4Duino UCAM-II Demo
https://www.electronics-lab.com/4duino-ucam-ii-demo/
by 4D Systems @ instructables.com: The main objective of this project is to show how to interface a uCAM-II serial camera to 4Duino. uCAM-II is a highly integrated micro serial camera which could be controlled by any host that requires a video camera or a JPEG compressed still camera for embedded imaging applications. uCAM-II processes […]
OPT3002 – Light/digital IC provides optical power measurements
https://www.electronics-lab.com/opt3002-lightdigital-ic-provides-optical-power-measurements/
By Graham Prophet @ edn-europe.com: Distributor Mouser Electronics has Texas Instruments’ OPT3002 light-to-digital sensor; the device promises improved system performance over standard photodiodes and photoresistors. The fully-integrated OPT3002 delivers the functionality of an optical power meter all within a single small device. Offering a wide spectral bandwidth, flexible and automated light measuring over a 23-bit […]
A DIY obstacle avoiding robot using an SG90 servo and Ultrasonic Sensor
https://www.electronics-lab.com/diy-obstacle-avoiding-robot-using-sg90-servo-ultrasonic-sensor/
In this video educ8s.tv shows us how to build an Arduino Robot that can avoid obstacles: The robot that we are going to build today is moving around and it can detect obstacles and avoid them. It uses a supersonic distance sensor in order to measure the distance from its front side. When it […]
PV cell string optimizer boosts solar panel output up to 30%
https://www.electronics-lab.com/pv-cell-string-optimizer-boosts-solar-panel-output-30/
Maxim presents its Cell-String Optimizer as the first IC to perform MPPT (maximum power point tracking) at low level in a panel; it allows photovoltaic (PV) panels to harvest significantly more energy and simplifies design complexity for solar installation projects. by Graham Prophet @ edn-europe.com Maxim’s cell-string optimizers are highly integrated DC-DC converters that replace […]
LTC7851 – Quad Output, Multiphase Step-Down Voltage Mode DC/DC Controller with Accurate Current Sharing
https://www.electronics-lab.com/ltc7851-quad-output-multiphase-step-voltage-mode-dcdc-controller-accurate-current-sharing/
The LTC7851 is a quad output multiphase synchronous step-down DC/DC controller with accurate current sharing between phases and differential output voltage sensing. This controller works in conjunction with external power train devices such as DrMOS and power blocks as well as discrete N-channel MOSFETs and associated gate drivers, enabling flexible design configurations. Up to 8 […]
How Boost Converters (DC-DC Step-Up) Works
https://www.electronics-lab.com/boost-converters-dc-dc-step-works/
A look into how boost converters work in a very visual format. Try this circuit: http://goo.gl/nkHq9H How Boost Converters (DC-DC Step-Up) Works – [Link]
Driving 14-segment displays with the MAX6954
https://www.electronics-lab.com/driving-14-segment-displays-max6954/
App note from Maxim on using the MAX6954 to drive 14-segment monocolor LEDs, (PDF): This article is how-to guide, intended as a quick learning aid for engineers considering using the MAX6954 to drive 14-segment monocolor LEDs. The MAX6954 is a versatile display driver, capable of controlling a mix of discrete, 7-segment, 14-segment, and 16-segment LED displays […]
Cheap Arduino Serial Terminal
https://www.electronics-lab.com/cheap-arduino-serial-terminal/
Peter Scargill writes, As it happens I’m experimenting on a 1284 chip which while being Arduino-compatible kind of, it does have another serial port, so without disconnecting my FTDI – I hooked up the second serial port to the home control serial and fired the DEBUG command at the latter. As you can see on […]
Using A Bench Power Supply To Charge Lithium Ion Batteries
https://www.electronics-lab.com/using-bench-power-supply-charge-lithium-ion-batteries/
David Jones has another useful video tutorial about how to safely charge Lithium Ion and Lithium Polymer batteries with a bench power supply. The purpose of this tutorial is to learn how to use your lab power supply to charge your Lithium Ion battery when you don’t have a special charger circuit to do so. […]
Exploring Eagle CAD ULPs #2 – ‘Unrouted.ULP’ Zoom To The Last Left unrouted Wire
https://www.electronics-lab.com/exploring-eagle-cad-ulps-2-unrouted-ulp-zoom-last-left-unrouted-wire/
Welcome to the second post of the “Exploring Eagle CAD ULPs” series. Every week we will publish a new post about one useful ULP in Eagle CAD. “ULP” User Language Program is a plain text file which is written in a C-like syntax and can be used to access the EAGLE data structures and to […]
