ASRock Industrial Unveils NUC(S) Ultra 200 and AMD 4X4 AI300 Series motherboard with Intel Core Ultra 200H (Arrow Lake-H) and AMD Ryzen AI 300 Processors
Following Intel and AMD's latest SoC announcements at CES 2025, ASRock Industrial introduced the NUC(S) Ultra 200 BOX and NUC Ultra 200 Motherboard Series, powered by Intel Core Ultra 200H Arrow Lake-H processors with up to 99 TOPS of AI inferencing power. The company also unveiled the 4X4 BOX AI300 and 4X4 AI300 Motherboard Series, featuring AMD Ryzen AI 300 processors with up to 50 TOPS of NPU performance.
ASROCK INDUSTRIAL PC and Motherboard
Following Intel and AMD’s latest SoC announcements at CES 2025, ASRock Industrial introduced the NUC(S) Ultra 200 BOX and NUC Ultra 200 Motherboard Series, powered by Intel Core Ultra 200H Arrow Lake-H processors with up to 99 TOPS of AI inferencing power. The company also unveiled the 4X4 BOX AI300 and 4X4 AI300 Motherboard Series, featuring AMD Ryzen AI 300 processors with up to 50 TOPS of NPU performance.
ASRock Industrial NUC(S) Ultra 200 BOX & NUC Ultra 200 Motherboard Series Features:
  • Processor:
    • Intel Core Ultra 7 255H (6P+8E) – Up to 5.1 GHz, 24MB cache, Intel Arc 140T GPU (74 TOPS), Intel AI Boost (13 TOPS), 28W PBP
    • Intel Core Ultra 5 225H (4P+8E) – Up to 4.9 GHz, 18MB cache, Intel Arc 130T GPU (63 TOPS), Intel AI Boost (13 TOPS), 28W PBP
  • Memory: Up to 96GB DDR5 6400 MHz via two 260-pin SO-DIMM slots
  • Storage:
    • 1x M.2 (Key M, 2242) with PCIe Gen4 x4 for NVMe SSD
    • 1x M.2 (Key M, 2242/2280) with PCIe Gen4 x4 for NVMe SSD
    • Motherboard and NUC only: 1x SATA 3.0 (6.0 Gb/s)
    • 256 Mbit SPI flash for AMI BIOS
  • Graphics and Display:
    • 2x HDMI 2.1 TMDS (up to 4096×2160 @ 60Hz)
    • 2x DisplayPort 2.1/1.4a via USB-C (up to 4096×2160 @ 60Hz)
    • Support for up to 4 independent displays
  • Audio:
    • Realtek ALC256 HD Audio
    • 3.5mm headphone and microphone jack
  • Networking:
    • 1x 2.5GbE RJ45 port via Intel I226LM (10/100/1000/2500 Mbps)
    • Motherboard and NUC models only: Additional 2.5GbE RJ45 via Intel I226V
    • Wi-Fi 6E and Bluetooth 5.3 via M.2 (Key E, 2230) (PCIe x1, USB 2.0, CNVi)
  • USB Ports:
    • 3x (NUCS) or 4x (NUC) USB 3.2 Gen2 Type-A
    • 1x USB4/Thunderbolt 4 (5V/3A, DP 2.1 display output)
    • 1x USB 3.2 Gen2 x2 Type-C (5V/3A, DP 1.4a display output)
    • 2x USB 2.0 via 2.00mm pitch header
  • Serial: 1x RS232/RS422/RS485 internal serial port
  • Security and Misc:
    • Intel PTT (Platform Trust Technology)
    • Watchdog Timer
  • Power: 12V to 24V DC input via jack (supports AT/ATX modes)
  • Dimensions & Weight:
    • NUC: 117.5 x 110.0 x 49mm | ~1 kg
    • NUCS: 117.5 x 110.0 x 38mm | ~1 kg
    • Motherboard: 104 x 102mm
  • Environmental:
    • Motherboard Operating: -20ºC to 70ºC
    • NUC/NUCS Operating: 0ºC to 40ºC
    • Storage Temperature: -40°C to 85°C
    • Humidity: 5% to 90% (operating & storage)
ASRock Industrial motherboard
ASRock Industrial officially supports Windows 10 and Windows 11, with no mention of Linux compatibility. The series is designed for AI-driven business applications, high-performance gaming, and immersive content creation.
