Renesas RZ/T2N MPU Integrates 4-Axis Motor Control and TSN Industrial Ethernet
Combining dual Cortex-A55 and Cortex-R52 cores, this single-chip microprocessor handles real-time robotics motion, EtherCAT networking, and Linux applications
Renesas introduced the RZ/T2N, an industrial Motor Control MPU designed to run Linux applications, real-time control, and factory networking in a single device. The MPU combines up to two Arm Cortex-A55 cores clocked at 1.2 GHz with two Cortex-R52 cores running at 800 MHz. It also integrates motor-control peripherals that can manage up to four axes, making it suitable for industrial robots, multi-axis servo drives, PLCs, and other automation equipment.
The processor includes three Gigabit Ethernet MACs, a three-port Time-Sensitive Networking (TSN) switch, and support for industrial communication protocols such as EtherCAT, PROFINET RT/IRT, and EtherNet/IP. Additional features include eight encoder interfaces, trigonometric accelerators, a 16-bit LPDDR4 memory controller, and PCIe Gen2 connectivity. By combining application processing with time-critical control and networking hardware, the RZ/T2N can reduce the need for separate processors in industrial systems.
Renesas RZ/T2N 4-Axis Motor Control MPU with TSN Industrial Ethernet
Renesas RZ/T2N specifications:
  • CPU:
    • Up to 2x Arm Cortex-A55 (64-bit) @ 1.2 GHz
    • 2x Arm Cortex-R52 (32-bit) @ 800 MHz
    • 2x trigonometric function accelerators
  • Memory:
    • 2MB on-chip SRAM with ECC
    • 576KB tightly coupled memory (TCM) with ECC per Cortex-R52 core
    • 16-bit LPDDR4-1600 interface, supporting up to 2GB RAM
    • Inline ECC and on-the-fly encryption/decryption support on applicable variants
  • Storage:
    • 2x xSPI interfaces supporting Quad/Octal SPI
    • 2x SD/eMMC host controllers
    • 8-bit NAND flash controller
  • Networking:
    • 3x Gigabit Ethernet MACs
    • 3-port Gigabit Ethernet switch with TSN
    • 3-port EtherCAT SubDevice controller on selected variants
    • Industrial Ethernet – EtherCAT, PROFINET RT/IRT, EtherNet/IP
    • Ethernet redundancy – HSR, PRP, DLR, and FRER
    • IEEE 1588 Precision Time Protocol (PTP)
  • Motor control:
    • Up to four motor axes
    • Three-phase complementary PWM outputs
    • 8-channel encoder interface supporting A-format, EnDat 2.2/3, BiSS-C, BiSS-Line, HIPERFACE DSL, and FA-CODER
    • Up to 15-channel delta-sigma interface
    • 3x 12-bit ADC units
    • General-purpose PWM timers and motor-control timers
  • Other interfaces:
    • 1x PCIe Gen2 x1
    • 1x USB 2.0 high-speed host/device
    • Up to 2x CAN/CAN FD
    • 4x SPI, 3x I2C, SCI/UART
    • Up to 201 GPIOs
  • Security:
    • Arm TrustZone
    • Secure boot and secure firmware updates
    • Hardware cryptographic accelerator
    • True random number generator (TRNG)
    • Secure debug
  • Operating temperature: -40°C to +125°C (junction)
  • Package options:
    • 489-pin FBGA (16 × 16 mm)
    • 537-pin FBGA (21 × 21 mm)
Note: The available Ethernet, CAN FD, security, and other peripheral functions vary between RZ/T2N models. See the datasheet for more information.
Renesas RZ/T2N Motor Control MPU Block Diagram
The RZ/T2N uses separate processing cores to handle application software and real-time tasks. The Cortex-A55 cores can run Linux for machine monitoring, diagnostics, data processing, and network management. The Cortex-R52 core, on the other hand, runs time-sensitive motor-control routines. The motor-control hardware includes PWM timers, encoder interfaces, and delta-sigma inputs for motor feedback. Two trigonometric accelerators can also perform mathematical operations used in motor-control algorithms without relying entirely on CPU processing.
For industrial networking, the TSN-supported Ethernet switch supports synchronized data exchange between connected equipment. The MPU also supports industrial redundancy mechanisms such as High-availability Seamless Redundancy (HSR), Parallel Redundancy Protocol (PRP), Device Level Ring (DLR), and Frame Replication and Elimination for Reliability (FRER). These features are useful in industrial networks where communication interruptions can affect machine operation. Protocol availability and implementation depend on the selected MPU variant and software stack.
In terms of software support, the company provides the RZ Flexible Software Package (FSP) and the Eclipse-based e² studio IDE for developing applications on the real-time cores. Linux support is available through RZ Linux BSP Plus, based on Linux kernel 6.12 and Yocto Project 5.0 (Scarthgap). A Multi-OS package using OpenAMP also enables communication between the Cortex-A55 and Cortex-R52 processors, allowing Linux and real-time software to run on the same MPU.
Renesas also provides sample applications for industrial networking, including EtherCAT, EtherNet/IP, OPC UA, and Modbus. A four-axis motor-control example uses EtherCAT with the CiA402 drive profile and supports cyclic synchronous position, cyclic synchronous velocity, profile position, and homing modes.
Renesas RZ/T2N-EVKIT evaluation board with industrial Ethernet and motor-control interfaces
RZ/T Series Inverter Board for Motor Control Evaluation
MC-COM Communication Board for Isolated Serial Communication During Motor Control Development
The company also provides various development boards, including the RZ/T2N-EVKIT, which includes an inverter board and a BLDC motor. The inverter board is also available separately, while the MC-COM communication board provides electrically isolated serial communication for motor-control evaluation and debugging. You can connect up to four inverter boards to the RZ/T2N evaluation board for four-axis motor-control testing.
Previously, we have written about other 64-bit processors, including the Renesas RZ/G3L and RZ/G3SE for HMI and edge computing, the Renesas RZ/G3E for HMI and edge computing, the Renesas RZ/A3M for graphics-driven interfaces, and the Renesas RZ/V2N for vision AI. But unlike those general-purpose, HMI, and AI-focused parts built around the Cortex-M33 coprocessor or NPU alongside Cortex-A55 cores, the new RZ/T2N is designed for deterministic factory automation and robotics.
The RZ/T2N Motor Control MPU’s are already available, with individual processors priced at approximately $50 through electronics distributors. The RZ/T2N-EVKIT has a $457.50 budgetary price on the Renesas website, although actual distributor prices may differ. You can find more information, including detailed specifications, documentation, software downloads, and development resources, on the Renesas RZ/T2N product page.
Images used courtesy of Renesas
