Even a small figurine can play a big performance
https://www.electronics-lab.com/even-a-small-figurine-can-play-a-big-performance/
New aerial from 2J will surely not surprise you by its size, however features of the antenna are worth noticing. 2JW035 antenna measures only 52,5mm and is intended for WiFi and Bluetooth devices in 2.4 a 5GHz bands. The gain is 5dBi and the VSWR value is below 2.6:1. A big advantage of this antenna […]
KaraOkay Microphone Amplifier
https://www.electronics-lab.com/karaokay-microphone-amplifier/
Here is an all-analog, all-through-hole, cheap & cheerful preamplifier for that perennial problem of getting the microphone amplification just right, which is a challenge not only with the faithful reproduction of lead vocals during concerts and recordings, but also with campfire and karaoke-ish performances specially when the beer takes hold. KaraOkay Microphone Amplifier – [Link]
More awesome DoorBell control
https://www.electronics-lab.com/more-awesome-doorbell-control/
Felix of LowPowerLab posted an update on his DoorBell Mote project: My first DoorBell Mote prototype was working nicely and it allowed monitoring the door bell (while also triggering it remotely – toddlers love it). But I wanted more. On weekends the family likes to get a well deserved nap during the day and often […]
Energy Wristband monitors energy usage on home
https://www.electronics-lab.com/energy-wristband-monitors-energy-usage-on-home/
by Matt Venn: A wristband that tells you energy changes in your home. It connects via a Raspberry Pi computer to a base station like a ‘current cost’ or similar. When a change in energy usage occurs, the wristband vibrates and a small LED bargraph shows your current usage from 1 to 4. Energy Wristband monitors […]
Using Python with Arduino
https://www.electronics-lab.com/using-python-with-arduino/
by toptechboy.com: This series of lessons will teach you how to take your Arduino projects to the next level by having the Arduino interact with the Python programming language. Python is a free program you can download. Since you have already learned the fundamentals of programming through our first 20 Arduino lessons, learning Python will be […]
2 New Families from Microchip
https://www.electronics-lab.com/2-new-families-from-microchip/
by elektormagazine.com: Microchip has introduced two new 8-bit MCU families with integrated Core Independent Peripherals (CIPs). You may be thinking that 8-bit processors are unlikely to cut the mustard for many of today’s applications but built-in interconnected CIPs combine to perform functions autonomously, without intervention from the processor. This makes these new 8-bit families suitable […]
Engine and Steering Wheel Automotive Networking Protocol
https://www.electronics-lab.com/engine-and-steering-wheel-automotive-networking-protocol/
An automobile plays an important role in a community. Aside from being a major option for transport, automobile also saves life, which is designed to give support in medications and hospitalizations. These machines are now embedded with electronic technology in which this advancement brings security and convenience to people. The engine and the steering wheel […]
Buck converter is pin-programmable
https://www.electronics-lab.com/buck-converter-is-pin-programmable/
by Susan Nordyk @ edn.com: Housed in a tiny 3×3-mm QFN package, the MIC24046-H synchronous step-down regulator from Micrel offers efficiency of greater than 90% peak and pin-selectable output voltage, switching frequency, and current limit. A wide input voltage range of 4.5 V to 19 V makes the part useful for distributed 12-V point-of-load applications. The […]
2A, 70V SEPIC/Boost DC/DC converter with 7µA Iq
https://www.electronics-lab.com/2a-70v-sepicboost-dcdc-converter-with-7%c2%b5a-iq/
by Graham Prophet @ edn-europe.com: LT8494 is a current mode, fixed frequency SEPIC/boost DC/DC converter with an internal 2A, 70V switch. Quiescent current of 7µA suits the device for always-on automotive or other industrial battery powered systems. The LT8494 starts up from an input voltage range of 2.5V to 32V and once running it operates from […]
A low-cost 0.5A 33V LED driver module with 90+% efficiency
https://www.electronics-lab.com/a-low-cost-0-5a-33v-led-driver-module-with-90-efficiency/
by Valentin Kulikov @ edn.com This article describes simple constant current driver module with fast PWM input that can be used for driving medium and high power LEDs. The module uses an integrated constant-current output, DC-DC buck converter with output current configurable from 0.1 to 0.5A. This article outlines the schematic, design guidelines, operation, and performance […]
