ADLINK DLAP-701 Edge AI Platform Powered by NVIDIA Jetson Thor
ADLINK’s DLAP-701 uses NVIDIA Jetson Thor with up to 128GB LPDDR5X, high-speed I/O, and industrial design for robotics, vision, and AI workloads.
ADLINK DLAP-701 NVIDIA Jetson based edge AI Platform
The DLAP-701 Series, an NVIDIA Jetson T5000/T4000-based compact edge AI platform for humanoid robots, autonomous mobile robots (AMR), and vision sensing systems (VSS), was recently introduced by ADLINK. Humanoid autonomous robots can function safely and effectively in some of the most challenging industrial settings, such as mining sites, construction zones, and energy facilities, thanks to DLAP-701, which is based on NVIDIA Jetson Thor. The DLAP-701 is intended for high memory bandwidth workloads and medical image analysis within the compact range. With a 14-core ARM Neoverse-V3AE CPU and up to 128GB LPDDR5X memory, it is powered by the NVIDIA Jetson T5000 or T4000, which can deliver up to 2,070 FP4 TFLOPS. It functions between -10°C and 35°C and has a dual GbE LAN and a QSFP port that supports 4×25GbE.
The cutting-edge NVIDIA Blackwell architecture is the foundation of the DLAP-701. Dual Gigabit Ethernet, multiple USB 3.2 ports, HDMI output, M.2 slots for Wi-Fi 6, 5G, and NVMe storage, as well as a mPCIe slot, are among the I/O options supported by the ADLINK DLAP-701. Additionally, it incorporates TPM 2.0 security and CAN-FD interfaces for robotics and vehicle control. It is made for harsh edge environments and has an industrial temperature range of -20°C to 60°C and an operating voltage range of 9-36V DC.
Previously, we covered several NVIDIA Jetson-based edge AI platforms, including the reComputer J3011B, reComputer J3011, and reComputer J4012. Feel free to explore them if you’re interested.
ADLINK DLAP-701 Front and Back PortsADLINK DLAP-701 Front and Back Ports
ADLINK DLAP-701 Specifications:
  • System-on-Module (SoM): Supports NVIDIA Jetson Thor T5000 or NVIDIA Jetson Thor T4000
  • Memory:
    • Up to 128GB LPDDR5X (T5000 variant)
    • Up to 64GB LPDDR5X (T4000 variant)
    • 256-bit memory interface delivering up to 273 GB/s bandwidth
  • Storage:
    • 128GB onboard SSD for OS (likely ADLINK ASD+ industrial-grade SSD)
    • M.2 M-key slot for NVMe SSD expansion
  • Display:
    • Dual HDMI 2.0b outputs
    • Supports up to 3840 × 2160 resolution at 60Hz
  • Audio: 2 × 3.5mm audio jacks (Mic-in and Line-out)
  • Networking:
    • 2 × Gigabit Ethernet ports (10/100/1000 Mbps, RJ45)
    • 1 × QSFP28 port (configurable as 4 × 25GbE)
    • M.2 E-key slot for Wi-Fi 6 connectivity
    • M.2 3052/3042 B-key slot for 5G modules
    • Dual micro-SIM slots for 5G dual-SIM support
  • USB Interfaces:
    • 4 × USB 3.2 Type-A ports
    • 2 × USB 3.1 Type-C ports (front and rear)
    • 1 × front-facing USB Type-C port dedicated for BSP installation
  • Expansion Interfaces:
    • 1 × M.2 2280 M-key slot (NVMe SSD)
    • 1 × M.2 2230 E-key slot (Wi-Fi 6)
    • 1 × M.2 3052/3042 B-key slot (5G cellular)
    • 1 × mPCIe slot
  • Industrial I/O (20-pin Euro Terminal Block):
    • 1 × Isolated CAN-FD (3KV isolation)
    • 3 × CAN-FD interfaces with transceivers
    • UART and I²C interfaces
    • +5V (1A) and +3.3V (1A) power outputs
  • Security: Integrated TPM 2.0 module
  • Misc:
    • RTC battery
    • Internal thermal sensor
    • Front power button and rear recovery button
    • 3 × internal fan headers
  • Power Supply: 9V to 36V DC input (±5%) via terminal block
  • Mechanical and Environmental:
    • Dimensions: 211 × 194 × 94 mm (including rubber feet)
    • Weight: 2 kg
    • Operating temperature: -20°C to 60°C
    • Operating humidity: Up to 95% at 40°C (non-condensing)
In terms of software support, the company provides Windows, Ubuntu, and EdgeGO software compatibility. The DLAP-701 Series supports the NVIDIA AI Enterprise eco-system as well as AI development frameworks such as Isaac (for robotics) and Holoscan (for medical). Therefore, allowing developers to develop on a single software platform, the DLAP-701 Series provides solutions to develop applications on this platform for any other branch of the enterprise.
There is no known cost for ADLINK’s DLAP-701, and so to get pricing information on this type of industrial edge AI system, users would need to reach out directly to ADLINK. Please go through the press release for more information.
Images used courtesy of ADLINK
