How to drive Nokia 5110 84×48 LCD display with Arduino
https://www.electronics-lab.com/drive-nokia-5110-84x48-lcd-display-arduino/
In the previous tutorial I showed how to build a weather station using DHT11 and BMP180 with an Arduino. However, the project has a downside which is the power consumption of the 16X2 LCD. If we were building a battery powered project with the desire to last for several weeks and probably several months, like […]
https://www.electronics-lab.com/project/drive-nokia-5110-84x48-lcd-display-arduino/
Introduction In the previous tutorial I showed how to build a weather station using DHT11 and BMP180 with an Arduino. However, the project has a downside which is the power consumption of the 16X2 LCD. If we were building a battery powered project with the desire to last for several weeks and probably several months, […]
Atmel ATmega8 – A World-Famous Microcontroller Created By Two Annoyed Students
https://www.electronics-lab.com/atmel-atmega8-world-famous-microcontroller-created-two-annoyed-students/
AVR is a family of microcontrollers developed by Atmel beginning in 1996. These are modified Harvard architecture 8-bit RISC single-chip microcontrollers. The Atmel AVR core combines a rich instruction set with 32 general purpose working registers. Atmel’s ATmega8 comes from the AVR line of microcontroller and it is a gem of the modern maker movement. It is used as […]
CH340E, A New Small Serial to USB Chip
https://www.electronics-lab.com/ch340e-new-small-serial-usb-chip/
WCH, a Chinese integrated circuits manufacturer, has just released a new serial to USB chip called CH340E. Unlike other CH340 chips, it doesn’t require an external crystal and also needs less PCB space and BOM. CH340 is a 3x3mm tiny chip comes in MSOP10 package and has 10 pins. Although it is smaller than other alternatives, it is […]
Using an ATmega328 without a crystal
https://www.electronics-lab.com/using-atmega328-without-crystal/
Here is another guide from David Johnson-Davies @ technoblogy.com explaining how to program an ATmega328 on a breadboard using the Arduino IDE. The guide is focused on how to use the internal clock of the microcontroller and how to achieve this using the Arduino environment. By default Arduino IDE doesn’t include a Boards option for an […]
Programmable Power Supply Using OPA548
https://www.electronics-lab.com/programmable-power-supply-using-opa548/
Project provides 1.2 to 20V DC output with current limiter adjustable to 0-5A. I have tested the circuit with 250mA output without a heat sink. Project is capable to drive 3A continues load and 5A peak, large size heat sink required for full load. The tiny power supply based on low cost OPA548 high-voltage and […]
https://www.electronics-lab.com/project/programmable-power-supply-using-opa548/
Bomist – Parts Inventory and BOM Management for Electronics
https://www.electronics-lab.com/bomist-parts-inventory-bom-management-electronics/
It all started a few years ago with Component Organizer, than BOMER and it’s now called BOMIST. The software runs locally, so no server nor setup required and you can have as many databases as you want (just run as many instances of BOMIST as you want). Additionally, it is integrated with Octopart, meaning you […]
Proto Board Power Supply
https://www.electronics-lab.com/proto-board-power-supply/
David Johnson-Davies @ technoblogy.com build a breadboard friendly power supply to power your Arduino or other low power electronics. The power supply is able to deliver 0V to 5.5V at up to 0.5A and it’s powered from two Li-Ion rechargeable batteries. The output can be adjusted using a rotary encoder, and the voltage is displayed on a […]
72 Channels Serial To Parallel Driver Board Using 74HC595 & ULN2803
https://www.electronics-lab.com/72-channels-serial-parallel-driver-board-using-74hc595-uln2803/
72 channels Serial (SPI) to parallel driver board has been designed for various applications. This project can be used as multi Solenoid driver, large size 7 segment display driver, bar graph driver, and LED driver. The project works with 5V logic levels. Output load supply 12V-48V DC and each output can drive 500mA load. I […]
