18 PIN PIC Development Board
https://www.electronics-lab.com/18-pin-pic-development-board/
The PIC 18 PIN (DIP) Development / Evaluations Board demonstrates the capabilities of Microchip’s 8-bit microcontrollers, specifically, 18 Pin PIC16F1847. It can be used as a standalone demonstration board with a programmed part. With this board you can develop and prototype with all Microchip’s 18 PIN PIC microcontrollers. The board has a Reset switch and […]
https://www.electronics-lab.com/project/18-pin-pic-development-board/
ESP8266 remote controlled sockets
https://www.electronics-lab.com/esp8266-remote-controlled-sockets/
Rui Santos published a new project, an ESP8266 remote controlled sockets: In this project your’re going to build a web server with an ESP8266 that can control remotely any sockets (safely!). ESP8266 remote controlled sockets – [Link]
Arduino – How to use a Force Sensitive Resistor
https://www.electronics-lab.com/arduino-how-to-use-a-force-sensitive-resistor/
by codebender_cc @ instructables.com: In this tutorial you will learn how to use an FSR – Force Sensitive Resistor with Arduino to fade an LED. This sensor is a variable resistor just like a photocell or flex sensor. The resistance changes by applying pressure on it. Arduino – How to use a Force Sensitive Resistor – […]
Laser Diode Driver
https://www.electronics-lab.com/laser-diode-driver/
Laser Diode Driver project will help you safely drive (constant current) a 3 mW visible Laser Diode for your application. Input supply – 2.5 to 6 VDC Onboard preset to adjust the current flow to the Laser Diode Power-On LED indicator Header connector for easy input supply and LASER DIODE module connection Laser diode is […]
8V97051 Low Power Wideband Fractional RF Synthesizer
https://www.electronics-lab.com/8v97051-low-power-wideband-fractional-rf-synthesizer/
This design features a low power wideband RF synthesizer that is used in GSM receiver cards. It has dual differential and open drain outputs with frequency range of 34.375MHz to 4400MHz(in continuous range). The logic compatibility is 1.8V while the system is running on a single 3.3V supply. It has -143dBc/Hz Phase Noise (PN) performance […]
Maximo Robot Arm – for kids and even big kids
https://www.electronics-lab.com/maximo-robot-arm-for-kids-and-even-big-kids/
The Maximo Robot Arm is the greatest way to discover robotics. Accessible, fun and affordable, Maximo is designed for everyone. Maximo Robot Arm comes with a laser-cut acrylic body. It was designed to offer the highest quality while remaining one of the most affordable robotic arms on the market. Its 5-axis range of motion allows […]
LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit
https://www.electronics-lab.com/lt3091-36v-1-5a-negative-linear-regulator-with-programmable-current-limit/
The LT®3091 is a 1.5A, low dropout negative linear regulator that is easily paralleled to increase output current or spread heat on surface mounted boards. Designed with a precision current reference followed by a high performance rail-to-rail voltage buffer, this regulator finds use in applications requiring precision output, high current with no heat sink, output […]
Open source pocket USB oscilloscope; 30 MHz, multi-platform
https://www.electronics-lab.com/open-source-pocket-usb-oscilloscope-30-mhz-multi-platform/
by Graham Prophet @ edn-europe.com: Running on Apple iPad, Android, Microsoft Windows and Linux, LabNation’s (Antwerp, Belgium) open source USB oscilloscope, SmartScope, is the result of a Kickstarter campaign commenced in 2014 – the project raised 645% of the funding goal within 30 days. Believed to be the first test equipment designed to run on multiple […]
RePhone kit: World’s first open source and modular phone
https://www.electronics-lab.com/rephone-kit-worlds-first-open-source-and-modular-phone/
Seeed Studio has announced that RePhone, an open source and modular phone kit: With Rephone you can: 1.Create your own phone in minutes with the slim MODULES, accessible SOFTWARE, and customizable Phone Enclosures. 2.Hack anything around you, giving inanimate objects the power of cellular communication. Have a conversation with your pets, plants, toys, motorcycle helmets, […]
