OPEN Power: A Simple Constant Power Supply with Variable Voltage
https://www.electronics-lab.com/open-power-simple-constant-power-supply-variable-voltage/
John Loeffler didn’t have much to build a power supply for his bench so he decided to build his own and he did it nicely. This Project is to produce 3 final Prototypes. All Power Supplies will have USB Charging of Lithium Batteries and a Load Sharing. Prototype 1: Simple Constant voltage Power Supply Variable […]
Industry-Leading Energy Harvesting Technology from e-peas Enables Accurate & Continuous Animal Tracking
https://www.electronics-lab.com/industry-leading-energy-harvesting-technology-e-peas-enables-accurate-continuous-animal-tracking/
Highlighting the huge application potential of the company’s advanced power management ICs (PMICs), e-peas has confirmed that its AEM10941 devices for photovoltaic energy harvesting are being incorporated into tracking equipment employed in Australian cattle ranches. e-peas engineers worked in conjunction with the team at Dutch systems integrator SODAQ on the development and implementation of energy […]
GW16130 Mini-PCIe Satellite Modem for IoT Applications
https://www.electronics-lab.com/gw16130-mini-pcie-satellite-modem-iot-applications/
The GW16130 is a Mini-PCIe Satellite Modem Radio adapter that provides cost-effective, short burst satellite connectivity for asset tracking, fleet management, telemetry, oceanographic data, grid monitoring and Internet of Things (IoT) applications. The GW16130 features an Iridium 9603N satellite transceiver which allows two-way communications anywhere in the world with a clear line of sight to […]
Homebrew DMX-controlled RGB LED light
https://www.electronics-lab.com/homebrew-dmx-controlled-rgb-led-light/
Glen has written an article detailing his homebrew DMX-controlled RGB LED light: This project is a small DMX-512 controlled, color-changing RGB LED light. The light can be controlled via the DMX512 protocol or it can run a number of built-in programs depending on how the software is configured. The light incorporates an advanced 16-bit PIC24 microcontroller with […]
Robo HAT MM1 – An open source robotics and automation controller for Raspberry Pi
https://www.electronics-lab.com/robo-hat-mm1-open-source-robotics-automation-controller-raspberry-pi/
The Robotics Masters Robo HAT MM1 is an open source robotics controller board for Raspberry Pi. It removes the initial barriers to starting any robotics project by providing all the hardware you need in one easy form factor. The wide compatibility with many open source software libraries such as CircuitPython, SeeSaw, and Arduino IDE gives […]
Samsung Galaxy Fold Teardown from ifixit.com
https://www.electronics-lab.com/samsung-galaxy-fold-teardown-ifixit-com/
“Taylor Dixon” did a teardown of Samsung Galaxy Fold and reveals what’s inside for the rest of us. Well, we’ve finally got the Samsung Galaxy Fold on our teardown table. This is, without question, an ambitious first-generation device—the idea of having both a smartphone and a tablet in your pocket at all times is pretty […]
Orange Pi PC 2 – Quad Core 64bit Linux and Android mini PC [Getting Start Guide]
https://www.electronics-lab.com/orange-pi-pc-2-h5-quad-core-64bit-linux-android-mini-pc/
A few time has passed since the addition of Orange Pi PC 2 to the Orange Pi family of SBCs made by Shenzhen Xunlong Software CO., Limited and this successful and high capable board still sales like crazy at $36.65 from various distributors online. Even though this 85×55mm board isn’t as cheap as the $4 […]
AJIT – First-Ever “Made in India” Microprocessor Designed By IIT Bombay
https://www.electronics-lab.com/ajit-first-ever-made-india-microprocessor-designed-iit-bombay/
In this modern era, the electronics industry is incomplete without microprocessors. From daily household appliances to space exploration – microprocessors are accompanying us everywhere and making lives way easier. But, independently designing and manufacturing a processor is an extremely complicated task and done by only a few countries like the US, Italy, France, Japan, Taiwan, […]
Sensirion SVM30 Multi-Pixel Gas Sensor Module
https://www.electronics-lab.com/sensirion-svm30-multi-pixel-gas-sensor-module/
Sensirion SVM30 Multi-Gas, Humidity, and Temperature Sensor Combo Module is ideal for measuring indoor air quality in devices such as air purifiers, air conditioners, and other air treatment products. The SVM30 combo module contains an SGP30 gas sensor as well as an SHTC1 humidity and temperature sensor. The SGP30 multi-pixel gas sensor combines multiple metal-oxide […]
Compulab Airtop3 is bringing performance to the edge
https://www.electronics-lab.com/compulab-airtop3-bringing-performance-edge/
Compulab is introducing Airtop3 – a ruggedized small-form-factor fanless IoT edge server powered by an 8-core Intel® Core™ i9-9900K Processor and Nvidia Quadro RTX 4000, both passively cooled using Compulab’s Natural Airflow technology. With a footprint of just 7.5 liters, Airtop3 can passively dissipate up to 300W and operate at a wide temperature range of […]
