OwnCloud on Raspberry Pi
https://www.electronics-lab.com/owncloud-raspberry-pi/
Install OwnCloud on Raspberry Pi And make your own cloud server. OwnCloud set on Raspberry Pi can be a good example of smart cloud storage. A cloud storage is a cloud computing model in which the data is stored on remote servers and maintained by a cloud storage service provider. This allows users to customize […]
Researchers Developed New Efficient, Thin, and Flexible Cooling Device
https://www.electronics-lab.com/researchers-developed-new-efficient-thin-flexible-cooling-device/
Engineers and scientists from the UCLA Henry Samueli School of Engineering and Applied Science and SRI International, California, have created a thin flexible device that could keep smartphones and laptop computers cool and prevent overheating. The component is based on the electrocaloric effect – a phenomenon where the temperature of material changes when an electric field is applied to it. The […]
Arduino Two-Way Bluetooth Communication Tutorial
https://www.electronics-lab.com/arduino-two-way-bluetooth-communication-tutorial/
Welcome to another Arduino Tutorial! Today we are going to learn how to use Bluetooth to exchange data between two Arduino boards! As a demonstration project, we are going to build a simple weather station. There is a lot to cover so let’s get started! Arduino Two-Way Bluetooth Communication Tutorial – [Link]
Design and Implementation of a 12 Lead Portable ECG
https://www.electronics-lab.com/design-implementation-12-lead-portable-ecg/
Alex Lao and his team at McMaster University have developed a compact, battery powered, 12-lead electro-cardiogram: During the academic year of 2016-2017 at McMaster University, in conjunction with Dr. DeBruin, Christina Riczu, Thomas Phan and Emilie Corcoran, we developed a compact, battery powered, 12-lead electro-cardiogram. The project won 1st place in the biomedical category at […]
Haasoscope – Cheap, flexible, data acquisition for all!
https://www.electronics-lab.com/haasoscope-cheap-flexible-data-acquisition/
Haasoscope is the first open-source, open-hardware, flexible, small, cheap, oscilloscope and data-acquisition board. You can use the stock firmware for basic oscilloscope functionality, or modify the firmware to customize what the Haasoscope does. Preliminary features and specifications: 4 x 100 MHz, 8-bit ADC channels with BNC cable inputs Altera Max10 FPGA with 8k logic elements […]
Arduino Weather Station using DHT11
https://www.electronics-lab.com/arduino-weather-station-using-dht11/
Using a display to view the temperature and humidity of your environment can be possible using the DHT11 or DHT22 sensor with the easy to use Arduino microcontroller platform and that’s the goal of this project. For this project, we will be using the 16×2 LCD display module to display the temperature and humidity readings […]
https://www.electronics-lab.com/project/arduino-weather-station-using-dht11/
Introduction Using a display to view the temperature and humidity of your environment can be possible using the DHT11 or DHT22 sensor with the easy to use Arduino microcontroller platform and that’s the goal of this project. For this project, we will be using the 16×2 LCD display module to display the temperature and humidity […]
Teardown, Repair & Analysis of an Agilent E4443A 3Hz – 6.7GHz PSA Series Spectrum Analyzer
https://www.electronics-lab.com/teardown-repair-analysis-agilent-e4443a-3hz-6-7ghz-psa-series-spectrum-analyzer/
In this episode Shahriar repairs an Agilent PSA Series Spectrum Analyzer. The instrument generates many errors during self-alignment and produces no measurements below 3.2GHz. The block diagram of the unit is thoroughly presented and various possible failure points are considered. Based on the observation of the noise floor, the most likely cause is the second […]
Decoding and Encoding JSON with Arduino or ESP8266
https://www.electronics-lab.com/decoding-encoding-json-arduino-esp8266/
In this blog post you’re going to learn how to decode (parse a JSON string) and encode (generate a JSON string) with the ArduinoJson library using the Arduino with the Ethernet shield. This guide also works with the ESP8266 and ESP32 Wi-Fi modules with small changes. Decoding and Encoding JSON with Arduino or ESP8266 – […]
Electronics Cheat Sheet Poster
https://www.electronics-lab.com/electronics-cheat-sheet-poster/
A quick reference in learning and debugging your electronics projects. Click to “download” the full resolution image + a bonus poster. or download ZIP file. “Amirhossein Amini” has re-designed the above poster in Corel Draw and the source file can be downloaded here or PDF download.
