Versatile Link Fiber-Optic Receiver
HBBR-2521Z Fiber Link is able to receive TTL data up to 5Mbaud@53meter distance. It uses a 5V supply and it has High EMI immunity and voltage isolation.
Modules by mixos
This module enables users to create a versatile fiber-optic link for applications requiring a low-cost solution. This receiver module receives data through a fiber-optic link and outputs standard TTL-level signals. It supports transmission distances of up to 19 meters with standard fiber-optic cable and up to 53 meters with enhanced cable.
Operating from a 5V power supply, the receiver supports data rates of up to 5 Mbaud. Typical applications include systems that require voltage isolation/insulation, EMI/RFI immunity, or improved data security. The optical link design is simplified by the use of logic-compatible receivers and the availability of complete specifications for each component.
Receiver include a monolithic DC-coupled, digital IC receiver with an open collector Schottky output transistor. An internal pull-up resistor is available.  A shield has been integrated into the receiver IC to provide additional, localized noise immunity. Internal optics have been optimized for use with 1-mm diameter polymer optical fibre. Versatile Link specifications incorporate all connector interface losses. Therefore, optical calculations for common link applications are simplified.
The design incorporates the HBBR-2521Z receiver module, which supports data rates up to 5 Mbaud. For applications requiring other speeds, refer to the provided table for alternative modules that support both lower and higher data rates.
  • Power Supply 5V DC
  • Output Signal TTL
  • SMA Connector for Output
  • 3 Pin Header for the Power Input
  • Rx Output connector current 25mA
  • Enhanced digital links: DC to 5 Mbaud
  • Link distance with standard cable 19Meters
  • Link distance up to 53Meters with improved cable
  • The propagation delay for one meter of cable is typically 5 ns
  • High noise immunity
  • Easy connecting: simplex, duplex, and latching connectors Flame retardant
  • Compatible with standard TTL circuitry
  • PCB dimensions 32.86 x 28.42 mm
  • PCB Mounting Holes 4 x 3 mm
Applications
  • Reduction of lightning/voltage transient susceptibility
  • Motor controller triggering
  • Data communications and local area networks
  • Electromagnetic compatibility (EMC) for regulated systems such as FCC, VDE, and CSA
  • Tempest-secure data processing equipment
  • Isolation in test and measurement instruments
  • Error-free signalling for industrial and manufacturing equipment
  • Automotive communications and control networks
  • Noise-immune communication in audio and video equipment
Connections
  • CN1: Pin 1 = GND, Pin 2 = VDD 5V DC, Pin 3 = Data Output
  • J1: Data Output
Schematic
Parts List
NO.QNTY.REF.DESC.MANUFACTURERSUPPLIERSUPPLIER PART NO
11CN23 PIN MALE HEADER PITCH 2.54MMWURTHDIGIKEY732-5316-ND
21C3100nF/50V CERAMIC SMD SIZE 0805YAGEODIGIKEY
31U3HFBR-2521ZBROADCOMDIGIKEY516-2062-ND
41C410uF/16V TANTLUM 1210MURATADIGIKEY
51J1SMA CONNECTOR RIGHT ANGLEADAM TECHDIGIKEY2057-RF2-03E-T-00-50-G-ND
Connections
Application Diagram
Optical Cable Connection
Gerber View
System Performance vs Cable Selection
Receiver Diagram
Link Selection Guide
Photos
Related Content
