2.9″ ESPaper Lite Kit for $39.90
The 2.9″ ESPaper Lite Kit contains most of the parts you need to display data over wifi: With the 2.9″ ESPaper module you can display data retrieved over WiFi on an ePaper with little effort. The integrated ESP8266 Wroom-02 module updates the 296×128 B&W ePaper display over the SPI bus.
Displays Power by mixos
With the 2.9″ ESPaper module you can display data retrieved over WiFi on an ePaper with little effort. The integrated ESP8266 Wroom-02 module updates the 296×128 B&W ePaper display over the SPI bus. The module also features a charging circuit for LiPo batteries and a JST connector which allows you to run the module for weeks or even months from a battery. How long the module can be run from battery mostly depends on the update frequency and the battery capacity. In tests we could run the module from a 800mAh LiPo battery for several weeks by updating weather information every 20 minutes.
2.9″ ESPaper Lite Kit for $39.90 – [Link]
Tags
