Sipeed SLogic32U3 – A 10 Gbps USB 3.2 Logic Analyzer
Built around a 10 Gbps USB 3.2 Gen 2 interface, this 32-channel instrument offers 350 MHz digital bandwidth, optional 8-bit ADC modules, and browser-based capture.
Sipeed has introduced the SLogic32U3, a third-generation, 32-channel USB 3.2 Gen 2 logic analyzer that streams continuous high-speed captures directly to a host PC without device-side buffer limits. Following the earlier SLogic Combo8 and SLogic16U3 models, this device integrates an in-house 10 Gbps FPGA IP and an onboard 2 Gbit (256 MB) DDR3 elastic buffer to sustain real-world streaming throughput up to 800 MB/s (6.4 Gbps).
The logic analyzer supports up to 1.4 GS/s sampling with four channels, 350 MHz digital bandwidth, and an optional four-channel ADC module for analog measurements. It also features adjustable voltage thresholds, shielded coaxial probes, support for over 150 protocols, and browser-based software with AI-assisted debugging capabilities.
SLogic32U3 logic analyzer connected to a Raspberry Pi for high-speed signal capture or protocol debugging
Sipeed SLogic32U3 specifications:
  • Hardware – FPGA-based design (FPGA model not disclosed)
  • Input channels – 32 digital channels through 4x mini HDMI connectors, 8 channels per connector
  • Sampling rates
    • 1,400 MS/s @ 4 channels
    • 800 MS/s @ 8 channels
    • 400 MS/s @ 16 channels
    • 200 MS/s @ 32 channels
  • Digital signal bandwidth – Up to 350 MHz
  • Memory – 2 Gbit (256 MB) DDR3 streaming buffer
  • Capture mode – Continuous streaming to host memory or storage, with capture depth limited by available host resources
  • Input voltage – 0–10 V
  • Adjustable voltage threshold – 0–6 V in 0.1 V steps
  • Input impedance – 100 kΩ (digital)
  • Triggering – Multi-channel and multi-edge triggering through supported host software
  • Optional ADC module
    • 4 analog channels
    • 8-bit resolution
    • 100 MS/s sampling rate
    • 10 MHz analog bandwidth
    • ±15 V safe input range
    • Simultaneous analog and digital capture using different channel groups
  • Supported protocols – Over 150, including SPI, I²C, UART, CAN, JTAG, SDIO, and Modbus
  • USB – 1x USB 3.2 Gen2 Type-C port (10 Gbps link speed, up to 800 MB/s sustained streaming)
  • Misc
    • 4x mini HDMI connectors for signal inputs
    • 15 cm shielded coaxial probe cables with PTFE jumper wires
    • 100 MHz fixed clock output
    • ACT status LED and recessed firmware-update button
  • Power supply – USB-powered
  • Dimensions – 59 × 51 × 13 mm
  • Enclosure – CNC-machined aluminum
SLogic32U3 uses a 10 Gbps USB 3.2 Gen 2 interface for high-speed data streaming to a host PC
Unlike conventional logic analyzers that store captured samples in a fixed internal buffer, the SLogic32U3 streams data directly to the host computer, allowing longer captures limited mainly by available RAM, storage capacity, and sustained write speed. The device can capture all 32 channels at 200 MS/s or increase the sampling rate to 1.4 GS/s when using four channels. However, reaching the maximum streaming rate requires a 10 Gbps USB connection; a 5 Gbps port reduces throughput, while USB 2.0 capture is unsupported.
SLogic32U3 features 32 digital channels organized into four independent 8-channel groups
The optional ADC module adds basic oscilloscope functionality with four 8-bit analog inputs operating at 100 MS/s. Each analog channel uses a corresponding group of eight digital inputs, while unused groups remain available for simultaneous digital capture. The included coaxial probe cables also help reduce interference and crosstalk when measuring high-speed signals.
In terms of software, the SLogic32U3 supports Windows 10/11, Linux, and macOS through Sipeed’s SLogicView software, along with ngscopeclient, sigrok-cli, and the community-developed ALL LOGIC application. The SLogicWeb interface lets you capture and decode signals directly in a Chromium-based browser without installing software, including on supported Android devices.
Sipeed has also released SLogic 2.3.3, which improves USB capture reliability and addresses interrupted transfers on busy host systems. The update adds an X-Y view and improved ADC handling in ngscopeclient, along with better support for multiple connected analyzers. You can perform firmware updates through a WebUSB-based update tool. For automated debugging, the SLogic software ecosystem provides a sigrok-cli plugin for AI agents, while the ALL LOGIC application includes a Model Context Protocol (MCP) interface for controlling capture and protocol decoding through compatible AI tools.
The SLogic32U3 is avilabe on Kickstarter, which launched on November 7, 2026, raising HK$2.77 million from 1,670 backers. The company has now opened preorders through its new online store, while its product comparison documentation lists a price of $149. More information, including hardware specifications and software instructions, is available on the Sipeed Wiki.
Images used courtesy of Kickstarter
