AS7261 Color sensor from Ams
https://www.electronics-lab.com/as7261-color-sensor-ams/
The AS7261 integrates Gaussian interference filter technology to enable chromatic white color sensor which provides direct XYZ color coordinates consistent with the CIE 1931 2° Standard Observer color coordinates. Additional mapping of XYZ coordinates to the x, y (Y) of the 2-dimensional color gamut and scales of the CIE 1976 u’v’ coordinate system, providing accurate […]
Meet Obsidian, A $99 Plug & Print 3D Printer
https://www.electronics-lab.com/meet-obsidian-99-plug-print-3d-printer/
Kodama Inc is a new company that delivers a new generation of FDM 3D printers that increase the possibility of affordable 3D printing. Recently, Kodama launched its new 3D printer “Obsidian“, the first 3D printer made for professional applications starting at under $100. Most additive manufacturing machines in this price range are not aesthetically designed, nor engineered for […]
Nixie Bargraph Kit
https://www.electronics-lab.com/nixie-bargraph-kit/
Robin @ kickstarter.com launched his new campaign on a project using IN-9 Nixie tubes. Now you can easily control two IN-9 Nixie bargraph tubes with 2 PWM inputs from your Arduino, Raspberry or other control board. The tubes are controlled by PWM signals and adjusting the PWM duty cycle you can control the tubes height, […]
µduino, The Smallest Arduino Ever
https://www.electronics-lab.com/%c2%b5duino-smallest-arduino-ever/
A new member to Arduino compatible devices is just here, the newest yet the smallest Arduino ever created, µduino!Believing that it is enough to include some bulky devices in our applications, the team behind µduino is trying to provide a shrinkified device that can be included anywhere. With the size of 12mm (0.5 inches) x 12mm, µduino is […]
The First 3D Quantum Liquid Crystals
https://www.electronics-lab.com/first-3d-quantum-liquid-crystals/
Strong electron interactions can drive metallic systems toward a variety of well-known symmetry-broken phases, but the instabilities of correlated metals with strong spin-orbit coupling have only recently begun to be explored. A team of physicists at the Institute for Quantum Information and Matter at Caltech, had discovered an new state of matter that may have applications […]
Electrolytic + polymer = the hybrid capacitor
https://www.electronics-lab.com/electrolytic-polymer-hybrid-capacitor/
Electrolytic capacitor is often a common reason for device failure and replacement is necessary. But what if we could combine the benefits of electrolytics and polymer capacitors. Now you can have the best of both worlds: hybrid capacitors from have been designed to combine the advantages of electrolytic capacitors with those of solid polymer capacitors. […]
USB 3.0 NanoHub
https://www.electronics-lab.com/usb-3-0-nanohub/
Muxtronics @ tindie.com designed a USB 3.0 mini hub. Source files here: Are you familiar with my NanoHubs? Tiny, penny-sized USB hubs you can use to add additional USB ports in incredibly cramped spaces, like hacking projects or mobile devices? Whereas the original NanoHubs were all USB 2.0, limited to 480Mbps, this new NanoHub allows […]
ESP32 Monster board, Ether, CAN, OLED all in one
https://www.electronics-lab.com/esp32-monster-board-ether-can-oled-one/
ESP32 monster board with Ether(LAN8720A), CAN bus(SN65HVD232DR), OLED(SH1106), Lipo-charger and FTDI interface @ tindie.com ESP32 Monster board, Ether, CAN, OLED all in one – [Link]
Opensource USB HUB
https://www.electronics-lab.com/opensource-usb-hub/
Christian @ hackaday.io build his own USB Hub based on GL850G IC: I was looking to make a custom USB Hub for a project but I couldnt find any of them that worked and using the chip GL850G. The chip is pretty old and cheap, but in my case I didnt need to use any […]
Store Data in Nanomagnets
https://www.electronics-lab.com/store-data-nanomagnets/
Imagine if a bit of data can be stored in a single atom or a small molecule, then massive volumes of data can be stored in a tiny amount of space. This theory was the topic of a research tries to develop a new method to store data magnetically in atoms. As the magnetization of an atom can […]
