Read the Design Engineer’s Guide to Pressure Sensors from Avnet
https://www.electronics-lab.com/read-design-engineers-guide-pressure-sensors-avnet/
The advent of smaller, lower-cost and lower-powered pressure sensors has generated a new wave of innovation, increasing efficiency and performance both in the sensors themselves and their applications. The worldwide pressure sensor market is set to grow to $11.4 billion by 2024, as demand for these technologies increases. Selecting the right sensor technology for your […]
Getting Started with ESP32
https://www.electronics-lab.com/getting-started-esp32/
Over the last few articles, we have covered the use of ESP8266 boards for building several WiFi based projects. For today’s tutorial, we will look at it’s recently released successor; the ESP32. As mentioned in previous tutorials, ESP-12e module popularly referred as the nodeMCU came at a time where makers were struggling with the difficulties […]
https://www.electronics-lab.com/project/getting-started-esp32/
16 x 2 LCD controlled via power line
https://www.electronics-lab.com/16-x-2-lcd-controlled-via-power-line/
Vinod blogged about a 16×2 LCD with data over power line: Then I just thought why even 1 wire for data? Because we can easily multiplex the 1 wire data line with the Vcc line by keeping a diode + capacitor combination towards the LCD power supply pin. I am using an arduino board to do […]
Sony Releases 0.5″ OLED Microdisplay with 1600 x 1200 resolution
https://www.electronics-lab.com/sony-releases-0-5-oled-microdisplay-with1600-x-1200-resolution/
Sony Corporation today announced the upcoming release of the ECX339A OLED Microdisplay featuring UXGA (1600 x 1200 resolution), the highest in class for a 0.5-type. This product achieves the world’s smallest pixel pitch of 6.3μm by leveraging Sony’s OLED display technology and miniaturization technology, enabling a resolution 1.6x higher than the previous model1. By employing […]
Multi-Gas, Humidity and Temperature Module for Air Purifiers and HVAC Applications
https://www.electronics-lab.com/multi-gas-humidity-temperature-module-air-purifiers-hvac-applications/
The solution for gas, humidity and temperature sensing remotely from the main control board is now available worldwide through Sensirion’s distribution network. Sensirion, the expert in environmental sensing, now offers a multi-gas, humidity and temperature module, the SVM30. The module facilitates product development and sensor integration while at the same time offering great flexibility for […]
Micron’s 11TB NVMe SSDs now at Mouser
https://www.electronics-lab.com/microns-11tb-nvme-ssds-now-mouser/
Micron 9200 NVMe™ Solid State Drives (SSDs) comes under Micron’s flagship performance product line and the second generation of NVMe drives. These SSDs utilize Gen3 PCIe interface, innovative non-volatile memory express protocol, and Micron’s high-speed NAND to provide high-throughput and IOPS, low-latency, and consistent quality of service. The 9200 SSDs are available in high-capacities up […]
Banana Pi Pro SBC features ARM Cortex-A7 Dual-Core CPU
https://www.electronics-lab.com/banana-pi-pro-sbc-features-arm-cortex-a7-dual-core-cpu/
The Banana Pi Pro Computer Board comes with ARM Cortex-A7 Dual-Core CPU @ 1.0GHz. It supports multi-channel HD display. It has on board WiFi network of 802.11 b/g/n and parallel 8-bit camera interface. Banana Pro™ is an updated version of Banana Pi™ designed by the LeMaker Team. Try Banana Pro™ today and take advantage of […]
TinyPICO – A tiny, mighty ESP32 development board
https://www.electronics-lab.com/tinypico-tiny-mighty-esp32-development-board/
TinyPICO is the world’s smallest, fully featured ESP32 development board, designed to give access to the power of the ESP32’s dual core 240 MHz and internet connectivity, in a package smaller than your thumb! The designers of the board wasn’t satisfied with the existing ESP32 boards that compromised some of it’s features, so they decided […]
AMD FS-FP5R 5×5 – Development board with triple DP++ ports runs on Ryzen R1000
https://www.electronics-lab.com/amd-fs-fp5r-5x5-development-board-triple-dp-ports-runs-ryzen-r1000/
The new SAPPHIRE FS-FP5R 5”x 5” small form factor embedded motherboard is based on the latest AMD Ryzen™ Embedded R-Series Family APUs which features the industry leading Vega GPU graphics combined with the dual-core high-performance “Zen” CPU. Three 4K displays can be supported in addition to dual-channel DDR4-2400 memory, dual Ethernet controllers, and M.2 for […]
