20×4 I2C Character LCD display with Arduino Uno
https://www.electronics-lab.com/20x4-i2c-character-lcd-display-arduino-uno/
Our friends on educ8s.tv published a new video! Check it out. Hello guys, I am Nick and welcome to educ8s.tv a channel that is all about DIY electronics projects with Arduino, Raspberry Pi, ESP8266 and other popular boards. Subscribe to the channel now if you don’t want to miss any future videos. In this video […]
4 Wheel Robot Motor Driver ( 4X 3Amps LMD18201 H-Bridge)
https://www.electronics-lab.com/4-wheel-robot-motor-driver-4x-3amps-lmd18201-h-bridge/
This compact board will help you to drive 4 Wheel Drive Robots, each axis can handle a load current up to 3 Amps and supply 12V – 48 V DC. Board requires two PWM and Dir. signals for full 4WD operations, mainly differential steering for taking turns left or right or complete 360 degree rotation. […]
https://www.electronics-lab.com/project/4-wheel-robot-motor-driver-4x-3amps-lmd18201-h-bridge/
Multi-brightness LED controller draws zero off-current
https://www.electronics-lab.com/multi-brightness-led-controller-draws-zero-off-current/
T A Babu @ edn.com has a design idea of a led controller with some nice features: The key features of this Design Idea are: Soft switch on/off operation Zero current drain in sleep mode Two level dimming Low battery protection Simple controller based on CMOS 4017 Johnson counter Multi-brightness LED controller draws zero off-current […]
Accelerometers for vibration measurements & wireless condition monitoring
https://www.electronics-lab.com/accelerometers-vibration-measurements-wireless-condition-monitoring/
Graham Prophet @ eedesignnewseurope.com discuss about two new MEMS accelerometers from Analog Devices: Analog Devices (ADI) has added two devices to its low noise, low drift, low power, three-axis MEMS accelerometers. The low noise performance over high frequencies provided by the ADXL356 and ADXL357 MEMS accelerometers delivers high resolution vibration measurements that enable the early […]
Open Source UV Index Detector
https://www.electronics-lab.com/open-source-uv-index-detector/
Boris Landoni @ open-electronics.org documents his UV index detector. It measures solar radiation and visualizes the corresponding value on the integrated display of a miniaturized Arduino, in order to tell us when to expose ourselves to the sun… Open Source UV Index Detector – [Link]
SEPIC/Ćuk converter sprouts second output
https://www.electronics-lab.com/sepiccuk-converter-sprouts-second-output/
by Gheorghe Plasoianu @ edn.com Many applications require positive and negative supply voltages, with only one voltage requiring tight regulation. This Design Idea describes a dual-output, hybrid SEPIC–Ćuk converter whose positive output voltage can be lesser or greater than the input voltage. The unregulated negative output is a mirrored replica of the positive output. SEPIC/Ćuk […]
Reverse engineering the 76477 sound effect chip
https://www.electronics-lab.com/reverse-engineering-76477-sound-effect-chip/
Ken Shirriff has written an article on reverse engineering the 76477 “Space Invaders” sound effect chip: Remember the old video game Space Invaders? Some of its sound effects were provided by a chip called the 76477 Complex Sound Generation chip. While the sound effects1 produced by this 1978 chip seem primitive today, it was used […]
Free PADS PCB packages from Mentor/Digi-Key
https://www.electronics-lab.com/free-pads-pcb-packages-mentordigi-key/
by Graham Prophet @ eedesignnewseurope.com: Two versions of the PADS software package (by Mentor, now a Siemens business) have been made available through distributor Digi-Key. Positioned as design software for “the aspiring innovator” both the free and the $499 versions include access to parts libraries and to a circuit simulator. Free PADS PCB packages from […]
Embedded vision development kit targets mobile & ‘edge’ applications
https://www.electronics-lab.com/embedded-vision-development-kit-targets-mobile-edge-applications/
by Graham Prophet @ eedesignnewseurope.com: Lattice Semiconductor positions its Embedded Vision Development Kit as the first of its type, that is optimized for mobile-influenced system designs that require flexible, low cost, and low power image processing architectures, by which the company refers to Robotics, Drones, ADAS, smart surveillance and AR/VR systems Embedded vision development kit […]
