Melexis MLX90636 Packs ±0.2°C Accuracy Into a 1.8 mm Wearable Sensor
A chip-scale infrared thermometer targets smartwatches and rings, while the vendor studies how wrist readings might be translated into core body temperature estimates.
Melexis has introduced the MLX90636, a far-infrared temperature sensor conceived for wearable health devices. The company bills it as the smallest contactless sensor to deliver medical-grade accuracy, which in this case means ±0.2°C across the human body temperature range, in line with section 5.4 of ASTM standard E1965-98. The part follows the MLX90632, carrying that sensor’s surface-mount, far-infrared approach into a tighter footprint.
Thermometry in a Speck of Silicon
Far-infrared sensing in a surface-mount package yields a truer reading of surface temperature than traditional contact thermometers, which tend to be tripped up by ambient temperature noise and thermal lag. Taming those effects in a miniature part is no small feat, so the MLX90636 is built to hold steady through rapid ambient swings and air turbulence. It arrives in a chip-scale package measuring 1.8 × 1.8 × 0.75 mm³, with five LGA pads, and an integrated optical filter passing roughly 2 µm to 20 µm keeps visible light from interfering.
Field of view is 50°. For high-accuracy work, though, the datasheet asks designers to keep a cone at least 95° wide free of obstruction, widening that to 135° for medical applications. Thermal gradients remain a caveat: hot electronics behind the sensor, or a hot or cold object sitting very close, can shift the package temperature and skew results. Accuracy figures also assume settled, isothermal conditions.
Power, Interface, and Integration
Calibration constants reside in on-chip EEPROM, and the host microcontroller computes ambient and object temperatures from them together with the raw measurement data. Supply voltage is 2.8 V or 3.3 V, depending on the variant, while the I²C bus runs at either 1.2 V or 1.8 V. The 1.8 V version supports Fast-mode Plus, whereas the 1.2 V version tops out at Fast-mode. The default address is 0x32, though it can be redefined in software.
Power draw suits battery-operated duty. Typical sleep current is 0.8 µA (1.5 µA at most), active supply current is 0.7 mA typical, and the refresh rate is programmable from 0.5 Hz to 32 Hz. Integration aids include a post-calibration option and an open-source GitHub driver. The recommended schematic pairs a 47 nF decoupling capacitor, placed within 20 mm of the device, with 1 kΩ pull-up resistors on the bus. For noisy environments, a separate Melexis application note on robust I²C communication reports passing EMC susceptibility tests on a four-layer board that routes SCL and SDA on an inner layer between ground shield layers, with ferrite beads added on both lines.
Host-side emphasis: Calibration constants stored in EEPROM and raw measurement data in RAM are both reachable over I²C, so the host microcontroller does the temperature math. Image used courtesy of Melexis
Chasing Core Body Temperature
A precise skin reading is only half the puzzle. Wrist skin temperature is swayed by local blood flow, ambient conditions, and device thermals, so it does not translate directly into core body temperature. To bridge that gap, Melexis is researching wrist-to-core modeling that would estimate core body temperature from wrist-worn sensor inputs. An evaluation kit for exploratory feasibility studies is being finalized, and interested customers are invited to get in touch. The MLX90636 itself is available now.
All told, this is a compact, low-power sensing building block with a clear eye on health tracking. Smartwatches, fitness bands, and smart rings are the headline targets, with body temperature measurement, healthcare devices, and non-contact thermometers for mobile and IoT products rounding out the list. Whether wrist-to-core estimation matures into something reliable is an open question, but the hardware groundwork looks tidy.
