MSI MS-C926 Ultra-Slim Fanless Box PC with Intel Alder Lake-N/Twin Lake, 16GB DDR5, and Triple 4K Displays
MSI’s Fanless Box PC MS-C926 is a 19mm slim embedded system with Alder Lake-N/Twin Lake CPUs, DDR5, triple 4K displays, dual 2.5GbE, M.2 expansion, and wide DC input.
MSI MS-C926 Industrial Fanless Box PC
MSI has launched the MSI Fanless Box PC MS-C926, an ultra-slim embedded system built on Intel Alder Lake-N and Twin Lake platforms. Measuring just 19 mm thin with a cable-free internal design, the MS-C926 is optimized for durability and thermal reliability in space-constrained applications such as digital signage, kiosks, industrial control, and other edge computing scenarios. It supports processors including the Alder Lake-N N97 and Twin Lake N150, N250, and Core 3-N355, reaching up to 3.9 GHz, along with up to 16GB of DDR5 memory, triple 4K display outputs, dual 2.5GbE ports, three USB 3.2 Gen 1 ports, and a COM port.
Expansion capabilities of the MSI Fanless Box PC include an M.2 B-Key slot with Nano SIM support for cellular connectivity, an M.2 E-Key slot enabling Wi-Fi 7, and a 2.5-inch SATA HDD/SSD bay. The system also provides optional TPM 2.0, wide-range 12–24V DC input, and VESA/wall mounting support, while operating reliably in environments between -10°C and 50°C. These features make it a compact yet powerful solution for industrial and commercial edge deployments.
MSI MS-C926 Ports
MSI MS-C926 Ports
MSI MS-C926 Industrial Fanless Box PC Specifications:
  • CPU options:
    • Intel Alder Lake-N N97: quad-core, up to 3.6GHz, 12W TDP
    • Intel Twin Lake N150: quad-core, up to 3.6GHz, 6W TDP
    • Intel Twin Lake N250: quad-core, up to 3.8GHz, 6W TDP
    • Intel Twin Lake Core 3-N355: octa-core, up to 3.9GHz, 15W TDP
    • L2 cache: 6MB
    • Package: BGA
    • BIOS: AMI
  • Memory:
    • Up to 16GB DDR5-4800 (single-channel)
    • 1x 262-pin SO-DIMM
  • Storage: 1x 2.5-inch SATA HDD/SSD
  • GPU:
    • Integrated Intel UHD Graphics (depends on CPU)
    • Triple independent displays
  • Video:
    • 1x HDMI 2.0 (4096×2304 @60Hz)
    • 2x DisplayPort (4096×2304 @60Hz)
  • Networking: 2x Intel I226-V 2.5GbE LAN ports
  • Audio:
    • Realtek ALC897 HD Audio Codec
    • 1x Line-out
  • I/O interfaces:
    • 3x USB 3.2 Gen1
    • 1x USB 2.0
    • 1x COM port (RS-232/422/485, 0V/5V/12V selectable)
    • 2x RJ45 LAN
    • 4x reserved antenna openings
  • Expansion:
    • 1x M.2 B-Key (2242/3042/2280) – PCIe x1/SATA, USB 3.2 Gen2, USB 2.0, Nano SIM holder
    • 1x M.2 E-Key (2230) – PCIe x1, USB 2.0 (Wi-Fi/BT support)
  • Security: TPM 2.0 (Infineon SLB9672VU2.0, optional)
  • Misc: 256-level watchdog timer
  • Power: DC-in 12~24V wide-range with lockable DC jack
  • Dimensions: 180 x 255 x 19 mm
  • Weight: 1.3 kg
  • Operating temperature: -10°C to 50°C (with airflow 0.7 m/s, SSD)
  • Storage temperature: -20°C to 80°C
  • Humidity: 10~90% non-condensing (operating/storage)
  • Vibration: IEC 60068-2-64, 2 Grms, 5–500 Hz, 1hr/axis (SSD)
  • Shock: IEC 60068-2-27, 50G, half sine, 11ms (SSD)
  • Certifications:
    • EMC: CE, FCC, RCM, VCCI, BSMI, UKCA, IC
    • Safety: IEC 62368 (CE/LVD, BSMI)
MSI MS-C926 Industrial Fanless Box PC SpecificationsMSI MS-C926 Industrial Fanless Box PC Specifications
In terms of software, MSI MS-C926 fanless PC Box supports Windows 11 IoT Enterprise LTSC (64-bit, 24H2) and Windows 10 IoT Enterprise LTSC (64-bit, 21H2) for Alder Lake-N platforms. Linux support is available depending upon user request only.
Previously, we have covered several fanless PCs such as the QBiX-ADNAN97-A1, MSI MS-C918S, uIBX-250-BW, BOXER-6647-MTH, and more. You can check them out if you’re interested in similar products.
The company did not reveal the pricing details of MS-C926 fanless PC Box as of now. For more information it is recommended to go the company product page and news page as well.
