Security Module for Raspberry Pi
https://www.electronics-lab.com/security-module-raspberry-pi/
Security Module for Raspberry Pi. Easy to integrate. Hard to penetrate. Zymkey secures all your digital assets from cyber-physical threats. Raspberry Pi is no longer just the purview of educational establishments and hobbyists; Pis of all flavors, and in particular Raspberry, have graduated to commercial applications with millions deployed in the field and many more […]
Highly integrated gateway module speeds LoRa deployments
https://www.electronics-lab.com/highly-integrated-gateway-module-speeds-lora-deployments/
The release of the LBAA0ZZ1QM (US) & LBAA0ZZ1TY (EU) LoRa Pico Gateway 14-pin metal-shielded module has been announced by Murata. Supporting eight channels and available in two variants for use in either EU or US ISM bands, this ultra compact module measures just 55.0×21.0x3.4mm.  Designed as a single substrate low cost module that can enable […]
Extended battery life in portable devices with new low Iq LDO
https://www.electronics-lab.com/extended-battery-life-portable-devices-new-low-iq-ldo/
Extending battery life in portable devices up to four times longer than traditional ultra-low quiescent (Iq) LDOs, Microchip has announced a linear Low Dropout (LDO) regulator. With an ultra-low Iq of 250nA versus the approximate 1uA operation of traditional devices, the MCP1811 LDO reduces quiescent current to save battery life, enabling end-users to recharge or replace batteries less often. […]
Weller soldering station for less than 150€
https://www.electronics-lab.com/weller-soldering-station-less-150e/
New soldering station WE1010 proves that even a very decent station can be available at an affordable price. It´s primarily designed for schools, students, demanding hobbyists, developers etc. Having a reliable Weller station without paying more than 150 Euro (excl. VAT) sounds quite good, doesn´t it? It´s true that a decent soldering station from less […]
Modules offer both Wi-Fi and dual-mode Bluetooth at the same time
https://www.electronics-lab.com/modules-offer-wi-fi-dual-mode-bluetooth-time/
u-blox announces multiradio and gateway modules with concurrent Wi-Fi and dual-mode Bluetooth connectivity. The NINA‑W15 module series offers much design versatility, built‑in security, and proven software support. Thalwil, Switzerland – October 24, 2018 – u‑blox (SIX:UBXN), a global provider of leading positioning and wireless communication technologies, has announced the NINA‑W15 multi-radio and gateway module series, which can […]
Inexpensive chip-based device may transform spectrometry
https://www.electronics-lab.com/inexpensive-chip-based-device-may-transform-spectrometry/
Tiny device could replace expensive lab-scale equipment for many applications. Spectrometers — devices that distinguish different wavelengths of light and are used to determine the chemical composition of everything from laboratory materials to distant stars — are large devices with six-figure price tags, and tend to be found in large university and industry labs or […]
TourBox – The Ultimate Controller For Photoshop And Lightroom
https://www.electronics-lab.com/tourbox-ultimate-controller-photoshop-lightroom/
Tour Technology is a group of tech engineers and designers working together to make innovative products for designers and creators. After several years of research and development, they created an advanced controller with customized creative inputs to simplify and optimize control of Photoshop, Lightroom, and other software. TourBox is the advanced creative controller for Photoshop, Lightroom, SAI, […]
uMesh – A self-contained, battery operated ESP32 module
https://www.electronics-lab.com/umesh-self-contained-battery-operated-esp32-module/
Jarrett published a new project. It is a battery powered ESP32 module. I’ve been working on an ESP32 module. Part of the problem I’ve been seeing with inexpensive IoT dev boards, is that the design around the power system hasn’t been very good. Here’s my attempt to fix that. This is a battery-ready module with […]
Using NXP’s NXQ1TXH5 Qi Charging Circuit
https://www.electronics-lab.com/using-nxps-nxq1txh5-qi-charging-circuit/
Adding wireless charging to furniture and other consumer goods is a nice way to add some oomph to an otherwise boring product. NXP’s NXQ1TXH5 provides an interesting, albeit difficult-to-prototype way around the problem. Creating a Qi-compatible is as easy as assembling the example circuit shown in figure one. From a technical point of view, the […]
Evaluation board for STSPIN820 stepper motor driver
https://www.electronics-lab.com/evaluation-board-stspin820-stepper-motor-driver/
The EVALSP820-XS is a compact and easy to use evaluation board for the STSPIN820, the world’s smallest 45 V microstepping motor driver rated at 2.5 A. It provides a very compact solution to evaluate the performance of the STSPIN820 stepper motor driver with a minimum set of additional equipment and without the need of additional […]
