PWM Halogen Lamp Dimmer
https://www.electronics-lab.com/pwm-halogen-lamp-dimmer/
High Current PWM Halogen Dimmer controller project is designed around SG3525 IC and High current MOSFET. Project can handle lamp up to 5 Amps (10Amps Possible with big heat sink) and supply 12-24V DC .Ideal for Halogen Dichroic Lamp or Halogen Lamp. Specifications  Supply input 15 to 24 VDC Load-Lamp 12 to 24 VDC @ […]
https://www.electronics-lab.com/project/pwm-halogen-lamp-dimmer/
LT8331- Low IQ Boost/SEPIC/ Flyback/Inverting Converter
https://www.electronics-lab.com/lt8331-low-iq-boostsepic-flybackinverting-converter/
The LT8331 is a current mode step-­up DC/DC converter with an internal 500mA, 140V switch. It operates from an input voltage range of 4.5V to 100V, making it suitable for use with a wide range of input sources found in industrial, transportation and avionic applications. The LT8331 can be configured as either a boost, SEPIC, […]
Voice Changer
https://www.electronics-lab.com/voice-changer/
Voice Changer project can be used to transpose or distort one’s voice by encoding the sound appearing at the Microphone input. This project is built around AP8072 IC. Specifications Supply input : 6 VDC @ 200 mA Output : Speaker, 8 Ω / 0.5 W Audio amplifier type LM386 with volume control preset Jumper selectable […]
Voice Changer
https://www.electronics-lab.com/project/voice-changer/
DIY SWR and Power Meter
https://www.electronics-lab.com/diy-swr-and-power-meter/
diycrap.blogspot.com has build a SWR and power meter based on Arduino Nano and LCD display: First of all, this SWR meter in this article is not exactly homebrew, as I based the circuit on the schematic in the excellent book Arduino Projects of Amateur Radio. Although I bought the book and respect the copyright of […]
Nandland Go Board – Your FPGA Playground
https://www.electronics-lab.com/nandland-go-board-your-fpga-playground/
There’s a new FPGA development board on Kickstarter. It’s called the Nandland Go Board, and it aims to be an inexpensive, easy-to-use FPGA development board to learn about how FPGAs work and what they are capable of. This board is unique because it provides a lot of options for projects built directly into the board. […]
Universal shield for popular platforms Raspberry Pi, Arduino, Intel Edison
https://www.electronics-lab.com/universal-shield-for-popular-platforms-raspberry-pi-arduino-intel-edison/
Modulowo DuoNect™ is a universal solution for rapid prototyping and production that allows easy connection of expansion modules, such as sensors, controllers, buttons, analog and digital IC, GPS, Bluetooth, WiFi (and more) for platforms, such as, Intel® Edison, Raspberry Pi, Arduino, Genuino, STM32 Nucleo, TI LaunchPad, Atmel Xplained or Freescale Freedom / Kinetis. Specifications: standard […]
Power Management of Xilinx ZedBoard using MMPF0100
https://www.electronics-lab.com/power-management-of-xilinx-zedboard-using-mmpf0100/
This reference design is a power management of Xilinx ZedBoard using MMPF0100 Power Management Integrated Circuit (PMIC). A PMIC is an IC for managing power requirements of the host system and is commonly used in a system-on-chip (SoC) device. On the other hand, the Xilinx ZedBoard, a development board based on Zync-7000 AP SoC, provides […]
Tiny Mic Preamplifier
https://www.electronics-lab.com/tiny-mic-preamplifier/
The Tiny Mic Preamplifier based is based on a single transistor amplifier design. It amplifies the output of the electret condenser microphone. Good choice for Karaoke. Specifications Power supply: 5 ~ 9 VDC @ 2 mA Provides standard audio signal PCB dimensions 26 mm x 56 mm Tiny Mic Preamplifier – [Link]
