PicoCore MX8MM features i.MX8 Mini and runs Linux
https://www.electronics-lab.com/picocore-mx8mm-features-mx8-mini-runs-linux/
F&S Elektronik Systeme has unveiled its 40 x 35mm “PicoCore MX8MM” module which runs Linux on a quad-A53, 1.8GHz i.MX8 Mini with up to 8GB LPDDR4 and 32GB eMMC plus WiFi/BT, a GbE controller, PCIe, and optional -40 to 85°C support. The PicoCore MX8MM is a i.MX8M variant with lower video resolution, but a faster […]
uChip: Arduino Zero compatible in a narrow DIP-16 package!
https://www.electronics-lab.com/uchip-arduino-zero-compatible-narrow-dip-16-package/
A very small narrow-DIP-sized, Arduino Zero compatible USB dev board (OTG enabled), with integrated buck and boost power supplies! The Arduino ecosystem provides an invaluable resource of hardware and software, which allows quick development of a myriad of projects thanks to its fruitful community. Several Arduino-compatible boards came out in the past years, to increase […]
60V to 5V DC-DC Step-Down Converter using LMR16030
https://www.electronics-lab.com/60v-5v-dc-dc-step-converter-using-lmr16030/
The circuit published here is a compact 60V DC-DC Step down Converter that provides 5V DC output and load current up to 3A in compact size. The project is based on LMR16030. The LMR16030 is a 60 V, 3 A SIMPLE SWITCHER® step down regulator with an integrated high-side MOSFET. With a wide input range […]
https://www.electronics-lab.com/project/60v-5v-dc-dc-step-converter-using-lmr16030/
Latest TySOM Kit Accelerates the Development of AI
https://www.electronics-lab.com/latest-tysom-kit-accelerates-development-ai/
Aldec’s TySOM-3A-ZU19EG embedded system development board, showcased at Embedded World 2019, supports the early co-development and co-verification of hardware and software. Aldec, Inc., a pioneer in mixed HDL language simulation and hardware-assisted verification for FPGA and ASIC designs, has launched the TySOM-3A-ZU19EG, to assist in the development of AI, Deep-learning Neural Network (DNN) and other […]
3.3” round TFT-LCD module delivers 600 cd/m2
https://www.electronics-lab.com/3-3-round-tft-lcd-module-delivers-600-cd-m2/
Tianma Europe’s TM033XDHG01 display module has been designed for use in applications such as thermometers, manometers where analogue displays are traditionally used. With its high display brightness of 600 cd/m 2, a contrast ratio of 1:800 and a large colour space of 16.7 million colours, the TM033XDHG01 is well suited for outdoor use. The wide […]
Congatec Announces a COM Express Type 7 Modules For The Aircraft Industry
https://www.electronics-lab.com/congatec-announces-com-express-type-7-modules-aircraft-industry/
A new milestone is hit by Congatec, as they recently announced Type 7 modules. Congatec has struggled hard to take Linux friendliness to the very next level and to make server response to quickest possible till date. To do that, two Type 7 modules are introduced to the market which provide support of up to […]
Programming Arduino on Visual Studio Code Editor with Platform.io or Arduino extension
https://www.electronics-lab.com/programming-arduino-visual-studio-code-editor-platform-io-arduino-extension/
The Arduino IDE is a great programming tool, it is simple to use and it contains probably all resources one will need to build a project, but evaluating it as a code editor, it is a not the perfect tool. It lacks programming aiding features like IntelliSense, code suggestions, auto-complete, auto-correct, and debug tools, which […]
Low-power IBQ800 Qseven CPU Module from IBASE with extended temperature range
https://www.electronics-lab.com/low-power-ibq800-qseven-cpu-module-ibase-extended-temperature-range/
iBASE Technology Inc, a leader in the manufacture of industrial motherboards and embedded systems, is proud to announce the highly integrated IBQ800 low-power CPU module powered by an Intel® Atom™ x7-E3950 @2.0GHz or x5-E3930 @1.8GHz processor. Designed to operate at extended temperatures ranging from -40°C to +85°C, the IBQ800 is suitable for use in industrial […]
NXP Launches i.MX RT Crossover MCU for Alexa Voice Service
https://www.electronics-lab.com/nxp-launches-mx-rt-crossover-mcu-alexa-voice-service/
NXP’s MCU-based solution for Amazon’s Alexa Voice Service (AVS) leverages the i.MX RT crossover processor, enabling developers to quickly and easily add Alexa voice assistant capabilities to their products. This ultra-small form-factor, turnkey hardware design comes completely integrated with Amazon qualified software for an out of the box AVS experience. NXP’s production-ready solution is a […]
