Using Interrupts with Arduino
https://www.electronics-lab.com/project/using-interrupts-with-arduino/
We can say that an Interrupt is an automatic transfer of software execution in response to a hardware event that is asynchronous with the current software execution. As it’s name says, interrupts, “interrupt” the normal program flow to perform an action (run another code block, function, etc.) and return back to the normal program flow […]
Omron USB and PCB Type Environmental Sensors
https://www.electronics-lab.com/omron-usb-pcb-type-environmental-sensors/
Omron’s 2JCIE environmental sensors are IoT sensors integrated with Bluetooth. These sensors are capable of tracking eight different environmental factors which include: temperature, humidity, light, UV index, barometric pressure, noise, acceleration and VOC (Volatile Organic Compounds) with wireless communication functionality in an ultra-small footprint. The sensors can be used in the home to monitor room […]
Leaked Intel roadmap reveals a 2Q launch for 10nm Ice Lake chips and Lakefield processor
https://www.electronics-lab.com/leaked-intel-roadmap-reveals-2q-launch-10nm-ice-lake-chips-lakefield-processor/
A leaked Intel roadmap reveals launch plans for Intel Core and Atom processors through the end of 2021. Of interest is a hybrid Lakefield processor design that combines a 10nm Ice Lake core and 4x Atom Tremont cores. The roadmap contains several surprises, like Intel’s plans for a market launch of its 10nm U- and […]
Experience the Power of AI with Solutions from AAEON
https://www.electronics-lab.com/experience-power-ai-solutions-aaeon/
AAEON is leading the industry with embedded solutions for AI and edge computing applications. Whether your project involves drones, robots, smart security systems, or intelligent street lights, AAEON has the hardware solutions to meet any need. With experience and expertise in creating rugged industrial platforms, these AI platforms will work anywhere you need. AAEON meets […]
Breakthrough in CO2 Sensing: First Sensirion Miniaturized CO2 Sensor
https://www.electronics-lab.com/breakthrough-co2-sensing-first-sensirion-miniaturized-co2-sensor/
Once again, Sensirion trailblazes innovation in environmental sensing to create healthier and more productive environments for people. At this year’s Sensor+Test 2019 in Nuremberg and SensorsExpo 2019 in San José, the expert in environmental sensing, Sensirion, is announcing the SCD40 – the first miniaturized CO2 and RH/T sensor that fits in a space of just […]
1.5V battery powers white-LED driver
https://www.electronics-lab.com/1-5v-battery-powers-white-led-driver/
Although white LEDs are common in a variety of lighting applications, their 3 to 4 V forward-voltage drop makes low-voltage applications challenging. Charge pumps and other ICs are available for driving white LEDs, but they generally don’t work with the low supply voltage of 1.5 V in single-cell-battery applications. The low-voltage circuit of Figure 1 provides […]
ASRock announces four Whiskey Lake-U based products
https://www.electronics-lab.com/asrock-announces-four-whiskey-lake-u-based-products/
ASRock Industrial has announced four new products based on Intel’s 8th Gen Whiskey Lake-U: a thin Mini-ITX “IMB-1216” board, a 3.5-inch “SBC-350,” a NUC 4×4 form-factor “iBox-8365U” mini-PC and NUC-8365U mainboard. The IMB-1216 thin Mini-ITX board and the 3.5-inch SBC-350 boards run the quad-core, dual-threaded Core i5-8365U, clocking at 1.6GHz (4.1GHz Turbo). The iBox-8365U mini-PC […]
Conversa – USB 3.1 Camera with Microphone supports Low Light
https://www.electronics-lab.com/conversa-usb-3-1-camera-microphone-supports-low-light/
e-con Systems is a leading camera solutions provider making state of the art camera modules, and also have recently added a new camera module to their collection called Conversa. e-con system’s cameras include standalone MIPI camera modules, USB cameras, and stereo cameras. The Conversa also known with the code name See3CAM_CU38 is a USB 3.1 Gen […]
3V DACs used in ±10V applications
https://www.electronics-lab.com/3v-dacs-used-%c2%b110v-applications/
Boosting DAC’s output to drive larger voltage tackled in this app note from MAXIM Integrated. Many modern systems have the majority of their electronics powered by 3.3V or lower, but must drive external loads with ±10V, a range that is still very common in industrial applications. There are digital to analog converters (DACs) available that […]
4X4-R1000 – NUC-R1000 AMD RYZEN embedded CPU
https://www.electronics-lab.com/4x4-r1000-nuc-r1000-amd-ryzen-embedded-cpu/
Asrock introduced their “4X4-R1000” SBC along with some preliminary specifications and features. There is not much information available nor pricing, so we will limited on the the features and specifications provided. This SBC is based on AMD RYZEN embedded CPU, accompanied with up to 32GB DDR4 memory and various peripherals as seen below. Spotlight Features […]
