Mini DC/DC converters integrate coil
https://www.electronics-lab.com/mini-dc-dc-converters-integrate-coil/
Torex Semiconductor’s XCL223 and XCL224 series of step-down converters pack an inductor and control IC in a single 2.25×1.5×0.75-mm package, simplifying board layout. Despite their miniaturization and reduced height, the synchronous converters deliver an output current of 400 mA or 700 mA. by Susan Nordyk  @ edn.com: An operating voltage range of 2.5V to 5.5V […]
Hands-on with the PocketBeagle
https://www.electronics-lab.com/hands-on-with-the-pocketbeagle/
Ken Shirriff shares his experience with a low-cost, compact Linux computer PocketBeagle: The PocketBeagle is a tiny but powerful inexpensive key-fob-sized open source Linux computer. It has 44 digital I/O pins, 8 analog inputs, and supports multiple serial I/O protocols, making it very useful as a controller. In addition, its processor includes two 200-MHz microcontrollers that […]
Flight controller unit evaluation board for drones
https://www.electronics-lab.com/flight-controller-unit-evaluation-board-drones/
The STEVAL-FCU001V1 board from ST is designed to support quadcopter drone designers with the latest solutions for motor control, sensors and and microcontroller. A complete sample FW project allows the designer to begin flying small and medium size quadcopters (with brushed or brushless DC motors) immediately and evaluate the performance of the IMU sensors under […]
Le Potato: Fastest 4K SBC under $50 for Makers
https://www.electronics-lab.com/le-potato-fastest-4k-sbc-50-makers/
Le Potato Single Board Computer – Raspberry Pi Form Factor, 2GB RAM, HDMI 2.0, eMMC, Latest Android 7.1 Nougat, and Linux 4.9 LTS.The project is already funded and you can order your unit now. Our first Libre Computer Board, code name Le Potato, is designed as a drop in hardware replacement for the Raspberry Pi […]
Renegade ARM Computer with USB 3 on Android Linux
https://www.electronics-lab.com/renegade-arm-computer-usb-3-android-linux/
Libre Computer launched a campaign about it’s open source, $35 “Renegade” SBC which is a Raspberry Pi clone that runs Linux or Android 7.1 on a Rockchip RK3328 with up to 4GB DDR4. They claim to be the first SBC with up to 4GB of DDR4, 4K, Gigabit Ethernet, and USB 3.0 for the ultimate […]
USB To 12V Boost Converter
https://www.electronics-lab.com/usb-12v-boost-converter/
This project provides 12V output from any USB power source, like PC USB port, USB adapter or power banks. LM2577ADJ boost converter IC is the heart of the project. The IC can handle load up to 800mA, it’s advisable to use only 200mA load on output to be on the safe side. The LM2577 are […]
USB To 12V Boost Converter using LM2577
https://www.electronics-lab.com/project/usb-12v-boost-converter/
Open-Source NB-IoT Shield for Arduino
https://www.electronics-lab.com/open-source-nb-iot-shield-arduino-2/
This completely open-source LTE shield uses the latest and greatest CAT-M NB-IoT technology optimized for low-power IoT devices! by Timothy Woo @ hackster.io: With the emergence of low-power IoT devices with cellular connectivity and the phase-out of 2G (with only T-mobile supporting 2G/GSM until 2020), everything is moving toward LTE and this has left many […]
Tomu – An ARM board which fits inside your USB connector
https://www.electronics-lab.com/tomu-arm-board-fits-inside-usb-connector/
Tomu is a programmable computer that is so small that can fit entirely inside a computer’s USB port. It sticks out just a little bit, enough to allow you to press one of the two buttons on it’sy side. It also have two LED lights, to let you know what I’m up to. The project […]
5.25″ SBC with Intel Kaby Lake or Xeon CPU
https://www.electronics-lab.com/5-25-sbc-intel-kaby-lake-xeon-cpu/
The new LS-579 announced by BVM Limited is one of the most powerful SBCs available in the compact 5.25” embedded form factor. With outstanding computing power from the latest generation processors, comprehensive I/O capability, four SATAIII mass storage interfaces and supporting up to 32GB of DDR4 DRAM, the LS-579 is optimised for use as a […]
