Beelink’s New EX Mate Pro Dock Features 80 Gbps USB4 and 4x M.2 Sockets
This multi-function docking station for laptops and mini PC's gives access to four PCIe Gen4 NVMe slots, a 140W built-in power supply, 2.5GbE networking, and AI-powered audio features.
Beelink has launched the EX Mate Pro, an all-in-one USB4 v2 Dock that turns your laptop or mini PC into a much more capable desktop setup. It uses the latest USB4 v2 standard to support the full 80 Gbps bandwidth, which makes it useful for various applications. Also, with this compatibility, it has a 99 × 99 × 98.3 mm form factor.
EX Mate Pro connects a laptop to an external GPU and peripherals over a single USB4 v2 cable
High-Speed Storage and Connectivity
The dock is designed to make storage upgrades really easy, with four M.2 PCIe Gen4 slots. You can install up to four NVMe SSDs and get fast local storage directly inside the dock.
For display, you have an HDMI port t that supports up to 4K at 60Hz, it also supports video output through the USB4 connection, which is pretty obvious for a device of this caliber, and with the two display outputs, you can drive two monitors simultaneously.
Exploded view showing internal layout with silent fan, dual M.2 PCIe 4.0 slots, built-in PSU, and integrated speaker.
There are also standard USB 3.0 and USB 2.0 Type-A ports for connecting keyboards, mice, or other devices. Additionally, there’s a second USB4 v2 port that can supply 15W of power. It’s great for hooking up an external GPU (eGPU), extra monitors, or high-speed external SSDs.
With all these features, they did not neglect networking, as it includes a 2.5GbE Ethernet port, which is pretty fast for most home and office needs.
Audio and Voice Features
It also comes with a built-in speaker and a quad-microphone array that can clearly pick up your voice from up to 5 meters away. The company also mentions that they have used an AI noise-cancellation chip (called B1), so your voice sounds clear even in noisy environments.
Dual-display setup and Front and rear I/O layout with USB4 v2, HDMI, USB, 2.5G LAN, power input, and status indicators.
You can also connect it via Bluetooth and use the dock as a standalone wireless speaker for music or calls. It also features touch controls, which include playing/pausing music, switching to Bluetooth mode, adjusting volume, and muting the microphone. There are also small LEDs that show the status of power, Bluetooth, and the microphone on/off. Inside, a quiet “silent fan” keeps everything cool when you’re using the storage or network heavily.
Integrated Power Supply
What’s interesting about this product is that it has a built-in 140W power supply. Instead of having a big external power brick cluttering your desk, the dock plugs straight into the wall with a normal power cord.
140W built-in power supply delivers clean, high-power output for connected devices.
This internal power supply lets the main USB4 v2 host port deliver up to 96W of charging power to your laptop or mini PC. At the same time, the second USB4 port still provides 15W for peripherals like external GPUs or extra drives. So, no extra adapters needed, just one clean power cable for the whole dock.
Pricing and Availability
The EX Mate Pro Dock is very compact, measuring just 99 × 99 × 98.3 mm. It works plug-and-play with no special software required and uses your laptop or mini PC’s standard USB4 drivers.
The dock is now available directly from Beelink’s official store for $199 (plus shipping). It should also appear on Beelink’s Amazon and AliExpress stores very soon. Inside the box, you’ll find a portable carrying bag, a user manual, an AC power cord, an 80 Gbps USB-C cable, and an HDMI cable.
Images used courtesy of Beelink
