thepilocator.com – check the availability of Raspberry Pi
https://www.electronics-lab.com/thepilocator-com-check-availability-raspberry-pi/
ThePiLocator is a website aims to help you check the availability of pi zero and pi zero w on various online stores. thepilocator.com – check the availability of Raspberry Pi – [Link]
LT8315 – 560VIN Micropower No-Opto Isolated Flyback Converter
https://www.electronics-lab.com/lt8315-560vin-micropower-no-opto-isolated-flyback-converter/
The LT8315 is a high voltage monolithic flyback regulator that simplifies the design of an isolated DC/DC converter. By sampling the reflected isolated output voltage across the third winding on the power transformer, the part requires no opto-isolator or LT1431 for regulation. The LT8315 operates over an 18V to 560V input voltage range, has a […]
Educational Biomed Shield for Arduino 101
https://www.electronics-lab.com/educational-biomed-shield-arduino-101/
Orlando Hoilett has built his new biomedical Arduino 101 shield: Biomed Shield, in order to allow students, educators, and hobbyists to learn about bio-medicine by monitoring heart rate, temperature, and other physiological metrics. To build this shield he used the following components: AD5933 MLX90614 Microchip Rail-to-Rail Input/Output Dual Op-Amp MAX30101: a specialized integrated circuit that is able […]
Making the Electronics for CDM324 – 24GHz Doppler Motion Sensor
https://www.electronics-lab.com/making-electronics-cdm324-24ghz-doppler-motion-sensor/
limpkin @ limpkin.fr tries out the CDM324 / IPM165 Doppler effect sensor and proposes an amplification circuit to get the readings out of the sensor. He writes: You may recall the article I wrote a couple of years ago about a nearly identical Doppler sensor, the HB100. While the HB100 is using a 10.525GHz frequency, […]
Arduino MKRFOX1200
https://www.electronics-lab.com/arduino-mkrfox1200/
MKRFOX1200 is a powerful board that combines the functionality of the Zero and SigFox connectivity. It is the ideal solution for makers wanting to design IoT projects with minimal previous experience in networking having a low power device. Arduino MKRFOX1200 has been designed to offer a practical and cost effective solution for makers seeking to […]
10 or 12-bit DAC from the ATtiny85
https://www.electronics-lab.com/10-12-bit-dac-attiny85/
David Johnson-Davies @ technoblogy.com writes: This article describes how to get up to two 10 or 12-bit digital-to-analogue outputs from an 8-bit Timer/Counter, such as in the ATtiny85. To test the routine I built a circuit which allows you to vary the brightness of two LEDs with two potentiometers: 10 or 12-bit DAC from the […]
Arduino analogue thermometer
https://www.electronics-lab.com/arduino-analogue-thermometer/
Clinton Matos @ htxt.co.za writes: With so many projects being made with the Arduino, we’ve seen a fair share of thermometer projects that try to do something different. This version, by educ8s.tv, does so by adopting an older look. Arduino analogue thermometer – [Link]
NanoPi NEO kit lets you build your own network-attached storage system for about $30
https://www.electronics-lab.com/nanopi-neo-kit-lets-build-network-attached-storage-system-30/
Brad Linder@ liliputing.com writes: The NanoPi Neo is a tiny computer with a quad-core ARM Cortex-A7 processor, Ethernet and USB ports, and support for a number of accessories. Measuring just 1.6″ x 1.6″ it’s smaller than most Raspberry Pi computers, and with a starting price of $7 it’s also an awfully affordable computer capable of […]
MAX17055 – a 7μA operating current fuel gauge
https://www.electronics-lab.com/max17055-7%ce%bca-operating-current-fuel-gauge/
by Graham Prophet @ eedesignnewseurope.com Maxim Integrated has posted details of a battery charge monitor IC for which it claims the lowest quiescent current available, at 7µA. The 1-cell Fuel Gauge with Maxim’s ModelGauge m5 EZ algorithm can eliminate battery characterization issues. MAX17055 – a 7μA operating current fuel gauge – [Link]
3D Gaming With Raspberry Pi & ExaGear
https://www.electronics-lab.com/3d-gaming-raspberry-pi-exagear/
ExaGear is a virtual machine that implements virtual x86 Linux container on ARM and allows you to run Intel x86 applications directly on ARM. With this software by Eltechs you can run Intel x86 application on your ARM-based Mini PC simultaneously with common native applications. It is like QEMU but 5 times faster! You can even run Windows […]
