Texas Instruments Unveils Dual RC-Timed Retriggerable Monostable Multivibrators
The TPUL2G123 is a two-channel monostable RC configurable pulse generator available in commercial and automotive-qualified versions for pulse generation and timing applications.
Texas Instruments has developed the TPUL2G123, a dual, retriggerable monostable multivibrator designed to provide a flexible solution for generating precise, fixed-width digital pulses. The pulse generator is also available with an AEC-Q100 Grade 1 qualification for automotive applications.
Texas Instruments’ TPUL2G123 and TPUL2G123-Q1 pulse generators feature balanced outputs, partial power down (Ioff), high speeds (tpd 10-50 ns), and over-voltage tolerant inputs
Texas Instruments’ TPUL2G123 and TPUL2G123-Q1 pulse generators feature balanced outputs, partial power down (Ioff), high speeds (tpd 10-50 ns), and over-voltage tolerant inputs. Image used courtesy of Texas Instruments
Texas Instruments’ TPUL2G123 and TPUL2G123-Q1 operate from a wide supply voltage range of 1.5 V to 5.5 V.  The devices are based on an external resistor-capacitor network, which sets the output pulse duration. The pulse width is approximately equal to R × C, providing a simple and intuitive way for engineers to configure the timing. The datasheet specifies a resistor-capacitor configurable range from 1 µs to 860 ms, with a typical pulse width variation of 1%. This precision is a key benefit, especially for applications where timing accuracy is critical.
Both the TPUL2G123 and TPUL2G123-Q1 come in a compact TSSOP package (16-pin) to simplify integration in space-constrained electronics.
Functional block diagram of the TPUL2G123 and TPUL2G123-Q1
Functional block diagram of the TPUL2G123 and TPUL2G123-Q1. Image used courtesy of Texas Instruments
Enhanced Noise Immunity Using Schmitt-Trigger Inputs
The TPUL2G123 and TPUL2G123-Q1 provide three trigger inputs, supporting rising-edge, falling-edge, and an asynchronous clear input that can terminate an ongoing pulse. This versatility allows the device to serve multiple functions in a single design.
A notable feature of the monostable multivibrators is the Schmitt-trigger architecture on all inputs, which enhances noise immunity and tolerates slow input transition rates. This is particularly valuable in noisy electrical systems where signal integrity can be a challenge.
The flexibility and robustness of the devices make them suitable for a variety of applications. It can be used to demodulate amplitude shift keying (ASK) signals, reset a system for a fixed duration, or generate a simple, positive fixed-width pulse. In addition to these timing functions, the device’s Schmitt-trigger inputs and fixed-pulse output make it an effective solution for debouncing mechanical switches, a common requirement in automotive control systems.
Clamping diode placement for TPUL2G123 inputs and outputs
Clamping diode placement for TPUL2G123 inputs and outputs. Image used courtesy of Texas Instruments
Pulse and Delay Generation
Texas Instruments’ TPUL2G123 and TPUL2G123-Q1 offer a robust solution for pulse generation and timing applications. The combination of a wide operating voltage range, resistor-capacitor configurability, and Schmitt-trigger inputs aims to simplify designs in harsh electrical environments. Potential applications include switch debouncing, system resets, and pulse generation for automotive on-board chargers, body control modules, and infotainment systems.
