LED Based Strobe For Entertainment, Events & Warning Signals
Strobe provides regular flashes of light. Usually Strobes are designed using Xenon Tubes.
Strobe provides regular flashes of light. Usually Strobes are designed using Xenon Tubes. Here is LED based simple solution that can be used as strobe for entertainment and events and also as warning signals. Project is based on PIC16F1825 micro-controller with two digit frequency display.
Project provides TTL output signal, frequency 1Hz-25Hz, Tact switches provided to set the frequency.
This project works along with DC Output Solid State Relay
- Supply 4.5 to 5V DC
- Frequency 1Hz To 25Hz
- Easy Interface with Relay Board
- Easy Interface with Solid State Relay
- On Board Power LED
- On Board Output LED
- Onboard Switch to set the frequency
- 2X7 Segment 0.5 Inch Display
Applications
- Strobe for Entertainment
- Traffic Signal
- Warning Signal
- Ambulance Warning Signals
Schematic
I need a code; can you share the code link? Thank you
I shared the tested .hex file in the downloads above.
