Intel Gen. 9.5 HD Graphics, 620 graphics engine with 24 execution units, enabling enhanced 3D graphics performance and higher speed for 4K […]
Using the BLE functionality of the ESP32
https://www.electronics-lab.com/using-ble-functionality-esp32/
One of the most beautiful features which the ESP32 has over the ESP-12e is the fact that, asides the WiFi, it has two other communication modules onboard. The ESP32 comes with an onboard Classic Bluetooth and Bluetooth Low Energy modules. For today’s tutorial, we will explore how the Bluetooth Low Energy Module onboard the ESP-32 […]
