Overheat/Overcooling Circuit Breaker
https://www.electronics-lab.com/overheatovercooling-circuit-breaker/
This project automatically switches off the electrical flow in event of excess heating or excess cooling thus protecting the circuit from damage using NXP NCX2220GU. The comparator guarantees to operate at low voltages which makes this device convenient for use in 5 V systems and has a typical internal hysteresis of 9 mV that allows […]
LSM6DS3H – New 6-axis motion sensor from STMicroelectronics
https://www.electronics-lab.com/lsm6ds3h-new-6-axis-motion-sensor-from-stmicroelectronics/
by Martin Cooke @ elektormagazine.com: The latest MEMs device from STMicroelectronics is said to be the world’s most advanced six-axis motion-sensor device designed to support image stabilization in smartphones, tablets and digital still cameras. The LSM6DS3H combines a 3-axis gyroscope and 3-axis accelerometer together with an Ultra Low Power processing IC to provide a System in […]
Temperature controlled coolbox
https://www.electronics-lab.com/temperature-controlled-coolbox/
by nusnel @ instructables.com: For my monthly maker column in Dutch newspaper “De Volkskrant”, I made a coolbox in which you can control the temperature in three separate compartments to keep craft beer at just the right temperature. The contraption I build uses three Peltier-elements to cool, an old desktop computers power source, an LCD to […]
Arduino Time-Lapse Panorama Controller
https://www.electronics-lab.com/arduino-time-lapse-panorama-controller/
by oliverb @ instructables.com: The Arduino controls a Geared Stepper Motor 28BYJ-48 via a ULN2003 Stepper Motor Driver Board. The 4×20 I2C LCD display and 5 micro switches form the interface to the Arduino. The controller has a Manfrotto 200PL-14 quick release tripod mount for attachment to my tripod and other mounting hardware fitted with a […]
Basic Types of Diodes
https://www.electronics-lab.com/article-basic-diode-types/
In this article we will discuss about the various types of diodes, their working principle and their common uses. We will cover many common diode types, such as P-N junction diode, Zener diode, Schottky diode, LED and laser diodes, photo diode, varactor diode, avalanche diode, PIN diode etc. Feel free to leave a comment with […]
Driving LEDs
https://www.electronics-lab.com/driving-leds/
Emanuele @ dev.emcelettronica.com published an article on how to drive LEDs: The LEDs (Light Emitting Diode) are diodes whose basic characteristic is the ability to emit light when they are passed through a current that flows from P to N region. At each recombination between the charge carriers (electrons and holes), on PN junction region, a […]
Make a Weather Station With a Raspberry Pi 2
https://www.electronics-lab.com/make-a-weather-station-with-a-raspberry-pi-2/
Jeremy Morgan @ jeremymorgan.com writes: Today I’m going to show you how to make sort of a mini weather station with a Raspberry Pi. This is an ongoing project of mine that I’ve been tinkering with so I’ll share my learnings with you. It started with a project I wrote about last month, and is […]
PCB stencil jig
https://www.electronics-lab.com/pcb-stencil-jig/
Gonazar’s PCB stencil jig: My solution to making a PCB stencil jig. I need this to do a run of ~30 small boards I got from DirtyPCB who also provided me with the stencil. However, I know that I’m going to be making more later with a new revision so I wanted a jig that […]
Can a current flow even up the hill?
https://www.electronics-lab.com/can-a-current-flow-even-up-the-hill/
Of course it can, even apeak. So if you connect leads from the bottom side via a PCB connector, you don´t have to worry about the current… Should you however be afraid of accidental fall off of the connector (it will certainly hold on if there are no vibrations, shocks or unpredictable tension to leads), […]
High Speed Ecosystem Support and Calamity Monitoring System
https://www.electronics-lab.com/high-speed-ecosystem-support-and-calamity-monitoring-system/
The innovation of equipment for calamity detection and monitoring are quite rampant. It is because of consecutive aggression of storms and earthquakes in different parts of the world. As to observe the different scenarios, these are not merely natural causes, there are some or most of it is manmade. A good example of it is […]
