Color sensor achieves high dynamic range with auto exposure
https://www.electronics-lab.com/color-sensor-achieves-high-dynamic-range-auto-exposure/
Massimo Gottardi@ edn.com writes: The Design Idea in Figure 1 is a color detector capable of generating an RGB triplet over a high dynamic range, a useful attribute for machine vision applications. The circuit implements auto-exposure control to achieve this. Thus, RGB values for a subject are invariant over a range of light intensity. Color […]
LT8641 – 65V, 3.5A Synchronous Step-Down Silent Switcher
https://www.electronics-lab.com/lt8641-65v-3-5a-synchronous-step-silent-switcher/
The LT8641 is a monolithic, constant frequency, current mode synchronous (external schottky diode is not necessary) step-down switching regulator. Its 3V to 65V input voltage range makes it ideal for 12V or 24V automotive and industrial applications. It delivers up to 3.5A of continuous output current and peak loads of 5A. Output voltages can be […]
Teardown of a TDA7375 audio amplifier IC
https://www.electronics-lab.com/teardown-tda7375-audio-amplifier-ic/
A teardown of a TDA7375 audio amplifier IC from Electronupdate: The TDA7375 audio power amplifier. Another example of a long-lived integrated circuit. 1st introduced in 1998… looks like it’s still being made. Teardown of a TDA7375 audio amplifier IC – [Link]
Magic Mote MSP430G2553 wireless sensor node with NRF24L01+ module
https://www.electronics-lab.com/magic-mote-msp430g2553-wireless-sensor-node-nrf24l01-module/
Tom from Magic Smoke writes: This is my first time designing a PCB for MSP430. I really like the NRF24L01+ booster pack but I would like something smaller to use for remote temperature sensors. With that in mind I’ve designed a 24.5 x 50 mm PCB (2 on a 5×5 cm prototype) featuring MSP430G2553 and […]
Cortex-M-based MCUs Set Pace For Automotive Design
https://www.electronics-lab.com/cortex-m-based-mcus-set-pace-automotive-design/
AUTomotive Open System Architecture (AUTOSAR) is a worldwide automotive consortium trying to create and establish an open and standardized software architecture for automotive electronic control units (ECUs). However, as is always the case with industry consortiums and standards, they are not endorsed by all interested parties, and, to complicate matters even more, not all applications […]
Sensirion solves long-standing stability problem in metal-oxide gas sensors
https://www.electronics-lab.com/sensirion-solves-long-standing-stability-problem-metal-oxide-gas-sensors/
At this year’s Sensor+Test 2017 in Nuremberg (May 30 – June 1), Sensirion AG, the expert in environmental and flow sensor solutions, introduces the SGP – a siloxane resistant metal-oxide gas sensor with unprecedented long-term stability. The SGP gas sensor is based on Sensirion’s multi-pixel platform, which integrates four gas sensing elements into a very […]
Arduino RFID Keycard Access
https://www.electronics-lab.com/arduino-rfid-keycard-access/
Use the PN532 NFC available on the anduinoWiFi shield to create an RFID keycard building access system. by Brian Carbonette @ hackster.io Arduino RFID Keycard Access – [Link]
2.5V to 36V, 2.5MHz, PWM Boost Controller with 4μA Shutdown Current
https://www.electronics-lab.com/2-5v-36v-2-5mhz-pwm-boost-controller-4%ce%bca-shutdown-current/
by Graham Prophet @ eedesignnewseurope.com: Maxim Integrated has posted details of the MAX17290/MAX17292 high-efficiency, synchronous step-up DC-DC controllers, that operate over a 4.5V to 36V input voltage range with 42V input transient protection and feature reduced EMI. The input operating range can be extended to as low as 2.5V in bootstrapped mode. 2.5V to 36V, […]
How to Make Your Own ARDUINO UNO Board
https://www.electronics-lab.com/make-arduino-uno-board/
Being Engineers @ instructables.com writes: Hello guyz, Welcome to Being Engineers. Hope you all are doing good. In this tutorial we will learn how to make your own Arduino Uno. We will gather the components, test the circuit in breadboard, then we will make the board itself. When it is done we will know how […]
DIY Arduino Soldering Station
https://www.electronics-lab.com/diy-arduino-soldering-station/
GreatScottLab @ instructables.com writes: In this project I will show you how to create an Arduino based soldering station for a standard JBC soldering iron. During the build I will talk about thermocouples, AC power control and zero point detection. Let’s get started! DIY Arduino Soldering Station – [Link]
