RGB UV IR light sensor is under 1x2mm
https://www.electronics-lab.com/rgb-uv-ir-light-sensor-1x2mm/
STMicroelectronics, a global semiconductor leader serving customers across the spectrum of electronics applications, has released an innovative full-color ambient light sensor (ALS) that helps smartphones take better pictures and present more visually accurate data on screen displays. By simultaneously providing scene color temperature, ultra-violet (UVA) radiation level, and lighting frequency information, the VD6281 lets the […]
Twelve PWM outputs from an ATtiny85
https://www.electronics-lab.com/twelve-pwm-outputs-attiny85/
This project describes how to get 12 analogue PWM outputs from an ATtiny85, so you can drive 12 LEDs with individual control over each LED’s brightness. David Johnson-Davies writes: Each LED can be set to a brightness between 0 (off) and 63 (fully on). The demonstration program shows a rotating wave of light that moves […]
OMRON Optical Air Quality Sensor
https://www.electronics-lab.com/omron-optical-air-quality-sensor/
Omron’s B5W-LD0101-1 is a High Sensitive and Compact Air Quality Sensor with 5V output. Overview Highly sensitive and compact air quality sensor Detection of particles down to 0.5 µm in diameter is possible while using an LED light source Features a unique flow path structure that efficiently sucks in air Small in size thanks to […]
NERO-SP1 – Arduino UNO Compatible Board
https://www.electronics-lab.com/nero-sp1-arduino-uno-compatible-board/
ATmega328, FT231X NerO – MCU 8-Bit AVR Embedded Evaluation Board. This is the NERO-SP1, an Arduino compatible module with short shield pin. This Nero module is a reference design for an energy efficient Arduino UNO compatible board based on the ATMEGA328 with the FTDI FT231X USB- UART delivers 5V at a full 1A without overheating. […]
LE-37M – 3.5″ Miniboard with Intel® 8th Gen Core™ H-series Processor
https://www.electronics-lab.com/le-37m-3-5-miniboard-intel-8th-gen-core-h-series-processor/
Taiwan Commate Computer Inc.(COMMELL), the worldwide leader of Industrial Single Board Computers, unveiled LE-37M 3.5 inch Miniboard embedded system board based on 8th generation Intel® Core™ H-series processors. The LE-37M 3.5 inch Miniboard platform is designed for the 8th generation Intel® Core™ H-series processors in the FCBGA1440 sockets.support DDR4 memory (Two DDR4 SO-DIMM 2666 MHz up to 32GB). The platform is based on Intel® UHD Graphics, this GPU […]
Texas Instruments ebook – LDO Basics
https://www.electronics-lab.com/texas-instruments-ebook-ldo-basics/
Power management is a fundamental block for all electronic systems. Without it, smartphones, computers and many other electronics we know today would not be possible. With the additional portability, computational power and the myriad of sensors implemented today comes the necessity to scrutinize power management design. The influx of scrutiny for power designs to meet […]
The WiFi 5 and Bluetooth 5 Board Now Available – Ivy5661 IoT Board
https://www.electronics-lab.com/wifi-5-bluetooth-5-board-now-available-ivy5661-iot-board/
A few months ago, in November 2018, we talked about the possibility of combining both WiFi 5 and Bluetooth 5 into one board. The UNISOC UWP5661 was a chip that could make that possible and the same chip powers the IVY5661 96Boards IoT board. At the time of posting about the IVY5661 board and the relatively unknown WiSoC chip […]
KEMET – Pyroelectric Infrared Sensors
https://www.electronics-lab.com/kemet-pyroelectric-infrared-sensors/
KEMET’s pyroelectric infrared sensors (PL series) are unobtrusive sensors that contribute to set designs. KEMET’s pyroelectric infrared sensors use the pyroelectric effect of ceramic by absorbing the infrared rays emitted from the human body. This detects the infrared signature naturally emitted by humans. It can detect infrared rays without using lenses. Due to the absence […]
AI Enabled RICO-3399: Power and Flexibility that Fits
https://www.electronics-lab.com/ai-enabled-rico-3399-power-flexibility-fits/
Pico-ITX Fanless Board with Rockchip ARM Dual-Core Cortex-A72 and Quad-Core Cortex-A53 AAEON, an award winning developer of AI hardware and a leader in industrial embedded solutions, releases the RICO-3399, a powerful PICO-ITX single-board computer that is built for AI applications and high-resolution displays. It features the Rockchip RK3399 ARM hexa-core processor, 4K Ultra HD video […]
ACEINNA Launches Industry’s First High Accuracy Current Sensors based on AMR Technology
https://www.electronics-lab.com/aceinna-launches-industrys-first-high-accuracy-current-sensors-based-amr-technology/
ACEINNA today announced its new MCx1101 family of ±5A, ±20A, and ±50A Current Sensors for industrial and power supply applications. The first high accuracy wide bandwidth AMR-based current sensors on the market, units and evaluation boards are available now for sampling and volume shipments. Our new integrated, AMR based Current Sensor family provides the best […]
