Vishay’s new VCNL4040 fully integrated proximity and ambient light sensor
https://www.electronics-lab.com/vishays-new-vcnl4040-fully-integrated-proximity-ambient-light-sensor/
Features Filtron™ technology; three-in-one design combines IR emitter, photo detectors, signal processing IC, 16-bit ADC    Vishay’s new VCNL4040 fully integrated proximity and ambient light sensor is now available from TTI, Inc., a world leading specialist distributor of electronic components. Featuring Filtron™ technology, the VCNL4040 combines an IR emitter, photo detectors for proximity and ambient light, […]
Dual-Channel, 42 V, 4 A Monolithic Synchronous Step-Down Silent Switcher 2
https://www.electronics-lab.com/dual-channel-42-v-4-monolithic-synchronous-step-silent-switcher-2/
The LT8650S 42 V, dual-channel, 4 A synchronous Silent Switcher® 2 regulator features a wide input voltage range of 3 V to 42 V, ideal for automotive, industrial, and other step-down applications. Its quiescent current is only 6.2 µA with the outputs in regulation – a critical feature in automotive environments where always-on systems can drain the battery even […]
Arbor’s “EmQ-RK390” Qseven module runs Linux or Android on a Rockchip RK3399
https://www.electronics-lab.com/arbors-emq-rk390-qseven-module-runs-linux-android-rockchip-rk3399/
ARBOR Technology, a leading provider of embedded computing solutions, which featured this year on concluded Embedded World 2019 Exhibition that took place in Nuremberg, Germany has launched the EmQ-RK390 Qseven module which is based on the RK3399-based SoC. The Qseven concept is an off-the-shelf, multi-vendor, Computer-On-Module that integrates all the core components of a standard […]
Giant Board – A single-board computer in the Adafruit Feather form factor
https://www.electronics-lab.com/giant-board-single-board-computer-adafruit-feather-form-factor/
Giant Board is an Open Source, Linux-capable SBC Compatible with the Featherwing Ecosystem. The Giant Board will come with over 100 CircuitPython libraries pre-installed and support many popular FeatherWings. Linux drivers interface directly with the Ethernet and LCD FeatherWings, and they can be easily enabled or disabled via a simple text file. Most FeatherWings will […]
USB Stack Light Controller based on PIC16F1459
https://www.electronics-lab.com/usb-stack-light-controller-based-pic16f1459/
Glen Akins build a USB Stack Light Controller based on PIC16F1459 and documents the process on this personal blog. He writes: After using the PIC16F1459 to build numerous USB HID input devices including a giant keyboard, a tiny keyboard, and a big red button, it was time to see if the PIC16F1459 could be used […]
AMD expands Embedded Product Family with New Ryzen™ Embedded R1000
https://www.electronics-lab.com/amd-expands-embedded-product-family-new-ryzen-embedded-r1000/
The AMD Ryzen™ Embedded R1000 SoC provides a new class of performance for the embedded industry with 3X performance per watt vs. previous AMD R-Series SoC1 and 4X performance per dollar compared to the competition. At the Taiwan Embedded Forum, AMD announced the Ryzen™ embedded product family is growing with the new AMD Ryzen™ Embedded […]
MAX16126/MAX16127 – protect power-supply inputs from automotive voltage transients
https://www.electronics-lab.com/max16126-max16127-protect-power-supply-inputs-automotive-voltage-transients/
MAX16126/MAX16127 – protect power-supply inputs from automotive voltage transients, including load dump The MAX16126/MAX16127 load-dump/reverse-voltage protection circuits protect power supplies from damaging input voltage conditions, including overvoltage, reverse-voltage, and high-voltage transient pulses. Using a built-in charge pump, the devices control two external back-to-back n-channel MOSFETs that turn off and isolate downstream power supplies during damaging […]
Western Digital PC SA530 3D NAND SATA SSD
https://www.electronics-lab.com/western-digital-pc-sa530-3d-nand-sata-ssd/
Up to 1TB capacity for exceptional storage options for a broad range of computing applications High performance and high capacity for computing The Western Digital PC SA530 combines Western Digital’s state-of-the-art 96-layer 3D NAND technology with the proven SSD platform. It also incorporates nCache™ 2.0, a tiered caching technology designed to improve responsiveness for corporate […]
15A 100V Isolated Half-Bridge Driver
https://www.electronics-lab.com/15a-100v-isolated-half-bridge-driver/
15 A 100V Isolated Half bridge driver project intended to be used for DC-DC converters, inverters, LED driver and motor driver applications. This projects is really helpful in industrial applications where noise is a concern since project provides optical isolation between microcontroller and high current output. ADuM4224 isolated precision Half-Bridge driver is the heart of […]
Programmable USB Hub will soon launch on Crowdsupply
https://www.electronics-lab.com/programmable-usb-hub-will-soon-launch-crowdsupply/
A USB hub that’s also a dev board and an I2C, GPIO, and SPI bridge. In addition to being a 4-port USB 2 High-Speed hub, this Programmable USB hub is also: A CircuitPython based development board. A bridge between your computer and I2C (via Sparkfun Qwiic connectors), GPIO, and SPI (via its mikroBUS header). A […]
