AI Antenna Recommendation Engine: Taoglas Accelerates Product Selection
The new AI-powered antenna product recommendation engine uses over 20 years of design data to filter suitable products in minutes, targeting both RF engineers and non-technical users.
Selecting the appropriate antenna for a wireless design has traditionally required extensive RF knowledge, manual comparison of datasheets, and considerable time investment. Engineers often spend hours or days evaluating parametric specifications across multiple vendors to identify suitable candidates for their applications. Taoglas has introduced an AI-driven antenna product recommendation engine designed to streamline this process.
The tool, which launched in February 2026, applies machine learning algorithms trained on more than two decades of antenna design data to filter and recommend products from Taoglas’ catalog of thousands of antenna variants. The system processes user input on application requirements and returns filtered results in minutes, rather than the hours typically required for manual searches.
With Taoglas’ AI Product Recommendation Engine, engineers can speed up antenna and RF component selection
With Taoglas’ AI Product Recommendation Engine, engineers can speed up antenna and RF component selection. Image used courtesy of Taoglas
AI-Powered Antenna Recommendation Engine
The AI Antenna Recommendation Engine draws on design knowledge accumulated from tens of thousands of deployed projects spanning multiple RF technologies. The AI model has been trained to understand trade-offs between parameters such as frequency bands, form factors, mounting methods, and environmental constraints that affect antenna performance in real-world applications.
According to David Connolly, Global Product Management Director at Taoglas, the system encodes expertise that has historically existed primarily in individual engineer experience. The tool processes queries for antennas across cellular, GNSS, Wi-Fi, Bluetooth, ISM, LoRA, UWB, and other wireless technologies, accounting for both embedded and external antenna configurations.
Taoglas’ recommendation engine combines decades of experience and data from tens of thousands of international projects. Video used courtesy of Taoglas
The platform handles queries from users with varying levels of RF expertise. For experienced hardware engineers, it accelerates the narrowing process when dealing with Taoglas’ extensive product line. For system designers less familiar with antenna trade-offs, the tool provides guided recommendations based on application-specific parameters.
Integration With AntennaXpert Ecosystem
The AI recommendation engine functions as part of Taoglas’ AntennaXpert digital toolset. This ecosystem includes the Antenna Builder for custom cable and connector configuration, the Cable Builder for RF cable assembly specification, and the Antenna Integrator for PCB placement analysis. The tools are designed to support the workflow from initial antenna selection through integration and testing.
Users can begin with the recommendation engine to identify candidate antennas, then proceed to the Antenna Builder to customize cables and connectors, and finally use the Antenna Integrator to evaluate placement within their specific PCB layout. The system aims to reduce iteration cycles during the development process by providing digital analysis before physical prototyping.
The AI Antenna Recommendation Engine expands Taoglas’ AntennaXpert tool suite
The AI Antenna Recommendation Engine expands Taoglas’ AntennaXpert tool suite. Image used courtesy of Taoglas
Antenna and RF Component Selection
Taoglas’ recommendation engine addresses common design scenarios where antenna selection becomes a bottleneck. In IoT device development, where size constraints and multi-band requirements complicate antenna choices, the tool can quickly filter options based on dimensional limits and frequency coverage. For automotive applications requiring specific environmental ratings and mounting configurations, the AI system can identify candidates meeting both RF performance and mechanical requirements.
The platform also supports early-stage product development when RF specifications may still be evolving. Engineers can perform multiple queries with varying parameters to understand available options and trade-offs before finalizing their system architecture. The tool is accessible at no cost and designed as a scalable platform that Taoglas plans to expand with additional RF components and enhanced recommendation capabilities over time.
