Shuttle NT10H Series Mini PC with Intel Core Ultra, Arc GPU, AI Boost NPU, Quad 4K Display, and Barebone Option
The Shuttle NT10H mini PC features Intel Core Ultra CPUs with Arc GPU, AI Boost NPU (34 TOPS), 4×4K display support, USB4, dual 2.5GbE, PCIe 4.0, and up to 16 cores/22 threads.
XPC nano NT10H series mini PC
The Shuttle NT10H is a compact NUC-style mini PC from the XPC nano lineup, designed for multitasking and demanding workloads. It is powered by Intel Core Ultra processors with integrated Intel Arc GPU and AI Boost NPU, delivering up to 34 TOPS of AI performance and supporting up to four 4K displays.
The system offers flexible connectivity with USB4, multiple USB 3.2 Gen2 and USB 2.0 ports, two USB4 Type-C connections with power delivery and video output, dual 2.5GbE Intel LAN ports (Realtek controllers), and a PCIe 4.0 SSD slot. It also supports customizable TDP values ranging from 28W to 45W.
Available with Intel Ultra 5 125H, Ultra 7 155H, or Ultra 9 185H CPUs, the NT10H provides up to 16 cores and 22 threads, making it suitable for applications requiring parallel processing and balanced power efficiency. Its performance and features make it a strong option for computer vision, AI inference, image processing, and multimedia content creation.
XPC nano NT10H series mini PC internal view
XPC nano NT10H series mini PC specifications:
  • CPU:
    • Intel Core Ultra 5 Meteor Lake 125H (TDP28W); 14C/18T (4P+8E+2LP-E), (Up to 4.5 GHz); 18 MB Intel Smart Cache, 20W – 115W TDP, Intel Arc Graphics (up to 2.2 GHz), 7 Xe-cores
    • Intel Core Ultra 7 Meteor Lake 155H (TDP28W); 16C/22T (6P+8E+2LP-E), (Up to 4.8 GHz); 24 MB Intel Smart Cache, 28W – 115W TDP, Intel Arc Graphics (up to 2.25 GHz), 8 Xe-cores
    • Intel Core Ultra 9 Meteor Lake 185H (TDP45W); 16C/22T (6P+8E+2LP-E), (Up to 5.1 GHz); 24 MB Intel Smart Cache, 35W – 115W TDP, Intel Arc Graphics (up to 2.35 GHz), 8 Xe-cores
  • Storage:
    • 1x M.2 (Key M, 2280) PCIe Gen4x4 SSD slot
    • 1x M.2 (Key E, 2230) PCIe slot for optional Wi-Fi 5 or Wi-Fi 6
    • MicroSD Card Reader slot
  • System Memory: 2x 262-pin SO-DIMM socket for Dual-channel DDR5/5600MHz up to 96GB RAM (48GB per DIMM)
  • Video Output: 2x HDMI Port + 2x TYPE-C DisplayPort quadruple video outputs
  • Audio: Realtek ALC269-VC3 HD codec | 1x 3.5mm Audio jack (headphone & microphone combo)
  • Networking:
    • 2.5GbE RealTek RLT8125B Dual Gigabit Ethernet RJ45 port (10/100/1000/2500Mbps)
    • Optional Wi-Fi 5 or Wi-Fi 6 via M.2 2230 module
  • USB:
    • 4x USB 3.2 Gen2 (Type-A) [Front Panel] and 1x USB 3.2 Gen2 (Type-A) [Back Panel]
    • 2x USB 4.0 Type-C (supports DisplayPort 1.4 / Power Delivery [5V/3A])
    • 1x USB 2.0
  • Expansion:
  • Misc:
    • Power button
    • Power LED
  • Power Supply:
    • Core Ultra 5: 90W (19V/2.37A)
    • Core Ultra 7: 120W (19V)
    • AC input: 100~240V, 50~60Hz
  • Security:
    • Kensington Lock Slot
    • Intel PTT (TPM 2.0): integrated TPM functionality without dedicated chip
  • Operating Temperature: 0℃~40℃
  • Dimensions: 132(W) x 143(D) x 55(H) mm (57.8mm include rubber + Shuttle 1.0L Form Factor)
  • Certifications: FCC, CE, BSMI, RCM, VCCI, UKCA, CB, UL, BSMI, CEC, RoHS
XPC nano NT10H series mini PC Front and Back Panel specifications
The NT10H supports Windows 11 and various Linux distributions. It is certified for FCC, CE, RoHS, and more. The system is VESA mount compatible (100 x 100 mm) and features a heat pipe with a fan-based cooling solution.
XPC nano NT10H series mini PC - all side view
XPC nano NT10H series mini PC – all side view
The Shuttle XPC nano NT10H mini PC is already available for ordering, although the model with the Core Ultra 7 is not available as of publication. The Shuttle XPC nano barebone NT10H5, which comes with the Core Ultra 5, 8 GB DDR5 SO-DIMM, no OS installed, no M.2 SSD, and an Intel AX200 Wi-Fi 6/Bluetooth module, is listed at €830.00 (excluding VAT).
Images used courtesy of Shuttle.
