USB to +/-5V Voltage DC-DC switching Converter
https://www.electronics-lab.com/project/usb-to-5v-negative-voltage-dc-dc-switching-converter/
Now days USB power source is very common and available in many devices and power banks. This DC-DC converter provide -5V negative voltage from +5V USB power source. This converter can be used in a wide range of industrial automation control equipment, sensors, isolated operational amplifiers and test & measurement equipment that require bipolar supply […]
Using Interrupts with Arduino
https://www.electronics-lab.com/using-interrupts-arduino/
We can say that an Interrupt is an automatic transfer of software execution in response to a hardware event that is asynchronous with the current software execution. As it’s name says, interrupts, “interrupt” the normal program flow to perform an action (run another code block, function, etc.) and return back to the normal program flow […]
0.8μm smartphone image sensor packs 64 megapixels
https://www.electronics-lab.com/0-8%ce%bcm-smartphone-image-sensor-packs-64-megapixels/
Samsung has expanded its 0.8μm pixel image sensor lineup with the 64-megapixel Isocell Bright GW1 and the 48Mp Isocell Bright GM2. Isocell Bright GW1 is a 64Mp image sensor that features the highest resolution in Samsung’s 0.8μm-pixel image sensor lineup. With pixel-merging Tetracell technology and remosaic algorithm, GW1 can produce bright 16Mp images in low-light […]
Arduino Menu Tutorial with a Rotary Encoder and a Nokia 5110 LCD display
https://www.electronics-lab.com/arduino-menu-tutorial-rotary-encoder-nokia-5110-lcd-display/
In our last tutorial, we examined how to create a menu for your Arduino project on a Nokia 5110 LCD, with push buttons to navigate through it. In today’s tutorial will build a modified version of it as we will use a rotary encoder (in place of the push buttons) for menu navigation. A rotary […]
Menu on Nokia 5110 LCD display with Arduino
https://www.electronics-lab.com/menu-on-nokia-5110-lcd-display-with-arduino/
We have published quite a number of tutorials using different displays with the Arduino, with the most recent being the tutorial on displaying graphics on all kind of displays with Arduino. For today’s tutorial, we will look into achieving more with displays by implementing a menu based system with the Nokia 5110 LCD display and […]
https://www.electronics-lab.com/project/arduino-menu-tutorial-with-a-rotary-encoder-and-a-nokia-5110-lcd-display/
In our last tutorial, we examined how to create a menu for your Arduino project on a Nokia 5110 LCD, with push buttons to navigate through it. In today’s tutorial, we will build a modified version of it which will make use a rotary encoder (in place of the push buttons) for menu navigation. A […]
How to isolate RS485 – smaller size and high reliability
https://www.electronics-lab.com/isolate-rs485-smaller-size-high-reliability/
Galvanic isolation for the RS-485port. RS-485 has been the industry’s most used wired communications interface for more than decades. Balanced differential signaling of RS-485 allows for rejection of common mode noise and facilitates communications over long distances in noisy industrial environments. RS-485 is a common communications port in most industrial applications such as factory automation, […]
5″ 800×480 HDMI TFT Display with Backlight Control for Raspberry Pi
https://www.electronics-lab.com/5-800x480-hdmi-tft-display-backlight-control-raspberry-pi/
Elecrow has just launched a new 5″ HDMI display with resistive touch screen designed for the Raspberry Pi boards, and whose main feature is to support backlight control over GPIO 11 in order to lower power consumption. This is a 5 inch mini HDMI touch screen for Raspberry Pi, with high resolution that will provide […]
Seeed Studio unveils Three W600-Based Wireless Boards
https://www.electronics-lab.com/seeed-studio-unveils-three-w600-based-wireless-boards/
Seeed Studio launched its Air 602 module in October last year and it was the first ESP competitor that retailed cheaper than the Espressif ESP8266 and ESP32 modules. Due to the lack of FCC certification for the Air 602 modules, integrating the module into a product seemed problematic. However, Seeed Studio announced early this year […]
Newport GW6100 Networking Single Board Computer
https://www.electronics-lab.com/newport-gw6100-networking-single-board-computer/
A Miniature 35x100mm Single Board Computer for Networking with Mini-PCIe Socket, Gigabit Ethernet Port, and USB Type-C TM 2.0 Port. The GW6100 is the smallest member of the Gateworks 6th generation Newport family of single board computers targeted for a wide range of indoor and outdoor networking applications. The GW6100 features the Cavium OcetonTX™ Dual […]
