Transient Voltage Suppressors
https://www.electronics-lab.com/transient-voltage-suppressors/
Voltage suppressors are used to protect circuits from unwanted transients, when other devices like diodes and capacitors fail to do so. Transient effects have various sources and are able to damage the connected parts and ICs if not properly measures taken. In this article we will discuss about the various transient voltage suppressors and their […]
PIC24 bedside table alarm clock
https://www.electronics-lab.com/pic24-bedside-table-alarm-clock/
Markus Gritsch posted pictures and code of his PIC24 bedside table alarm clock: Another year, another clock, but for the first time for my alarm clocks. I am not using an MSP430 but a PIC24 instead. Standby current is with 5.5 µA only slightly higher than that of my MSP430 based ones. Time keeping is […]
3A Variable Bench PSU with Color Display
https://www.electronics-lab.com/3a-variable-bench-psu-with-color-display/
by SHARANYADAS @ instructables.com: I am playing with electronics since i was a child and made numerous circuits.But still now,i didn’t made any power supply unit for general purpose use.So tired of making PSU for each circuit,I decided to make a stable Bench PSU for general purpose use with some enhanced features.I decided to made the […]
Electronic Live Capture Mousetrap
https://www.electronics-lab.com/electronic-live-capture-mousetrap/
A mousetrap is a type of animal trap specialize to catch small animals, particularly rodents like rats, mice, hamsters, etc. This project is a kind of mousetrap that is intended to keep a captured animal alive. In this way, the hunter can release the captured animal later to the wild. The PIC12F683 microcontroller acts as […]
Makerarm – The first robotic arm that makes anything, anywhere
https://www.electronics-lab.com/makerarm-the-first-robotic-arm-that-makes-anything-anywhere/
Makerarm just lauched on kickstarter. It’s a penknife for the DIY world, it can make almost anything by changing the toolhead! A complete digital fabrication system for makers everywhere: 3D print, laser, carve, plot, assemble, pick/place + more on your desktop! Makerarm works with interchangeable heads for countless applications. It 3D prints: Makerarm is not confined […]
The femtocell technology
https://www.electronics-lab.com/the-femtocell-technology/
by Slovati @ dev.emcelettronica.com: Femtocells are basically low-power wireless access points that operate inside licensed frequency bands for connecting standard mobile devices with a provider’s network, using a broadband connection such as the DSL or a cable connection (basically using the best Internet connection available at that point). A femtocell is therefore an indoor base station that […]
Fastest, highest-resolution DLP chipset for 3D print/lithography
https://www.electronics-lab.com/fastest-highest-resolution-dlp-chipset-for-3d-printlithography/
by Graham Prophet @ edn-europe.com: With its latest micro-mirror-based light-steering chip, Texas Instruments says, applications developers can innovate with more than 4 million micromirrors to enable high throughput digital imaging applications. Presented as its highest speed and resolution chipset for 3D printing and lithography applications, TI’s DLP9000X digital micromirror device (DMD) and the DLPC910 controller, offers […]
Programmable Home Security Alarm System
https://www.electronics-lab.com/programmable-home-security-alarm-system/
In this project we design low cost high performance programmable home security system using few LDR’s as an input sensors. When above sensor(s) get triggered system may dial the user specified phone number (using build-in DTMF generator) and activate the high power audio alarm and lights. All the parameters of DTMF generator, audio alarm and […]
Single Channel SMD Relay Driver
https://www.electronics-lab.com/singe-channel-smd-relay-driver/
Single Channel Relay Board is a simple and convenient way to interface a relay for switching application in your project. Specifications     Input supply 12VDC @ 42 mA     On Board 5V Regulator provides 5V output     Output SPDT Relay     Relay specification 5 A @ 230 VAC     Trigger level 2 ~ 9 VDC […]
https://www.electronics-lab.com/project/single-channel-smd-relay-driver/