Asrock 4X4 Box Ai300 Series And 4X4 Ai300 Motherboards
  • Processor:
    • AMD Ryzen AI 7 350 – Octa-core, up to 5.0 GHz, Radeon 860M GPU, 50 TOPS Ryzen AI
    • AMD Ryzen AI 5 340 – Hexa-core, up to 4.8 GHz, Radeon 840M GPU, 50 TOPS Ryzen AI
  • Memory: Up to 96GB DDR5-5600 via two SO-DIMM slots
  • Storage:
    • 2x HDMI 2.1 (up to 7680×4320 @ 60Hz)
    • 2x DisplayPort 1.4a via USB-C (up to 4096×2160 @ 60Hz)
  • Audio: 3.5mm jack with Realtek ALC256 HD Audio
  • Networking:
    • 1x 2.5GbE RJ45 (Realtek RTL8125BG)
    • 1x 1GbE RJ45 (Realtek RTL8111H)
    • Wi-Fi 6E and Bluetooth 5.2 via M.2 Key
  • USB Ports:
    • 1x USB 3.2
    • 2x USB4 (Supports DP1.4a display output)
  • Security: AMD FW TPM
  • Miscellaneous:
    • Watchdog Timer
  • Power Supply: 12V to 24V DC-In, supports AT/ATX modes
  • Dimensions and Weight: 117.5 x 110.0 x 49mm (~1kg)
  • Environmental Ratings:
    • Operating Temperature: 0ºC to 40ºC
    • Storage Temperature: -40ºC to 85ºC
    • Humidity (Operating and Storage): 5%-90%
4X4 8040 Series and AI350 ASRock Industrial motherboard
ASRock specifies Windows 11 as the supported OS for AMD-based systems, emphasizing their suitability for AI-powered applications, gaming, content creation, and AIoT deployments.
Intel vs. AMD: Feature Comparison
While ASRock Industrial has not directly compared Intel’s and AMD’s AI-driven solutions, key differences emerge:
  • Video Output: AMD’s 4X4 AI300 supports 8K @ 60Hz via HDMI, whereas Intel’s NUC Ultra 200 is limited to 4K @ 60Hz.
  • USB Connectivity: AMD models include two USB4 ports, while Intel has only one USB4/Thunderbolt 4.
  • Networking:
    • Intel models: Dual 2.5GbE ports.
    • AMD models: 2.5GbE + 1GbE.
  • Additional Features:
    • Intel’s models offer SATA support and a COM/serial interface.
    • AMD’s models lack SATA and COM ports but feature AMD FW TPM security.
Both series cater to AI-driven computing, business applications, and content creation, with hardware optimizations suited to different use cases.
ASRock Industrial’s latest NUC(S) Ultra 200 and 4X4 AI300 Series PCs and motherboards showcase the growing integration of AI inferencing capabilities in compact computing solutions. While Intel’s Arrow Lake-H processors provide higher AI inferencing power (up to 99 TOPS) and better connectivity, AMD’s Ryzen AI 300 models offer superior display output (8K 60Hz), dual USB4 ports, and competitive AI performance (50 TOPS). Both product lines cater to AI-driven applications, gaming, and content creation, but Linux compatibility remains uncertain based on ASRock’s official documentation.
ASRock Industrial has not yet revealed pricing for its new motherboard and Box PCs. However, more details can be found on the Fanned Embedded Box PC, NUC, and 4X4 product pages on the ASRock website. You can also refer to the press release for additional information.
