Infrared Temperature Sensor Array using AMG8833
https://www.electronics-lab.com/infrared-temperature-sensor-array-using-amg8833/
The Grove – Infrared Temperature Sensor Array (AMG8833) is a high precision infrared array sensor which based on advanced MEMS technology. It can support temperature detection of two-dimensional area: 8 × 8 (64 pixels) and maximum 7 meters detection distance. We provide both Arduino and Raspberry Pi demo for this sensor. It will be a […]
NXP’s MMA8451QR1 Accelerometer
https://www.electronics-lab.com/nxps-mma8451qr1-accelerometer/
Process computer designs usually start out with an accelerometer. As reliability problems creep in, making the switch to a more “professional” solution is beneficial. Accelerometers are based on the MEMS principle: instead of being a purely solid-state affair, the inside of the chip contains a micromechanical motion sensor along with a small mass. In addition […]
Avalue’s ECM-CFS SBC Sports Intel’s Coffee Lake Processor
https://www.electronics-lab.com/avalues-ecm-cfs-sbc-sports-intels-coffee-lake-processor/
Avalue recently announced a Linux-friendly 3.5″ ECM-CFS Single Board Computer with a choice of Intel’s latest 8th Gen “Coffee Lake” S-series processors. It also features triple display support, 2x GbE, 4x USB 3.1, 2x SATA, and mSATA. This SBC is considered as the world’s first 3.5-inch SBC to feature Intel’s 8th Gen “Coffee Lake” processors. Avalue’s 146 […]
Pi Supply LoRa Boards Run on Raspberry Pi, Arduino and Micro:bit
https://www.electronics-lab.com/pi-supply-lora-boards-run-raspberry-pi-arduino-microbit/
Pi Supply has launched a new series of IoT LoRa Boards on Kickstarter that work with Raspberry Pi, and Micro:bit. They include an IoT LoRa Gateway HAT board with a price of £120 ($157) and a LoRa Node pHAT node board for £25 ($33) price. The boards support any 40-pin Raspberry Pi, and they may […]
Credit Card Sized HMI Development Hardware
https://www.electronics-lab.com/credit-card-sized-hmi-development-hardware/
Coinciding with the BT815 and BT816 advanced graphics controller ICs being ramped up into volume production, Bridgetek has introduced a series of accompanying entry-level development modules. Supporting a range of different display configurations, the compact (54.1mm x 85.60mm) VM816C modules each feature a BT816 device. Through these items, engineers will be able to utilise the […]
Using Ferrite Beads for Ringing Control in Switching Converters
https://www.electronics-lab.com/using-ferrite-beads-ringing-control-switching-converters/
“Ringing” is a common term referring to the undesired oscillation that occurs when a power semiconductor switch turns on or off in the presence of parasitic inductance and capacitance. Energy stored in the parasitic junction capacitance of the switch is released during the switching transition and rings with parasitic inductance coming from the stray fields […]
FLIR Boson Camera Frame Grabber using FPGA
https://www.electronics-lab.com/flir-boson-camera-frame-grabber-using-fpga/
Simple FPGA based PCB to capture thermal images from a FLIR Boson camera on to a microSD. The project’s sources are available on Github. by Greg Davill A small PCB designed to attach to the backside of the FLIR Boson Thermal Camera. The PCB facilitates configuration of the camera along with capturing data to an […]
The 10 Trillion FPS Camera Captures Light In Slow Motion
https://www.electronics-lab.com/10-trillion-fps-camera-captures-light-slow-motion/
Light moving in vacuum is the fastest thing in the universe. Scientists have tried many times before to catch it on the move with some success. This time a new equipment built by Caltech scientists pulls down a mind-blowing 10 trillion frames per second, meaning it can capture light as it travels along, and also they are […]
CubieBoard9 – An Actions S900 SoC Based SBC With 2x HDMI
https://www.electronics-lab.com/cubieboard9-actions-s900-soc-based-sbc-2x-hdmi/
CubieTech recently announced a new SBC CubieBoard9 on their product page. This SBC is yet unpriced and also not reached the CubieBoard.org community website. CubieBoard9 features a quad A53 Actions S900 SoC, 3GB LPDDR3, 16GB eMMC, WiFi/BT, and dual independent displays with HDMI, MIPI-DSI, LVDS, and eDP. Back in 2014, CubieTech announced Allwinner A80 based CubieBoard8 […]
Εfficient Wireless Li-Ion Charger with Regulator Optimized for Low Power Wearables
https://www.electronics-lab.com/%ce%b5fficient-wireless-li-ion-charger-regulator-optimized-low-power-wearables/
Analog Devices announces the Power by Linear™ LTC4126, which expands its offerings in wireless battery charging. The LTC4126 combines a wireless powered battery charger for Li-Ion cells with a high efficiency multi-mode charge pump DC/DC converter, providing a regulated 1.2V output at up to 60mA. Charging with the LTC4126 allows for a completely sealed end […]
